GMF2 and PropertyProvider [message #63884] |
Tue, 17 October 2006 07:28  |
Originally posted by: tobk.gmx.de
just experimenting with GMF2 Stream Stable Build. The new features and
bugfixes are really cool, but I miss the old extendable property source. I
do not mean that division in EMF and Style Folders (I didn't like that),
but I need to be able to extend some EObject-references.
In my model I have some non-visible elements which's attributes can be
modified only in their parent's property source (or in the EMF-Editor, but
switching between them s***s).
The GMF 1.0 had a class named XXXPropertyProvider which seems to have cared
about that. Now the standard EMF-Property view is used. By this, the
multiref-bug has been fixed, but I really miss the extendable EObject
references.
I tried to copy the PropertyProvider from an earlier version and restoring
the extension point in the plugin.xml, but it didn't work. Are there other
places I'd have to fix? Or will there be extendable property sources in the
final 2.0 release again? Or could you give me a template how to provide
extensible property sources in the edit code?
Since these elements do not have Edit Parts I can not select them via the
navigator, too.
tobias
PS.: Would you recommend to switch the GMF2 or to stick with the 1.0 for
now? I'd neither care about issues that might already be fixed in 2.0, nor
do I like to run in a dead end when relying on a feature that might not
make it in the final version...
Re: GMF2 and PropertyProvider [message #64000 is a reply to message #63884] |
Tue, 17 October 2006 07:50   |
Add GenStandardPropertyTab with 'advanced' id to your GenPropertySheet and
you'll get the page that consults PropertyProviders back.
Artem
"tobias" <tobk@gmx.de> wrote in message
news:eh2em0$29v$1@utils.eclipse.org...
> Hello,
> cared
> references.
> the
> navigator, too.
> tobias
Re: GMF2 and PropertyProvider [message #64023 is a reply to message #63884] |
Tue, 17 October 2006 07:52   |
Take 2.0. Users are those to decide what and how makes it into final
versions, and if they don't check and verify what we are doing for 2.0, we
might end up with a thing they don't really need. ;)
Artem
> Hello,
> cared
> references.
> the
> navigator, too.
> tobias
Re: GMF2 and PropertyProvider [message #64954 is a reply to message #64135] |
Wed, 18 October 2006 07:12  |
> - There were some annoying and discouraging errors when configuring the
> new
> standard property tab
Some hints, what did they say?
> - a combobox holding the possible identifiers would be nice
File a bug, please
> - the XXXPropertyProvider and the extension point were not created; I had
> to
Yep, that's intended. Advanced page provides means to plug-in your own
providers (consulting PropertiesService), but it's up to client to write
providers that fill it.
Artem
news:eh2ies$r1e$1@utils.eclipse.org...
>> and
> Worked (nearly) perfectly.
> Some notes (no complaining; feedback):
> new
> to
> copy them from an earlier version (which does not everybody have). without
> it there only was the appearence folder
> tobias
FUDForum. Page generated in 0.05532 seconds
