Home » Eclipse Projects » Plugin Development Environment (PDE) » NewSearchUI EmptySearchView
NewSearchUI EmptySearchView [message #63548] Thu, 28 May 2009 04:08 Go to next message
I am using the NewSearchUI for a search in my application. In my
perspective I want to have two views (search and result) and the
corresponding editor.
Over the extension point 'perspectiveExtensions' I set the result view
'org.eclipse.search.ui.views.SearchView'. All okay - after a search the
result is shown correct.
I've done the implementation, all works BUT...
The Class SearchView.EmptySearchView displays the message "No search
results available. Start a search from the search dialog..." - How can I
change this message to display another message, also in another
language??? Other solution than to patch the original plugin or extend the
SearchView class?
Re: NewSearchUI EmptySearchView [message #64010 is a reply to message #63548] Wed, 03 June 2009 02:20 Go to previous messageGo to next message
Hello, no one has the same problem? Is this a special request to want to
customize an empty view in a desired language??????
Re: NewSearchUI EmptySearchView [message #64077 is a reply to message #63548] Thu, 04 June 2009 04:16 Go to previous message
For the moment I have a workaround...
When creating a fragment to the search plugin, I can provide a
SearchMessage_de.properties. With this solution I am able to show a simple
message in german.
But if I have to provide a message in English - how can i replace this
message from EmptySearchView? I don't want a Java Search in a business
application.
Is this a bug?
Re: NewSearchUI EmptySearchView [message #598082 is a reply to message #63548] Wed, 03 June 2009 02:20 Go to previous message
Re: NewSearchUI EmptySearchView [message #598096 is a reply to message #63548] Thu, 04 June 2009 04:16 Go to previous message
message in german.
application.
Is this a bug?
Previous Topic:customize the org.eclipse.ui.newWizard extension point
Next Topic:View dynamic toolbar drop down menu
Current Time: Thu Nov 20 17:50:13 EST 2025
Powered by FUDForum. Page generated in 0.03730 seconds
