Home » Eclipse Projects » Nebula » CDateTime display change?
CDateTime display change? [message #63564] Fri, 15 May 2009 21:12 Go to next message
Has the CDateTime drop-down graphical display changed? We have an older
version in use where the drop-down is set to show both a calendar (left)
and an analog clock (right) at the same time. The new screenshots seem to
indicate only either the calendar or analog clock with a button to switch
between the two.
We are interested in upgrading to get bugfixes but such a change may
impede that.
Craig Foote
Re: CDateTime display change? [message #63586 is a reply to message #63564] Mon, 18 May 2009 09:30 Go to previous messageGo to next message
this is now fixed in HEAD: Bug 276699
> between the two.
> impede that.
> Craig Foote
Re: CDateTime display change? [message #63609 is a reply to message #63586] Mon, 18 May 2009 18:37 Go to previous messageGo to next message
Thanks Jeremy. That's great news. Is the 'Latest nightly build' on the
nebula downloads page kept up to date, i.e. updated every day?
Craig
>> (left) and an analog clock (right) at the same time. The new
>> screenshots seem to indicate only either the calendar or analog clock
>> with a button to switch between the two.
>> impede that.
>> Thanks,
>> Craig Foote
Re: CDateTime display change? [message #63655 is a reply to message #63609] Tue, 19 May 2009 08:29 Go to previous messageGo to next message
It is (updated everyday)
Just wait 1 full day after the fix is committed before downloading the
file just to be sure the change is included.
If for some reason you think that the file is not updated, let us know
because we don't get alert on failure yet.
Nicolas
> Craig
>>> impede that.
>>> Thanks,
>>> Craig Foote
Re: CDateTime display change? [message #63677 is a reply to message #63655] Tue, 19 May 2009 19:21 Go to previous messageGo to next message
OK, I will, thanks Nicolas. Are you planning a release or milestone any
time soon? It'll be hard to convince the powers that be to go to prod
with a nightly trunk build :) (though I will be downloading and trying it
out in the meantime)
Craig
> file just to be sure the change is included. If for some reason you
> think that the file is not updated, let us know because we don't get
> Nicolas
>> Craig
>>>> older version in use where the drop-down is set to show both a
>>>> calendar (left) and an analog clock (right) at the same time. The new
>>>> impede that.
>>>> Thanks,
>>>> Craig Foote
Re: CDateTime display change? [message #63811 is a reply to message #63677] Fri, 29 May 2009 18:57 Go to previous message
Anyone?
> it out in the meantime)
> Craig
>> Nicolas
>>> Craig
>>>>> new screenshots seem to indicate only either the calendar or analog
>>>>> clock with a button to switch between the two.
>>>>> impede that.
>>>>> Thanks,
>>>>> Craig Foote
Re: CDateTime display change? [message #594757 is a reply to message #63564] Mon, 18 May 2009 09:30 Go to previous message
> between the two.
> impede that.
> Craig Foote
Re: CDateTime display change? [message #594762 is a reply to message #63586] Mon, 18 May 2009 18:37 Go to previous message
Craig
>> impede that.
>> Thanks,
>> Craig Foote
Re: CDateTime display change? [message #594782 is a reply to message #63609] Tue, 19 May 2009 08:29 Go to previous message
Nicolas
> Craig
>>> impede that.
>>> Thanks,
>>> Craig Foote
Re: CDateTime display change? [message #594792 is a reply to message #63655] Tue, 19 May 2009 19:21 Go to previous message
Craig
> Nicolas
>> Craig
>>>> impede that.
>>>> Thanks,
>>>> Craig Foote
Re: CDateTime display change? [message #594861 is a reply to message #63677] Fri, 29 May 2009 18:57 Go to previous message
Anyone?
> Craig
>> Nicolas
>>> Craig
>>>>> impede that.
>>>>> Thanks,
>>>>> Craig Foote
Previous Topic:CDateTime - DropDown
Next Topic:CDateTime Release schedule?
Current Time: Mon Sep 01 00:30:17 EDT 2025
Powered by FUDForum. Page generated in 0.04777 seconds
