| Multiple editor windows for the same file when activating a task [message #63728] |
Fri, 02 January 2009 05:59 |
Originally posted by: jeffreyz.q-free.com
--------------010702000102000302090004
Whenever I *activate* a task, my workspace is often populated with
multiple editors for some files (usually 2 editor windows for one or
more files in the context). Here is how I reproduce this problem:
1. I have a single editor window for a file, e.g., named "foo.sql".
2. I deactivate the task. The current context disappears.
3. I later activate the task and restore the context.
At this point there can be TWO editor windows opened for file "foo.sql".
In case there is disbelief, see the attached file that shows the list of
open editors (obtained with Ctrl-E). There are *two* entries for the
file "qp_STS_FinCSCShift.scp" (the last two lines in the menu).
This behaviour is not only annoying, but also leads to other problems:
I always close one of the duplicate tabs since this sort of thing is
very confusing to see (and no one likes to edit the same file in two
different windows - that always smells of corruption). Depending on
which tab (editor window) I close, the remaining editor window can end
up in read-only mode where I cannot make any editing changes - the
content acts as if they are frozen. Or, on other occasions, I can
modify the file in the remaining editor window, but I receive an error
message when I try to save it.
The only way out of this problem is to close the remaining editor
tab/window for the file. But this then removes the file from my context
so that I must rummage through my file system to find and open it again.
I have experienced this problem for several years (read: this is not a
new problem).
But I have not been able to locate any bug reports, nor any references
on the web to this problem.
Am I the only one seeing this problem? If not, are there any ways to
avoid this problem?
Thanks in advance.
Jeffrey
Content-Type: image/gif;
name="multiple_editor_windows_for_a_file.GIF"
Content-Disposition: inline;
filename="multiple_editor_windows_for_a_file.GIF"
R0lGODlhWQIPAvcAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/ AP//AAAA//8A
/wD//////wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMwAAZgAAmQAAzAAA/wAz AAAzMwAzZgAz
mQAzzAAz/wBmAABmMwBmZgBmmQBmzABm/wCZAACZMwCZZgCZmQCZzACZ/wDM AADMMwDMZgDM
mQDMzADM/wD/AAD/MwD/ZgD/mQD/zAD//zMAADMAMzMAZjMAmTMAzDMA/zMz ADMzMzMzZjMz
mTMzzDMz/zNmADNmMzNmZjNmmTNmzDNm/zOZADOZMzOZZjOZmTOZzDOZ/zPM ADPMMzPMZjPM
mTPMzDPM/zP/ADP/MzP/ZjP/mTP/zDP//2YAAGYAM2YAZmYAmWYAzGYA/2Yz AGYzM2YzZmYz
mWYzzGYz/2ZmAGZmM2ZmZmZmmWZmzGZm/2aZAGaZM2aZZmaZmWaZzGaZ/2bM AGbMM2bMZmbM
mWbMzGbM/2b/AGb/M2b/Zmb/mWb/zGb//5kAAJkAM5kAZpkAmZkAzJkA/5kz AJkzM5kzZpkz
mZkzzJkz/5lmAJlmM5lmZplmmZlmzJlm/5mZAJmZM5mZZpmZmZmZzJmZ/5nM AJnMM5nMZpnM
mZnMzJnM/5n/AJn/M5n/Zpn/mZn/zJn//8wAAMwAM8wAZswAmcwAzMwA/8wz AMwzM8wzZswz
mcwzzMwz/8xmAMxmM8xmZsxmmcxmzMxm/8yZAMyZM8yZZsyZmcyZzMyZ/8zM AMzMM8zMZszM
mczMzMzM/8z/AMz/M8z/Zsz/mcz/zMz///8AAP8AM/8AZv8Amf8AzP8A//8z AP8zM/8zZv8z
mf8zzP8z//9mAP9mM/9mZv9mmf9mzP9m//+ZAP+ZM/+ZZv+Zmf+ZzP+Z///M AP/MM//MZv/M
mf/MzP/M////AP//M///Zv//mf//zP///yH5BAEAABAALAAAAABZAg8CAAj/ AFEIHEiwoMGD
CBMqXMiwocOHECNKnEhx4r+LGDNq3Mixo8ePIEOKHEmypMmTKFOqXMmypcuX KlH88zezJs2b
NnPi3KmzJ8+fPoMCHSq0KNGjRpMiXaq0KVOaMmFKnUq1qtWrWLNq3YoSxVOn YL+KDUt2rNmy
aM8ejcq1rdu3cOPKnctVptq0eO/qzct3r1+wbOkKHky4sOHDL732Xfy3MePH jiPrDIy4suXL
mDNntQu5s+TPnkOD5klZs+nTqFOjVkxatOvRr2PDHlpate3buHNr5byTtezf s4ELv1tbt/Hj
yJN/jNqa50XnPZ/nlI6Tek3rNLFjhM59evTv3auD//ce/vp48eWznzeffntx 5fDjy1/tM0Xw
+8Pz4yc+v7///5X5hhNv+hW4n4HAvQfgggw2OBWBN9mH4IEUTiicgg5mqOGG IQlYE4QWVihi
iIxhyOGJKGoIoj8SjugiiS9KZmKKNNY4n4dQwahjjDsaNaONQAaZ24o49sjj kUZ+KOSSTCLH
XE4gaifleuq1N6WVVG5H3pboccmel1WCqWWXZH5ZZpjo/djkmmwStmKLSSIp Z5JqtmnnnW0V
uWKcfM5JYZ14Birog30W6qeOgA6q6KJdHeqooUYmyuiklHq056OYQlqhpJV2 2mmRmYaqqWyc
emrqopeOKuqqnZV66qt4Pv/pzzSpUJMKrbbiemutu+bKq67A/iqsr8T2amyw xSJ77LDLJsus
stA+K62z1DZrbbTVYtvsc67C6u2aBH5bY47ilvspq+iq+lq35raLYqrpxqvu Wey6a2+GoM6r
r7xP1XvvvwDCu+/A/PbkL8AIy5dvwQwT7NPBCUfspMMNV5wUxBJnjJus7MXy RyF/GPJxyB9v
MaaZKKOZ8skqt8zyy1eKGfOZMGc588o3u8ytxjyfmKrJYXS0hcVE84lxz0hn tnAhsRhCTTWx
QA01LCYXbfWORyetNWI/xxKGNrDEInbYhQxNsU72oIADUMsIJAZs8KBww8BZ b233YAsb0vTT
Ucf/sk0sVPflDxwDzZ32QIb4M3jhPi0ukOEEJe643P8cLpAhac99U9yG9ENJ DP94rsI2/liO
AuhAiU56T22LkbYPPGVeU+s6Da6CNgbWfffucXUdBjWxZBRL2X4NngIsNcWt +Uz9wJECI0IZ
jzxNytvU/PPJU35T5j/dw8Tazatgyz/V28PE6D+FPz5R1e+U9tpFhb/6iLrz bn9dRzHNCPCF
GHLKMqdgxilyAgqCxOIehHsc7nhCu5u8AwWJmx0KxFCUBs7kgRGkiQX9gUGc xO0FhLuBNtLG
gwSqQAoDUYE0UAC7f9DOcjD4BzFSmA0mDISCmXufP5SBONlRj3IFdBsP/wVy u5rM0G3kG0gM
+mFDgaAuLfW7nxSv4juwAW4Z1fhHNe4Ripo8cG4FNIT3YqCNB75NJzNsBE4e eEN/pPEob/Qi
Qd4Wxx+2MW1kTOMXx6gN243vizN5n/koaEY/2sQfdjhe5pTXuu3JzZE4sOD1 5udCFASNJg+E
wTb6MQppMEGTbbskWqI4xVJKhWNV0pvT/laNAcICFtO4xwB3iIJY0PKAcACd D3MyQ+jhxHMD
8UEax9NLLQFTIMJEgS8xckwWyq6Xr0Mg6FRXOhbSZJEF8QE1KymQFNwihyxs GxJ3iU2B+BIO
RcwOGyF4y5sw8QbbeB3NrkRKU9qTJb4DHuBOsf8NLf5jG6igSRj/EUbviVCH OilkT8wHg7Zl
0CcKjR0cGjpBoDBUh2lUnkG1ob4kas6MoTwkOscXUlA8733Vi9vjEFrNtVkO B/JzX+EGes1P
ehQv9bynTk+ytL1JbYCqgIUh/tFFDrKTh7gEXTF54jlv/uR1Tb0FUaL6VBZS FW3OBKIyo5nL
0FECffJ85whRkE6voo+HiTPpN+XGUib6gJza+wcCb2BIC841c30chViRqpec 7vSvIqli2GKB
Cmr8w7DUCAVN+qGJyDGRcalLoNqC6LbFSpauPWneQHBA2YqG7rKdfRtGUdCI LzKRjNxUwSkI
glp/eO+Gqa0F4VIgBUX/yo2RShzrQGCwwkjulnRsVO0ExYkCTVbTiZ7c7F78 CtjmdiRvTetb
Nabxj1cOtag2Qao0z3a1oYi1L8x1rngxkqoqUA0WhUDvNLJo2GqIgicFZYII ZzK5bko1LPVF
gVO5mx+GLia84xXvwlSxhT9sYQtV2EIfRNEHVCy4D/zt7oQAHODmCkzCGKZT hTe8mZzVDEsg
lpnNRhzieZJYxCXG2YnTxOEWVyVVhiibgWW8hbKZLcM4vpCLdwyTpf1jqByp WoSH7CIK87iU
ghUb4IZ3YyI7+UBGPrIUoes0qfkNcELGsTxZd7kc91XKYO5KUbbgNX0Olsl/ 0ezjjiuQoKlZ
/23psyEFq5mCRUhWgW+em0rd1r6ZOLR5MYxpEhEnaKaik5Lsi+sGmTfSAkU5 zLvr6f6ChxEs
8+Wq1WzhYimxX6Ag8AV/6OMm+LDfBkqvJrvMdJzXZshUG/InrzbKlqf6VUQn CNK4DuyYvQY2
Q4RhGaEA9jJ2csTLvVYgxtVJIyU45wt6digG5UMj7LGFRE5v2SG9ybIxiYIX 2JCMabNBAmmb
wtWeUaApnEYTLUnQFK6Qrm8sthgA+UMw3rDY4qsJZYO2Zxg8Ftm2/sqjc601 VG5HldRg5QAv
Ig1mPEee2u3qommy1EDOUYakHY807XEDZTBCrRqc4EyQKh3TJQ6vSP/N3DtJ h07cmVxxhz6k
JlRgy5ZXjnK9fCD0LN7Cm/uAdhfZ5kUsiMeZ3EriItcZeAZOcKTlc2zLOGwh 7sEMZqB7qPE9
KJzRSNqdTO4GdfTJabUBChhoQxPYM+oZaVqTN+OgemEUpE0F7XZBE9ebMR1t I4jL77gqb52S
a7S221jHjbKULExvOs96WuWoDbCfFynqDG0ZcV3GFScTZ558M4+T7d4E5JWc M+c8nUuI11Ll
8u2j4GsiTdvhjnbEOF6rcQ7Bm6/UmhZ3aTC36UhkVny7qQ5L4hWfsSTH4hTV gIUqVNHKkFMw
jGMPuzudt8w1PtJ50/MJH+lrbT979nq2xCr/DgAZd7Z+cpPOQ7TK0+/GiqI9 FpOsZh67PhPv
jd/vcTUfXRtNdPni1R+iUEPzp0ajRHwG+A9UxjfV0EX91E9F5Q+NNRC4FExD 8XVDhEQwB1k5
4XkzAXqSRAnBVGzsZHqxgHrzJU4qwAeRE3JklQ0gSFsqgDwoSHYEwQjrpHVK 9DrEhToqpQKo
AEE7aHGPMw2SpWllMXwHiDC+o2SwVA3UUAjMF1AEBEEb9WQRVoXLlYSKtzBb sAiFwAjoBUv+
1E8QRmy1xIHN1E3Z9xVpqF9raIWwgUAx5BdIqIX3kioGlmB6yGB98GB94GVw 6Bp1aIfuYnAe
dogrpmIppnSL+GEo//aIJtaIiOgPg0iI5nJhgQiI9GOJuLYwNqEKqQCKqqCJ mbgunAhpFwaF
ykcNoEiKrhgalXiK3uKJ0zANUBiKUKgK09AMpfiKkRGLsvgq8EJdGJEPGTEN rGIPVbBAvWgh
wBiMpuKJqeARvEgT9xBqNzdUatEPVMAY/VAFw/GNzfgTzwiNn2IUxGiMF6GO yFh/VBBPTVB9
FkJtzIgfyliP44iA5shjhlgTvNgR03gR1zgNcYA8/8BGTnU4oCNO8PRY3lR0 CERWHAWO/vCN
32gKKpANVWAK5pRasCCODMmM1wgKt4OQt3APfmAHAnFAKbmSFWlDozOStxNE zTaJkKiIN//J
iORRjvs4KcOYRRcBlFrUDDdxD1MQj2hzA/fgBKRjDK7gBOMjCtogB6TDjfH0 B9kAB0O1DDdg
D9hIbZ40VOYzVPDQWuSDA8ooDXIQlfPDRAS4PUrZBFJlDxnZBLZEl1mpRlzp lte0jPk4ID3p
YtLoEdNojXGACvP1ko/jgujjenIlWbdjkRTZD06gkcxTBeJYkZMJjhF5Ot/o mP6gUlqAjYop
N9OAjf1QCa+AmpawmrhzD3Lgmpf5lzbBk4GpKPCSClm0m/5UDangTu+4DGtz D3LpWu9YkY12
PdPQjTiRllvgck7gCn6ZltP5nJVTBdLQBMhDnbgTf+5Yf8V5D1T/YJWKEwev wJz9YJ7H2Q9N
sJyrQ4+0SS63WWGD2YBj+A+FKVehBoFihI1cOQ2j6A+b8AraKAqvQAnV95lw YEvvcAOUSTpl
mZkSipkUGaGYWaDZd42v6Z83cJou16FfeQMuCD3L4AMayjxM6YuTMZ8blpu8 +aK/+Z3IKQZB
5AdUkJVuo2Y41ESaRI+vhT5sNJrSMJ1Eqg1HJKRVgKNJxzzH2W4ooAVUoG5E ZAv/lm/mQ1ZU
2qTt91AqapssGitIMY399KL46Rn2MIcIcqLXRJrx6RRe+qV2kptQ+AepMKd1 OoqPAX5HIp7z
w6cqyh9wKmA2GYk56YiEeqg4iag6qaiG/5qojsqIbxqo4NKmf6pjkmphlZqp wxGpl7okMDZj
BVZjodpkmlqqRcGpnRokefNjQkOprroWqfpXT7dkYkM8r3qrrRGrOiVp+mRl gXMfmYmrhoKq
ukojSRY2ZEOqOuGneAGfpiovxFqs73IlCAd5F2Fpg5qo4piti/qojdqt4Pqt 4sqt7iGt9vR0
viZswVaUVKCCjNBYYtSNIek4b8lNZOQ4NzCk+PishRKt5rohjKeAC/cP0jBs clWQ9vCQIDoN
coA7xnB24dd5a/kPD6sJtiSZwoou/vqv+LJrXzNYWKR8VHcKFfmO9yie3JiV VmqdXpecE8ud
GduvHDtFCSg1Xf+UEQOkoeI4kKj5VZaZOl81lVVJoTG7Khs7swwyq7CAfE/I fCQrntfJUVE6
noUwE6GwCJqgjZUDlfcwVP2wCbAACmL5B/patEaDtPfDq2LTSvcJYToLjl55 mi6IRJ3JCA96
TDiUQEtEkWaLKUeLtv+xhMg6DdSgfKqQWLBxj317toAbaVcCCIzwhbAAhtRl n9jFqFcSrOS6
uYkYrpwriZ1bro17N3iIYKZbBQzGYH6wYPzaulAyuqTrurILXrBrN5g4u7hr MLW7NQvjMSDz
uyRTNov7rH+7u8rxM/8QNEGWu65bvMbrJPkTC5MmXZbGvK/qvM9rHMe6ZLZa McwqU7X/Z71E
gb3ZOyTUujesdGWBk62WMzedOWeW4wPa0b6PiYHxW5qMoKb6STpxIFXb+m+J E6zVIcAsE6wn
Kh0HHLqfi2LkW7638XTC071ksQz55g/GUAtxAD39AAj+QMGrIwq2RsHrc8EF GToc/A7o8w9S
2b8V+QfkmRP2AJVR6w9xYEv+8AeVw6bN6ZdE4ZX7aj1aOioN7MCqEbDVYAiM 8D8BNEv0lUAd
2pK19BOisIb+QJU3IaD3NRShQMVWTF+bkMWhYwnro59BdEBYCYLFFURhYAn1 SJMm6Q9BNJob
WkZOZMChxkYxAIFdJkFyo3oCkQpUEETyKCJDTMT0QRRk9rFi/4NFWjQND2gH asSN01CcdIlo
S4loMwQ/MTzG6dMEmPxIW8vJ7aY53qNGZ5oNJmudiltAy6O4cFk5z+mnKOvJ FiydCySe2UDL
xmAL3xvKRHV2BGgPSAkPFexohiwxNet41QVLshTGG+qhoVMJb6i/zSk3BMwT 1Ixq1sy3MmWi
2MizEzmbjgQ7EtpEIrSz33zG6GPHjLk61OyYapqZNAzGhHzMEaO0/DSGJNsP Voyyx0nDEUtf
NZw6coDBb7gT6UnPbVfQGSx2coDKVTm1UTvRV0yVPhqe3XiP5EmetuMKLMvR I/XCv4ROEN2X
3VnCL1LI9qw00Tu9bGtdRNWB0HON0v8QovtKzKtjDNlQNdzoQhW8ywmVwgHI 0+BIwQvEDNPA
wfpZ088cahLKlPYQQTrLlCfKlRxF1Q3rQh0aoAPKnPoJoIrzxbDpcg3bD9q4 xaDgS5lpD09U
ZCuthB5rRbBQWId1WIpVOTwqpVgKUZvFWN0UfsS1PDsR2HD81yz4SCqpX/l7 nP4cTzw8Q2EQ
gcczEzNEowIBpaRT2eIEpdqQQK7TRCmwnI6zdpZ0yWoWNFeKAoTQRCmc0m8N MP3oD6p0ZdO1
zNe1gX8AzZirwLwNur4Nidva24W6M699h0VhXlsQuerFXlr0XjbR2NNHEGnn FPU12a7rys5Y
3Hd4FARmYAf/9gcP5mAONrzxqdLafRi3S96za97nXRieKL7Dy97tjTdFEWOh SmM2Bt+mKt/z
TRc+tnMbkWXqPY783d9ysb3Jqt9tWuAGDhexXa198zfrK9y7bY3YaB2HE9Ce S+HeusAVzsAN
/i1Kq2QSbBYvVZoRtGeCjWqeLdJQm57buYwvjN0mPeBAweAhnifRW2XC86tl gdM08bAsfMM+
vT7MgI+piTz9QArZXJEpis4/7E7cbOO1meOwIljpGmzr2nYJBAPLqYLhe0hf /EsTexOhMMiH
FAd9GsiXk7JdntiYfU3PKU5mF4HnZq9+jAKFMAWJrbX7beXCeBQI91MY0XCf N9O5/13CdImP
Y81L2vOgR8FDLYRA0MNxHjqh+rlAFpmiR07AjV6x4Qeb21lWpYrjgN5hiFxm YzNAT0h1w8bP
pAPdAI3QQQxJNB4UyrPREq24Gt2kyqiy78nDTWylPAy1FcnCrmrqp05FLd2r j4cRXdQPYrzU
rPmG0n7Q9NWwyI4U0i6bcevUm5np4uxH12xWPyvuSX69y+4px4p8htt8iBTJ U0s6Z8o6P+3R
Jr0MKbA6oYBo/VA14rmc7uie8LnJxn6d0iA5d1CCMmzwXgu2YuuO9J5sf77u lfLg6Bs1DPhP
MV2aHWpCq2MdhB2BNDcTeya/OhFE3nSi4BzcM6QFJqSRjv+zc5V9t2hMQZ1Z CCDv4R3O4RtO
iRZ/8R7LhOvVtNUghewq0nB48M0b9JTChYUguZTbtrit214l3QrN7WhsX0jS 5JSq7E7fY0WR
h6fLh36o4JUK9mHvEu9N5bKr9muPT25P5XAf9zFxFLAwMsD7uwKO9r1Y93Yv ZoicvELj92kf
+IKC8asU4djq8+Pq+Dz/88MN+SQG+IhfEiNeq8pq+IFo+Zc/EkZMvT5uFgAc gTcEwEMBCm0d
FBFJ6qwP8kzRma0t7pr5+kRESZ0ZxX3i+Z/fIXFtkNda4k6R0C0s8cfuvzic PlNwB9geO8J+
FMZ+pgG3rMdZ78AZ7FFOntLPrvX/xwT1+ii83/vLIeg+ZQj+wwzLAEAiNYRQ rOHOjNvdycYV
ZAjEEEEMOQ3tX/soqZIfF8X/BqIAoe1fP0vT/oBSoc0fHBQoYi1reMOgQIIG EU78569flX8Q
UUg8qAJjxZAYNXL0qAKWP02x/PmLc8tfxo4RFTJEkYoKqIaMaM4E+lNoUKIZ UfxDmlTpUqZN
nT6FGlXqVKpVrV7FmlXrVq5dvX4Fu/Vo0aBbYoWhFisWrFNIq00LlZFlI3/3 qPRr4tKeim1F
ed742Y9K339/h9LstwmWPRjb7Mmx9U9Utrz+9jreou1ek1vwUiyGkQ0OXbuC +76DMY0J3bkz
7TmJPHmw/z/UqklToWnvjzTYkm3Xxe1vGYx+qzXOHgiZJjwclgHDuxH0dWxt duj+s9cE1j94
KiKTPQw+6NGw5c2fR59e/Xr27d1nRSE+Y6FYjNLGqtYWFqxp0toSjOye3f6g yJLtyLIHBR9m
ElAgoBJccKiNBqpkJTgSwo7AgQwU7J8GJ9QNIwGlwSkGDzVsUK4LBboHJxhO ZFHDkxbyDkYP
S7RRNwf9kcMxHAFUxiegaIzRwQlfikk+JYci7z0nn4QySimnpPK9scL7x6ww tIFlrVOq+QfM
/JDsS7BpZusnyfD66RE4CdsUyqOGxJipHzhSOLPMmOypQrPB7MnMLmkaOy5P oP9MA46wOu88
8ye7ykSOT4ouNBTRjOy6NNItpNEOuz4LWwTOoOzEMzhPKYpDSCyXHK9KV1+F NVZZZzWPvKKQ
8seQWAyhZhv84trPkH/a8gcUnwTEyJ4bBMLVQ0MYRBHFZ21stlifsIuhH2H9 EeUVDZXVZsIP
ORIwGwNPNOnEbTIyNiNtM+pWQ6RSJCiWjKB7159QvI1xXWiLHIgSRo6Ex0SN mJj2HjnC3VYU
WNodiCPLTKyWpopnujgpf5qktWOPPwY55PauBE/L+2BBBUxqwkTFNSYaIu5l FGokyh87GvrM
3dlYwlnVQ5FL8xWcxCiuIe/ueVkk3CQ1DZ6GUCAOOTf/XW6okKEtnRo7FwfC KQxMsz6uTJlT
EJKYhrTILKNQDuzHiW3snBM7mQmRmS9WVxWKY5H35rtvv/2Ob1X6dK0Gv2n+ UQUWYfsQClkZ
8b47cppSlNy1CCuHPHPMxbPHYM2P1Dz0jf8mvXTTT4+S5MOqYGQLWAphpJBp VqY9FKLMNPUl
nHA+UPOFnkYhZ/G+Dp2nmb8TPfnNkwflursBdVB5vPVGvXrrr8deqsDFU2UL 7//wvg9UxCdf
+uXPNz999NdXv30lqc8+fvnn/1t19u93P3/899e/f8zhp18ABThAV23Pfwfk XwIRuEAFbg6A
BIRgBCV4HvsJxRDgK8QWwLdB/+81kIEf9GAIQYilB07QhCdE4VRsJRRcCUtY TdmCxlh4mIzV
kIY3vBUOZ5hDHu7Qh0GxYQ+BqMMhCtFiRDyiETFmlBQ20YlPZEoFy3KWk6kl FhkUYRZHqEUu
9q+EUARjGOdnQLIMjhqFQ+NaYthFNh6GckJJkEPaOEf3fVGMd8Sj6aRIEy1x yYpdwmL67CGz
MBjvaWIYZNyIgrSnqSAbUvtJHD9ysDnNxGkRkVtDvCY106TJJ9DbYigVaMc8 ltKUICPjUHTF
KzAlRY3p60eFBqKKf1FoO/2gZeMeJ57uEMYY2kiSP/7QEQz5gxnmuqUq3ngo t51ElM/cHylP
OU1qFv8QbybbVRiWcYplhGIZo3KRYG6Ggm39hEeK0llfzikerJVmJw151iZk ghjlACUUPmOT
ogRjPEPY5XcosME4pzUTjywLbigoBBX4AE9oNnQm0qxmRCXqnlQShT72UUt+ kiKNb7LrWLuJ
w3b2Ej2gKAMFzZmcjEyK0qK0qJEGmQYcfAKdadSTJmYDjEaa+ROzRahFMwVJ uCQGOtcsTDLa
aAmDQoodmjlUlBCdaFSlGpY9zqSPXYLFMqoBC2Uy4xRkKhSa1FSUd3wkU0Ip a04dlTu7NAo4
hhpKgnAgqcM47QZfa+uf0kbXQ10oMqBMFJJc4tQuQnWqh0XsVVZYxFX26lf/ S/mPJWI0Ellm
jCAAa9ZlZZiief1BRH9AZhLlsrCxHpEkkyXQhCI2w35QwpEc6WyB7KVEGRbx h6K1bW5xu9sl
ji6xvwVuV6qaJSqqhS3VoEYhVFGNlrXGnX1hDDo1skZEVZe6kAwbUJ4btmXQ zBiu4IJr+vQO
u/lmjdvF3amw05vp9KMQaluEJrb1NcYQ9pmGDW5+g1vRn5gRjW0B07riQsmP xNRo0mUXzuZJ
OeOlYJ5BeaPjACan6GjCaAe6pIKKpeAUSRh0ZiOa21obN5ciFCflpSMb8atf Fh92uFpai1pm
x1VVUMN2gaGCW+2b4s9hd8cjXHGLhSxR/gIFELFj/wQskny4dQlYl+ka8dMc LLkoK5jH7Fvm
j7MY5CF3+ZTDzWAVtiDmKvihD6I485mvrGU2r/luXPZynO9Y5DbX2c12Vh6c 5bznJw73zn/G
M6Alp2c+F/qEi01iLP5QiD9ckNGOjmEQb9vbSdeWt5amtG4zfWlJaxrTn+40 p5G4aVKDmomG
RnU1X/yPMDhlC4IOdKx5TOhU1zqAdPaHf/Gza1isUda/hjUXaW1rYmfvxWfx o3Gv+Gpg6+9R
CGJosOs87GJXG3W4bmwafdVr9RWNnBYGHtFkNtDJ7U4ku8zN0wBTYjFkRJIL 8nY/H9cgmMiE
qM2eI7Wtve/6XbO4Sln2+f9g4hJhplOwLxnm7XxclO5+xxi1WGo//kCb8k4m SRLHWm7Y+ylp
31nf/Aa5yHB90bQUwhDcPIVXzYmTG0jDD+Mc7Kgkq8sCkZTmKbVIQ1yyNnOK yh/ylDnyBGS8
WJSLEjAzXruBUlYUmCjKhXi5zjvuv4+H3OodO/aWsKrVMN1jwDaji5kqcxm/ mFW7pjIMWRhp
tDP9hjHTaIJ0ceqa3gQl7Uijy9v1KhC+XqqZxrAFKOY79hQgeOrLq/rVFQ8r RPe2sb7S6H6m
cY/IopYilY2rhqnlbs03i7Poila6mpWgG9wbYxDqsGdTC9t7t9ZuqrVRvUZt atqGutS211ji
F7//+yll/WSnWFeAm9um7Q5cPOvM+EtEZfBMVZcKwHywUNgE8d7VTA6PhFSj 6Nr3IV3IFRz/
Wpqif/j06Z7353fSyHd1Rvy0JXHCGrDgQS8Q6Nj8HgmLFovwb/95q75I5PWl bKAulCgmZpgG
/PusiTiStikTt7kHWvo5W0iqHFkWfFMf80O/DFyPrEs2VKCdf7AxqoEa1TAa 5BkScBOeZ+OZ
4Km+TNGnHJuNr6GwDQueeZrBcSKbZ3suvgKx9hoaAiuEujFBC/wfDTRCwFGS Vdq1t/iHYPmH
AcM5dCO/NsqyKbzAI8RCkcObKui113mdaVCZMBGFRboLTtqd4PEZyDmo/54h wqEgHitkHwzM
wjkUCyXpHvAZsy1Is/FBszaEQz/UHDmkw0G0Cj8DxD9ExPwRREJkxKhoPNqr NNyTxNmbxNqj
xEu0xEyMREzcRN9qxE+EEkNMxFE8ROlZRFBERaTAtVIkxVYUnVNMRVAURVak RVcED1iMxUZc
RVusxV4kClzMRUKcRV4kxl4ExmCkw130xWW0xWNExiwcRmaUxj90xmc8wkes xE7URk/LRm7k
RG/URHDcRlELxySqRmvUwGgsxnUExHNER/RTRnaURz90x3fkPXWcxnycunq0 x8UDnn8EyIAU
yIEkyII0yINEyIRUyIVkyIZ0yIcEnn6UyImkyP+KtMiLxMiM1MiN5MiO9MiP BMmQFMmRJMmS
NMmTRMmUVMmVZMmWdMmXhMmYlMmZpMmatMmbxMmc1Mmd5Mme9MmfBMqgFMqh JMqiNMqjRMqk
VMqlZMqmdMqnhMqolMqppMqqtMqrxMqs1Mqt5Mqu9MqvBMuwFMuxJMuyNMuz RMu0VMu1ZMu2
dMu3hMu4lMu5pMu6tMu7xMu81Mu95Mu+9Mu/BMzAFMzBJMzCNMzDRMzEVMzF ZMzGdMzHhMzI
lMzJpMzKtMzLxMzM1MzN5MzO9MzPBM3QFM3RJM3SNM3TRM3UVM3VZM3WdM3X hM3YlM3ZpM3a
tM3bxM3c1M3d5M3e9M3/3wTO4BTO4STO4jTO40TO5FTO5WTO5nTO54TO6JTO 6aTO6rTO68TO
7NTO7eTO7vTO7wTP8BTP8STP8jTP80TP9FTP9WTP9nTP94TP+JTP+aTP+rTP +8TP/NTP/eTP
/vTP/wTQABXQASXQAjXQA0XQBFXQBWXQBnXQB4XQCJXQCaXQCrXQC8XQDNXQ DeXQDvXQDwXR
EBXRESXREjXRE0XRFFXRFWXRFnXRF4XRGJXRGaXRGrXRG8XRHNXRHeXRHvXR HwXSIBXSISXS
IjXSI0XSJFXSJWXSJnXSJ4XSKJXSKaXSKrXSK8XSLNXSLeXSLvXSLwXTMBXT MSXTMjXTM0XT
yzRV0zVl0zZ10zeF0ziV0zml0zq10zvF0zzV0z3l0z710z8F1EAV1EEl1EI1 1ENF1ERV1EVl
1EZ11EeF1EiV1Eml1Eq11EvF1EzV1E3l1E711E8F1VAV1VEl1VI11VNF1VRV 1VVl1VZ11VeF
1ViV1Vml1Vq11VvF1VzV1V3l1V711V8F1mAV1mEl1mI11mNF1mRV1mVl1mZ1 1meF1miV1mml
1mq11mvF1mzV1m3l1m711m8F13AV13El13I113NF13RV13Vl13Zty4AAADs=
--------------010702000102000302090004--
FUDForum. Page generated in 0.15113 seconds
