Teneo: problems with HibernatePersistableEList.equal(Object) [message #63684] |
Tue, 05 December 2006 02:57  |
Hi all.
When I have some feature in my model which is unordered list it's mapped
as <bag> so in runtime I have HibernatePersistableEList which delegates
to hibernate PersistentBag class. The problem is that PersistantBag
equals() method is:
* Bag does not respect the collection API and do an
* JVM instance comparison to do the equals.
* The semantic is broken not to have to initialize a
* collection for a simple equals() operation.
* @see java.lang.Object#equals(java.lang.Object)
public boolean equals(Object obj) {
return super.equals(obj);
So when I try to compare two features which are
HibernatePersistableLists in runtime I get annoying result.
More: HibernatePersistableList delegating to PersistentBag is not equal
to itself. Why? Cause HibernatePersistableList extends DelegatingEList
that has:
public boolean equals(Object object)
return delegateEquals(object);
protected boolean delegateEquals(Object object)
return delegateList().equals(object);
Imagine that you have HibernatePersistableList myList.
myList.equals(myList) return always false cause calling to equals
results in comparison
persistentBagDelegate.equals(myList).
BUT HERE IS INSTANCE COMPARISON - SO IT RETURNS FALSE.
Is there any simple workaround or can Teneo implements correct equals()
method in PersistableLists?
Thanks in advance
Re: Teneo: problems with HibernatePersistableEList.equal(Object) [message #63800 is a reply to message #63753] |
Tue, 05 December 2006 09:05  |
I have created issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=166778
Will wait for fix
Martin Taal wrote:
> Hi Ilya,
> As the hibernate remark says it can make sense to do jvm instance
> comparison for the HibernatePersistableEList (because of lazy loading
> etc.).
> Can you enter a bugzilla for this change (it means that this change is
> visible in the release notes later)?
> gr. Martin
> Ilya Klyuchnikov wrote:
>> Hi all.
>> mapped as <bag> so in runtime I have HibernatePersistableEList which
>> delegates to hibernate PersistentBag class. The problem is that
>> PersistantBag equals() method is:
>> equal to itself. Why? Cause HibernatePersistableList extends
>> DelegatingEList that has:
>> equals() method in PersistableLists?
>> Thanks in advance
Re: Teneo: problems with HibernatePersistableEList.equal(Object) [message #596530 is a reply to message #63684] |
Tue, 05 December 2006 07:11  |
Hi Ilya,
As the hibernate remark says it can make sense to do jvm instance comparison for the
HibernatePersistableEList (because of lazy loading etc.).
Can you enter a bugzilla for this change (it means that this change is visible in the release notes
later)?
gr. Martin
> Hi all.
> equals() method is:
> that has:
> Thanks in advance
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo: problems with HibernatePersistableEList.equal(Object) [message #596550 is a reply to message #63753] |
Will wait for fix
Martin Taal wrote:
> Hi Ilya,
> etc.).
> gr. Martin
>> Hi all.
>> Thanks in advance
FUDForum. Page generated in 0.04050 seconds
