Home » Archived » M2M (model-to-model transformation) » [ATL] ecore to ecore transformation
[ATL] ecore to ecore transformation [message #63873] Fri, 12 October 2007 10:35 Go to next message
Originally posted by: n.toublanc.laposte.net
Hi all,
I'm trying to write my first ATL project using Eclipse 3.3. Here is my
first ATL file :
module ClassModel2DAClassModel; -- Module Template
create da : MOF from dto : MOF;
rule Package{
from
ip :MOF!EPackage
to
op :MOF!EPackage(
name <- ip.name + '.da.hibernate.impl'
rule Class {
from
ic : MOF!EClass
to
oc : MOF!EClass (
name <- ic.name + 'DAImpl'
The result is that the packages and the classes are created with the
suffixes I specified.
Example :
- km3 format of my ecore input
package "com.mdd.test" {
class Project {
attribute name[0-1] : ;
attribute beginDate[0-1] : ;
attribute endDate[0-1] : ;
attribute id[0-1] : ;
- km3-like format of my ecore output
package "com.mdd.test.da.impl" {
class ProjectImpl {
So, it's not too bad to begin. The first problem is that my classes are
not in the package. How could I do that in my ATL file?
Then, I would like to add some methods in my MyClassDAImpl like :
public List<MyClass> getAll(){
How could I do that?
I will try to read the ATL guide to understand that myself, but I you
can simply explain me the concepts I need to know to do that, it would
really help me.
Thanks for your help.
Re: [ATL] ecore to ecore transformation [message #63896 is a reply to message #63873] Fri, 12 October 2007 10:43 Go to previous messageGo to next message
Originally posted by: freddy.allilaire.univ-nantes.fr
Hi Nicolas,
I advise you to take a look to the following article/example:
http://www.eclipse.org/m2m/atl/basicExamples_Patterns/Tree2L ist/
(especially section 6).
Freddy.
Nicolas Toublanc a écrit :
> Hi all,
> first ATL file :
> rule Package{
> from
> ip :MOF!EPackage
> to
> op :MOF!EPackage(
> rule Class {
> from
> ic : MOF!EClass
> to
> oc : MOF!EClass (
> Example :
> class Project {
> class ProjectImpl {
> really help me.
> Regards
Freddy Allilaire - ATLAS Group (INRIA & LINA)
http://www.sciences.univ-nantes.fr/lina/atl/contrib/allilair e
Re: [ATL] ecore to ecore transformation [message #63920 is a reply to message #63873] Fri, 12 October 2007 10:48 Go to previous messageGo to next message
--------------000408080103040109060308
To link classes with packages, you must create the containment link in
the rule. In your case, you can add a binding in the "Package" rule,
like this :
eClassifiers <- ip.eClassifiers
Then to create an operation in a class, you have to add a binding in the
class to rely the operation, and to describe the operation creation.
Here is an example :
rule Class {
from
ic : MOF!EClass
to
oc : MOF!EClass (
operations <- Sequence{getAllOperation}
and then in the same rule
rule Operation {
from
io : MOF!EOperation
to
oo : MOF!EOperation (
name <- io.name,
parameters <- io.eParameters,
type <- io.eType
Nicolas Toublanc a
Re: [ATL] ecore to ecore transformation [message #63942 is a reply to message #63920] Fri, 12 October 2007 10:51 Go to previous message
--------------060402080805000202060001
Sorry, I encountered a bug and didn't finish my answer...
So I wanted to describe the class rule which adds an operation to the
class element :
rule Class {
from
ic : MOF!EClass
to
oc : MOF!EClass (
name <- ic.name + 'DAImpl',
getAllOperation : MOF!EOperation (
name <- 'getAll'
etc...
Content-Type: text/x-vcard; charset=utf-8;
name="william.piers.vcf"
Content-Disposition: attachment;
filename="william.piers.vcf"
begin:vcard
fn:William Piers
n:Piers;William
org:Obeo
adr:2 rue Robert Schumann;;lot 24;NANTES;;44408;France
email;internet:william.piers@obeo.fr
title:MDA Consultant
tel;work:+33 (0)2 51 13 51 82
tel;cell:+33 (0)6 20 31 75 98
url:http://www.obeo.fr
version:2.1
end:vcard
--------------060402080805000202060001--
Previous Topic:[QVTOM] Mapping calls in strict mode
Next Topic:antlr/TokenStream error
Current Time: Thu Jul 17 22:02:43 EDT 2025
Powered by FUDForum. Page generated in 0.07363 seconds
