| 2 levels of xsd:redefine [message #63789] |
Mon, 26 September 2005 14:13  |
Originally posted by: abanerjee.vitria.com
Hi Ed,
With your help I was able to resolve the a single level of xsd:redefine.
However 2 levels of xsd:redefine does not work.
I am appending the sample program and the 4 schemas for your reference.
The 1st is the parent schema. It includes the 2nd schema which redefines
the 3rd which redefines the 4th.
The sample program prints out all the resolved elements of CompleType -
ClaimType. Am I missing something?
Thanks in advance,
-Anindita.
import org.eclipse.emf.ecore.resource.*;
import org.eclipse.xsd.util.*;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.common.util.URI;
import org.eclipse.xsd.*;
import java.util.*;
import java.io.File;
public class TestRedefine {
private XSDSchema schema_;
public TestRedefine() {
void checkComplexTypeForElement(XSDComplexTypeDefinition complexType) {
if (complexType.getContentType() instanceof XSDParticle ) {
XSDModelGroup modelGrp =
(XSDModelGroup)((XSDParticle)complexType.getContentType()).g etTerm();
checkModelGroupForElement(modelGrp, "");
} else
System.out.println("complexType.getContentType(): " +
complexType.getContentType().getClass().getName());
XSDElementDeclaration checkModelGroupForElement(XSDModelGroup modelGroup,
String tab) {
tab = tab + " ";
List particles = modelGroup.getParticles();
System.out.println(tab + "Size of particles is " + particles.size());
XSDElementDeclaration xsElement = null;
for (Iterator iter = particles.iterator(); iter.hasNext();) {
XSDTerm term = ((XSDParticle)iter.next()).getTerm();
if (term instanceof XSDElementDeclaration) {
System.out.println(tab + "FOUND ELEMENT: " +
((XSDElementDeclaration)term).getName());
} else if (term instanceof XSDModelGroup) {
xsElement = checkModelGroupForElement((XSDModelGroup)term, tab);
} else
System.out.println(tab + "wildcard group:" + term);
return xsElement;
XSDComplexTypeDefinition getComplexType(String memberName) {
List allTypes = schema_.getTypeDefinitions();
for (Iterator iter = allTypes.iterator(); iter.hasNext();) {
XSDTypeDefinition typedef = (XSDTypeDefinition)iter.next();
if ((typedef instanceof XSDComplexTypeDefinition) &&
typedef.getName().equals(memberName))
return (XSDComplexTypeDefinition)typedef;
return null;
XSDSchema loadSchema(String fname) throws Exception {
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "xsd",
new XSDResourceFactoryImpl());
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getLoadOptions().put(XSDResourceImpl.XSD_TRACK_L OCATION,
Boolean.TRUE);
URI uri = URI.createURI(fname);
XSDResourceImpl xsdSchemaResouce = (XSDResourceImpl)
resourceSet.getResource(uri, true);
for (Iterator resources = resourceSet.getResources().iterator();
resources.hasNext(); ) {
Resource resource = (Resource)resources.next();
if (resource instanceof XSDResourceImpl) {
XSDResourceImpl xsdResource = (XSDResourceImpl)resource;
schema_ = xsdResource.getSchema();
return schema_;
return null;
try {
String fname = args[0];
File file = new File(fname);
TestRedefine sch = new TestRedefine();
sch.loadSchema(file.toURL().toString());
XSDComplexTypeDefinition claim = sch.getComplexType("ClaimType");
sch.checkComplexTypeForElement(claim);
} catch (Exception e) {
e.printStackTrace();
Schema 1:
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<xsd:include schemaLocation="ClaimType.xsd"/>
<xsd:element name="Claim" type="ClaimType"/>
</xsd:schema>
Schema 2:
<xsd:redefine schemaLocation="two/ClaimType.xsd">
<xsd:complexType name="ClaimType">
<xsd:complexContent>
<xsd:extension base="ClaimType">
<xsd:sequence>
<xsd:element name="NewEncounterFlag" type="xsd:boolean" minOccurs="0"/>
</xsd:sequence>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
</xsd:redefine>
</xsd:schema>
Schema 3:
<xsd:redefine schemaLocation="../one/ClaimType.xsd">
<xsd:sequence>
<xsd:element name="EncounterFlag" type="xsd:boolean" minOccurs="0"/>
</xsd:sequence>
</xsd:extension>
</xsd:complexType>
</xsd:redefine>
</xsd:schema>
Schema 4:
<xsd:sequence>
<xsd:element name="AccidentCountryCode" type="xsd:string" minOccurs="0"/>
<xsd:element name="AccidentDateTime" type="xsd:dateTime" minOccurs="0"/>
<xsd:element name="AccidentStateCode" type="xsd:string" minOccurs="0"/>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
| Re: 2 levels of xsd:redefine [message #63817 is a reply to message #63789] |
Mon, 26 September 2005 16:33   |
Anindita,
Could you provide a zip of the schemas, so that I don't have to figure
out their file names and relative locations? Or at least outline the
path names...
Anindita Banerjee wrote:
> Hi Ed,
> xsd:redefine. However 2 levels of xsd:redefine does not work.
> reference. The 1st is the parent schema. It includes the 2nd schema
> which redefines the 3rd which redefines the 4th.
> - ClaimType. Am I missing something?
> Thanks in advance,
> -Anindita.
> import java.util.*;
> } else
> modelGroup, String tab) {
> tab = tab + " ";
> tab);
> } else
> return xsElement;
> return null;
> Boolean.TRUE);
> return schema_;
> return null;
> public static void main(String[] args) {
> try {
> Schema 1:
> </xsd:schema>
> Schema 2:
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> </xsd:redefine>
> </xsd:schema>
> Schema 3:
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> </xsd:redefine>
> </xsd:schema>
> Schema 4:
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
| Re: 2 levels of xsd:redefine [message #63928 is a reply to message #63907] |
Tue, 27 September 2005 13:47  |
Anindita,
Other than the issue reported in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=106098 import and include
should work fine in general.
> Ed,
> Thanks for the response. I was able to resolve element definitions
> with more than 2 level of xsd:include and xsd:import. Do you know of
> any bugs/limitations with multiple levels of xsd:import and xsd:include.
> -Anindita.
| Re: 2 levels of xsd:redefine [message #596582 is a reply to message #63789] |
Anindita,
path names...
> Hi Ed,
> Thanks in advance,
> -Anindita.
> import java.util.*;
> } else
> tab = tab + " ";
> tab);
> } else
> return xsElement;
> return null;
> Boolean.TRUE);
> return schema_;
> return null;
> try {
> Schema 1:
> </xsd:schema>
> Schema 2:
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> </xsd:redefine>
> </xsd:schema>
> Schema 3:
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> </xsd:redefine>
> </xsd:schema>
> Schema 4:
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
| Re: 2 levels of xsd:redefine [message #596594 is a reply to message #63817] |
Mon, 26 September 2005 16:46  |
Hi Ed,
How do I attach a file to the posting?
Schema 1 and Schema 2 should be in the current directory.
Schema 3 should be a directory called "two" in the current directory.
Schema 4 should be in a directory called "one" within the current
directory.
Schema 2, 3 and 4 should all be called ClaimType.xsd.
-Anindita.
| Re: 2 levels of xsd:redefine [message #596601 is a reply to message #63840] |
Mon, 26 September 2005 17:11  |
Anindita,
Okay. I'll try to have a look tomorrow.
> Hi Ed,
> directory.
> -Anindita.
| Re: 2 levels of xsd:redefine [message #596607 is a reply to message #63840] |
Tue, 27 September 2005 08:29  |
Anindita,
This looks like yet another manifestation of
https://bugs.eclipse.org/bugs/show_bug.cgi?id=83055 This bug and all
the problems associated with complex uses of redefine are something that
I simply don't have time to fix. You'll find that Xerces has bugs in
this area too. The whole concept of redefinition is far too loosely
defined in the spec and coming up with a consistent model for the
semantics is a challenge beyond my abilities as well as beyond my
resource capacity. Sorry. :-(
> Hi Ed,
> directory.
> -Anindita.
| Re: 2 levels of xsd:redefine [message #596620 is a reply to message #63885] |
Tue, 27 September 2005 13:42  |
Ed,
Thanks for the response. I was able to resolve element definitions with
more than 2 level of xsd:include and xsd:import. Do you know of any
-Anindita.
FUDForum. Page generated in 1.05983 seconds
