how to use API docs [message #63874] |
Fri, 13 May 2005 09:24  |
Originally posted by: uranus.zhang.gmail.com
i've configed the javadoc places,and after using Shift+F2,the doc in html
format appeared.
when my mouse hovering on a method,press F2,there was an empty field,how can
i enable the API doc ?
Re: how to use API docs [message #63964 is a reply to message #63874] |
Fri, 13 May 2005 11:21  |
Originally posted by: eclipse.rizzoweb.com
> format appeared.
The text for the hover boxes (tooltips) is pulled from the source code,
so you'll need to specify source locations for any libraries (JARs) that
you want to see JavaDoc in the editor.
HTH,
Eric
FUDForum. Page generated in 0.07335 seconds
