Can't launch simple SWT app... [message #63690] |
Fri, 01 October 2004 04:38  |
Originally posted by: spam.scientifik.com
I just installed VE, I'm using WinXP. I'm simply trying to launch a very
basic SWT app and I get this error:
java.lang.NoClassDefFoundError:
Files\eclipse-3/1M2\plugins\org/eclipse/swt/win32_3/1/0\os\w in32\x86
Exception in thread "main"
...here is string arguement I'm passing to the VM:
-Djava.library.path=C:\Program
Files\eclipse-3.1M2\plugins\org.eclipse.swt.win32_3.1.0\os\w in32\x86
...this path is absolutely correct, I copied it right out of Win Explorer
rather than typing it in manually.
Here's the code (generated by VE)
import org.eclipse.swt.SWT;
import org.eclipse.swt.widgets.Combo;
* Created on Oct 1, 2004
* TODO To change the template for this generated file go to
* Window - Preferences - Java - Code Style - Code Templates
* @author vjenks
* TODO To change the template for this generated type comment go to
public class SWTMain {
private org.eclipse.swt.widgets.Shell sShell = null; //
@jve:decl-index=0:visual-constraint="128,49"
private Combo combo = null;
* This method initializes combo
private void createCombo() {
combo = new Combo(sShell, SWT.NONE);
combo.setBounds(new org.eclipse.swt.graphics.Rectangle(155,43,232,21));
/* Before this is run, be sure to set up the following in the launch
configuration
* (Arguments->VM Arguments) for the correct SWT library path.
* The following is a windows example:
-Djava.library.path=" installation_directory\plugins\org.eclipse.swt.win32_3.0.0\o s\win32\x86 "
org.eclipse.swt.widgets.Display display =
org.eclipse.swt.widgets.Display.getDefault();
SWTMain thisClass = new SWTMain();
thisClass.createSShell() ;
thisClass.sShell.open();
while (!thisClass.sShell.isDisposed()) {
if (!display.readAndDispatch()) display.sleep ();
display.dispose();
* This method initializes sShell
private void createSShell() {
sShell = new org.eclipse.swt.widgets.Shell();
createCombo();
sShell.setSize(new org.eclipse.swt.graphics.Point(398,267));
sShell.setText("SWT is wicked cool!");
Can anyone help? I can run SWT apps built in VE all day long on linux/gtk
but I can't get it to work in windows regardless of what version of
eclipse I use (have tried 3.0.1 and now 3.1M2)...
Thanks!
Re: Can't launch simple SWT app... [message #63715 is a reply to message #63690] |
Fri, 01 October 2004 04:48   |
Allow me to answer that 5 minutes later - it was the space in "Program
Files" that was breaking it.
I moved my eclipse IDE directory to the C:\ drive and ran it there (no
spaces in VM arguements) and it ran fine.
Seems like a silly limitation? Is there a way around this (ability to
have spaces in diretory structure?)
Thanks!
> Fileseclipse-3/1M2pluginsorg/eclipse/swt/win32_3/1/0oswin32x 86
> -Djava.library.path=C:Program
> Fileseclipse-3.1M2pluginsorg.eclipse.swt.win32_3.1.0oswin32x 86
> * @author vjenks
> public static void main(String[] args) {
> configuration
-Djava.library.path=" installation_directorypluginsorg.eclipse.swt.win32_3.0.0oswi n32x86 "
> display.dispose();
> createCombo();
> Thanks!
Re: Can't launch simple SWT app... [message #63760 is a reply to message #63715] |
Fri, 01 October 2004 07:34  |
> Thanks!
> V. Jenks wrote:
Try putting double quotes around the path if it has spaces. ie:
-Djava.library.path="C:\Program Files\eclipse\..."
- Jeff
Re: Can't launch simple SWT app... [message #600360 is a reply to message #63690] |
Thanks!
> * @author vjenks
> configuration
> display.dispose();
> createCombo();
> Thanks!
Re: Can't launch simple SWT app... [message #600379 is a reply to message #63715] |
> Thanks!
- Jeff
FUDForum. Page generated in 0.03846 seconds
