Home » Modeling » GMF (Graphical Modeling Framework) » Ordering of model elements based on position
Ordering of model elements based on position [message #63774] Tue, 17 October 2006 06:50 Go to next message
Hi All,
I was wondering if there is a GMF by which one can control the occurence
of model element based on the postion of the notational element in the
diagram file.
For ex:
Assume form with id "ABC" was added first and then "def" was added. The
model file is generated as follows;
<vxml>
<form id="ABC"/>
<form id="def"/>
</vxml>
Now if the first form is deleted and added again I still want the order to
be same. How can I achieve this?
Can someone please help me with this.
Thanks & regards
Balraj
Re: Ordering of model elements based on position [message #63955 is a reply to message #63774] Tue, 17 October 2006 07:43 Go to previous messageGo to next message
Hi All,
I was wondering if there is a way in GMF by which one can control the
occurence of model element based on the position of the notational element
in the diagram file.
For ex:
<vxml>
<form id="ABC"/>
<form id="def"/>
</vxml>
Now if I want to reorder the elements in the model file by exchanging the
positions of the form with id "ABC" with id "def" model should now be
generated as follows:
<vxml>
<form id="def"/>
<form id="ABC"/>
</vxml>
Is there a way to do this?
Thanks & regards
Balraj
Re: Ordering of model elements based on position [message #64046 is a reply to message #63774] Tue, 17 October 2006 07:55 Go to previous messageGo to next message
Ordering within your domain model is not GMF's job. If you care only about
visual representation, check notation.SortingStyle.
Artem
"Balraj Kannan" <balraj.kannan@hp.com> wrote in message
news:1f6e08a0a6ea25fe36cac34ca3ec9914$1@www.eclipse.org...
> Hi All,
> diagram file.
> For ex:
> <vxml>
> <form id="ABC"/>
> <form id="def"/>
> </vxml>
> Thanks & regards
> Balraj
Re: Ordering of model elements based on position [message #64773 is a reply to message #64046] Wed, 18 October 2006 00:10 Go to previous messageGo to next message
Hi Artem,
Thanks for your reply. I understand this may not be possible from the GMF
framework. But If I intent to handle it programmatically is it possible?
If yes How can I go about it.
Best Regards
Balraj
Re: Ordering of model elements based on position [message #64922 is a reply to message #64773] Wed, 18 October 2006 07:08 Go to previous message
Almost everything is possible ;) To help with "how" it would be great to
know "what" first. Reordering visual elements or domain?
news:a06d01003e10904a332e95900577d7db$1@www.eclipse.org...
> Hi Artem,
> Thanks
> Best Regards
> Balraj
Previous Topic:Proper usage of diagram node selection and subsequent command processing
Next Topic:GMF2 and PropertyProvider
Current Time: Tue Dec 02 18:36:29 EST 2025
Powered by FUDForum. Page generated in 0.04413 seconds
