Cannot open XML and DTD files [message #63461] |
Thu, 12 May 2005 08:31 |
Hi!
I have Eclipse 3.0.2 and VE 1.0.2.1 installed.
Now I tried to open .xml and .dtd files.
It did not work and I got some errors. I attached the .log file.
What can I do to fix this error?
Maja
Error Mai 12, 2005 10:16:10.681 Problems occurred when invoking code from
plug-in: "org.eclipse.core.runtime".
An error has occurred when initializing the input for the the editor's
source page. Original Error: org.eclipse.ui.PartInitException: Editor
could not be initialized.
org.eclipse.wst.xml.internal.ui.XMLMultiPageEditorPart.addSo urcePage(XMLMultiPageEditorPart.java:185)
org.eclipse.wst.xml.internal.ui.XMLMultiPageEditorPart.creat ePages(XMLMultiPageEditorPart.java:231)
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:187)
at org.eclipse.ui.internal.PartPane$2.run(PartPane.java:137)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:616)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
at org.eclipse.ui.internal.PartPane.createChildControl(PartPane .java:133)
at org.eclipse.ui.internal.PartPane.createControl(PartPane.java :205)
at org.eclipse.ui.internal.EditorManager$9.run(EditorManager.ja va:969)
org.eclipse.ui.internal.EditorManager.busyRestoreEditor(Edit orManager.java:933)
at org.eclipse.ui.internal.EditorManager$8.run(EditorManager.ja va:926)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.EditorManager.restoreEditor(EditorMa nager.java:922)
org.eclipse.ui.internal.EditorManager$Editor.getEditor(Edito rManager.java:1303)
org.eclipse.ui.internal.EditorManager$Editor.getPart(EditorM anager.java:1295)
at org.eclipse.ui.internal.EditorStack.setSelection(EditorStack .java:186)
org.eclipse.ui.internal.PartStack.presentationSelectionChang ed(PartStack.java:674)
at org.eclipse.ui.internal.PartStack.access$0(PartStack.java:66 0)
at org.eclipse.ui.internal.PartStack$1.selectPart(PartStack.jav a:94)
org.eclipse.ui.internal.presentations.DefaultPartPresentatio n.setSelection(DefaultPartPresentation.java:1408)
org.eclipse.ui.internal.presentations.DefaultPartPresentatio n$4.handleEvent(DefaultPartPresentation.java:166)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:820)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:805)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:6 13)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.ja va:3053)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:19 17)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.j ava:287)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2773)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2432)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
FUDForum. Page generated in 0.11783 seconds
