Home » Archived » Visual Editor (VE) » inserting swt container results in error?
inserting swt container results in error? [message #63807] Fri, 01 October 2004 18:14 Go to next message
Originally posted by: wim.nospam.org
Hi all,
I have a table and two buttons on a swt shell (gridlayout). I decide to
introduce a tree and drop a sashform on the shell. Then i drag the table and
the buttons on the sashform. If i now run the application, there is a
recursive method call where the createsashform() method runs the
createSShell() function (twice) where the createsashform() method is called.
Correcting this error manually results in restore from local history (also
manually).
Bugzilla?
Wim Jongman
Re: inserting swt container results in error? [message #64183 is a reply to message #63807] Mon, 04 October 2004 11:08 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Yes, please open a bugzilla. Tell us how you created the class
originally, then the steps you did, and then finally attach as source
the java file we produced so that we can see what code was created
incorrectly.
Rich Kulp
Re: inserting swt container results in error? [message #64345 is a reply to message #63807] Mon, 04 October 2004 11:54 Go to previous message
Originally posted by: mendelgili.netscape.net
Wim Jongman wrote:
> Hi all,
> manually).
> Bugzilla?
> Wim Jongman
Yep, we do not handle yet visually moving a component the is locally defined inside another component's init method, to
another component.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=71661
Re: inserting swt container results in error? [message #600579 is a reply to message #63807] Mon, 04 October 2004 11:08 Go to previous message
incorrectly.
Rich Kulp
Re: inserting swt container results in error? [message #600649 is a reply to message #63807] Mon, 04 October 2004 11:54 Go to previous message
Wim Jongman wrote:
> Hi all,
> manually).
> Bugzilla?
> Wim Jongman
another component.
Previous Topic:Problem Installing VE plugin
Next Topic:my first experience with vep
Current Time: Fri Jul 18 23:19:48 EDT 2025
Powered by FUDForum. Page generated in 0.03971 seconds
