Home » Eclipse Projects » GEF » GEF build problem
GEF build problem [message #63801] Sun, 09 February 2003 15:34 Go to next message
I get all the files in CVS for GEF, but I can't build the file
DomainEventDispatcher.java.
I got the following errors. I build it with Eclipse 2.1 M5. Is there some
changes in the class SWTEventDispatcher in Eclipse 2.1 M5 which causes these
compilation error?
Thank you.
This class must implement the inherited abstract method
EventDispatcher.getCursorTarget(), but cannot override it since it is not
visible from DomainEventDispatcher. Either make the type abstract or make
the inherited method visible.
EventDispatcher.getMouseTarget(), but cannot override it since it is not
EventDispatcher.releaseCapture(), but cannot override it since it is not
EventDispatcher.setCapture(IFigure), but cannot override it since it is not
EventDispatcher.updateCursor(), but cannot override it since it is not
Re: GEF build problem [message #63826 is a reply to message #63801] Sun, 09 February 2003 18:05 Go to previous message
The code is fine. M5 is broken.
(No you know why I was asking you how you were able to build GEF with M5 in
your thread below)
Previous Topic:Using ChopBoxAnchor in GEF 0206
Next Topic:Plan updated on website
Current Time: Sun Nov 23 23:19:51 EST 2025
Powered by FUDForum. Page generated in 0.03759 seconds
