Home » Modeling » M2T (model-to-text transformation) » XPand workflow problem
XPand workflow problem [message #63354] Tue, 30 June 2009 09:52 Go to next message
Hi everyone,
I want to define an XPand template for a rule which is defined as follows
in XText:
import "http://q-impress.eu/samm/staticstructure" as refn_staticstructure
Entity returns refn_core::Entity:
(NamedEntity | Connector | EndPoint | HardwareDescriptor)
NamedEntity returns refn_core::NamedEntity:
ComponentType | Type
PrimitiveComponent returns refn_staticstructure::PrimitiveComponent:
'PrimitiveComponent' id=STRING ':' name=STRING '{'
//parent attrib(s)
'doc:' documentation=STRING';'
//class specific attributes
'reqd:' (required+=InterfacePort)* ';'
'prov:'(provided+=InterfacePort)* ';'
'operBehv:' (OperationBehaviour+=OperationBehaviour)* ';'
'compTypeBehv:' (componentTypeBehaviour=ComponentTypeBehaviour)? ';'
'sink:' (sink+=EventPort)* ';'
'source:' (source+=EventPort)* ';'
The rule refers to an existing external metamodel EClass.
Now, I've defined a concrete metamodel for this grammar as:
PrimitiveComponent "pr_01":"pr_a"{
doc:"csabcb,am";
reqd:;
prov:;
operBehv:;
compTypeBehv:;
sink:;
source:;
I want to run the XPand generator for the above model.
My Xpand template is as follows:
«IMPORT edifice»;
«EXTENSION templates::Extensions»
«DEFINE def_outer FOR NamedEntity»
«EXPAND def_inner FOREACH elems.typeSelect(PrimitiveComponent)»
«ENDDEFINE»
«DEFINE def_inner FOR PrimitiveComponent»
«FILE name+".edifice" »
PrimitiveComponent «id»: «name»{
doc: «documentation»;
«ENDFILE»
«ENDDEFINE»
XPand workflow is as follows:
<workflow>
<!--bean class="org.eclipse.emf.mwe.utils.StandaloneSetup"
platformUri=".."/-->
<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup" platformUri="..">
<registerGeneratedEPackage
value="eu.qimpress.samm.staticstructure.StaticstructurePackage "/>
value="eu.qimpress.samm.behaviour.BehaviourPackage"/>
value=" eu.qimpress.samm.deployment.targetenvironment.Targetenvironm entPackage "/>
value="eu.qimpress.samm.deployment.hardware.HardwarePackage "/>
value="eu.qimpress.samm.deployment.allocation.AllocationPackage "/>
value="eu.qimpress.samm.datatypes.DatatypesPackage"/>
value="eu.qimpress.samm.annotation.AnnotationPackage"/>
value="eu.qimpress.samm.usagemodel.UsagemodelPackage"/>
</bean>
<component class="org.eclipse.emf.mwe.utils.DirectoryCleaner"
directory="src-gen"/>
<component class="org.eclipse.xtext.MweReader"
uri="classpath:/model/MyModel.edifice">
<!-- this class will be generated by the xtext generator -->
<register class="org.xtext.samm.EdificeStandaloneSetup"/>
</component>
<component class="org.eclipse.xpand2.Generator">
<metaModel
class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel "/>
<expand value="templates::Template::def_outer FOR NamedEntity"/>
<genPath value="src-gen"/>
</component>
</workflow>
But the workflow shows the following error when I run it:
1 [main] INFO eclipse.emf.mwe.core.WorkflowRunner -
10 [main] INFO eclipse.emf.mwe.core.WorkflowRunner - EMF Modeling
Workflow Engine 0.7.0, Build v200906091110
10 [main] INFO eclipse.emf.mwe.core.WorkflowRunner - (c) 2005-2009
openarchitectureware.org and contributors
10 [main] INFO eclipse.emf.mwe.core.WorkflowRunner - running workflow:
C:/Users/Durga/workspace_TMF/org.xtext.samm.Edifice.generato r/src/workflow/EdificeGenerator.mwe
676 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering
platform uri 'C:\Users\Durga\workspace_TMF'
872 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated
EPackage 'eu.qimpress.samm.staticstructure.StaticstructurePackage'
873 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated
EPackage 'eu.qimpress.samm.behaviour.BehaviourPackage'
875 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated
EPackage
'eu.qimpress.samm.deployment.targetenvironment.Targetenviron mentPackage'
876 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated
EPackage 'eu.qimpress.samm.deployment.hardware.HardwarePackage'
877 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated
EPackage 'eu.qimpress.samm.deployment.allocation.AllocationPackage'
878 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated
EPackage 'eu.qimpress.samm.datatypes.DatatypesPackage'
888 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated
EPackage 'eu.qimpress.samm.annotation.AnnotationPackage'
889 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated
EPackage 'eu.qimpress.samm.usagemodel.UsagemodelPackage'
2009 [main] INFO e.core.container.CompositeComponent - DirectoryCleaner:
cleaning directory 'src-gen'
2010 [main] INFO ipse.emf.mwe.utils.DirectoryCleaner - Cleaning
C:\Users\Durga\workspace_TMF\org.xtext.samm.Edifice.generato r\src-gen
2011 [main] INFO e.core.container.CompositeComponent - MweReader:
loading file from classpath:/model/MyModel.edifice
4103 [main] INFO e.core.container.CompositeComponent - Generator:
generating 'templates::Template::def_outer FOR refn_core::NamedEntity' =>
4181 [main] ERROR org.eclipse.xpand2.Generator - Error in
Component of type org.eclipse.xpand2.Generator:
EvaluationException : Couldn't find enum literal or type
'refn_core::NamedEntity'
[65,22] on line 1 'refn_core::NamedEntity'
4182 [main] ERROR eclipse.emf.mwe.core.WorkflowRunner - Workflow
interrupted. Reason: Couldn't find enum literal or type
4182 [main] ERROR eclipse.emf.mwe.core.WorkflowRunner - [ERROR]:
Diagnosis of
eu.qimpress.samm.staticstructure.impl.PrimitiveComponentImpl @c7e8a7{classpath:/model/MyModel.edifice#pr_01}(Element:
pr_a; Reported by: MweReader: loading file from
classpath:/model/MyModel.edifice)
4182 [main] ERROR eclipse.emf.mwe.core.WorkflowRunner - [ERROR]: The
'HasToProvideOrRequireServices' invariant is violated on
'eu.qimpress.samm.staticstructure.impl.PrimitiveComponentImp l @c7e8a7{classpath:/model/MyModel.edifice#pr_01}'(Element:
4182 [main] ERROR eclipse.emf.mwe.core.WorkflowRunner - [ERROR]: Couldn't
find enum literal or type 'refn_core::NamedEntity'(Element:
refn_core::NamedEntity; Reported by: Generator: generating
'templates::Template::def_outer FOR refn_core::NamedEntity' => [])
find enum literal or type 'refn_core::NamedEntity'(Element: EXPAND
templates::Template::def_outer FOR refn_core::NamedEntity; Reported by:
Generator: generating 'templates::Template::def_outer FOR
I'm surprised why it's unable to determine the rule that tht references!!
Can anyone suggest??
Thanks.
Durga
Re: XPand workflow problem [message #63382 is a reply to message #63354] Tue, 30 June 2009 12:48 Go to previous messageGo to next message
Hi Durga,
in the workflow file ...
> <metaModel
.... it must be
<expand value="templates::Template::def_outer FOR model"/>
instead.
Because the MWEReader by default makes the loaded model under that name
('model') available to other components.
The <expand/> element is actually an invocation, so you have to provide
a value to pass in, which is typically a model, which has been parsed
previously.
So the syntax is
<expand value="qualified::name::to::Template FOR someExpression"/>
Hope that helps,
Sven
Re: XPand workflow problem [message #63497 is a reply to message #63382] Thu, 02 July 2009 07:13 Go to previous messageGo to next message
Hello Sven
As u advised, I made the necessary changes, but that doesn't still help.
My workflow is now:
<workflow>
</bean>
</component>
<!--metaModel
class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel "-->
<metaModel class="org.eclipse.xtend.typesystem.emf.EmfMetaModel"/>
<!--metaModelFile
value="platform:/resource/eu.qimpress.samm/model/samm.ecore "/>
</metaModel-->
<expand value="templates::Template::defn_PrimitiveDataType FOR model"/>
</component>
</workflow>
And my XPand template is:
«DEFINE def_outer FOR Type»
«EXPAND def_inner FOREACH this.typeSelect(PrimitiveDataType)»
«ENDDEFINE»
«DEFINE defn_PrimitiveDataType FOR PrimitiveDataType»
PrimitiveDatatype «id»: «name»{
«REM»
operBehv: «EXPAND defn_OperationBehaviour FOREACH OperationBehaviour»
compTypeBehv: «EXPAND defn_componentTypeBehaviour FOREACH
ComponentTypeBehaviour»
sink: «EXPAND defn_sink FOREACH EventPort»
source: «EXPAND defn_source FOREACH EventPort»
«ENDREM»
«ENDFILE»
«ENDDEFINE»
But the error that I get when I run my workflow is:
11 [main] INFO eclipse.emf.mwe.core.WorkflowRunner - EMF Modeling
11 [main] INFO eclipse.emf.mwe.core.WorkflowRunner - (c) 2005-2009
11 [main] INFO eclipse.emf.mwe.core.WorkflowRunner - running workflow:
12 [main] INFO eclipse.emf.mwe.core.WorkflowRunner -
758 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering
915 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated
EPackage
916 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated
917 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated
1990 [main] INFO e.core.container.CompositeComponent - DirectoryCleaner:
1990 [main] INFO ipse.emf.mwe.utils.DirectoryCleaner - Cleaning
1992 [main] INFO e.core.container.CompositeComponent - MweReader:
2702 [main] INFO e.core.container.CompositeComponent - Generator:
generating 'Template::defn_PrimitiveDataType FOR model' => []
2781 [main] ERROR org.eclipse.xpand2.Generator - Error in
EvaluationException : No Definition 'Template::defn_PrimitiveDataType for
datatypes::PrimitiveDataType' found!
[23,49] on line 1 'EXPAND Template::defn_PrimitiveDataType FOR model'
2781 [main] ERROR eclipse.emf.mwe.core.WorkflowRunner - Workflow
interrupted. Reason: No Definition 'Template::defn_PrimitiveDataType for
2781 [main] ERROR eclipse.emf.mwe.core.WorkflowRunner - [ERROR]: No
datatypes::PrimitiveDataType' found!(Element: EXPAND
Template::defn_PrimitiveDataType FOR model; Reported by: Generator:
generating 'Template::defn_PrimitiveDataType FOR model' => [])
It seems it's unable to find the definition in template file !!
Do I need to explicitly import the metamodel inspite of registering them
in the workflow ? I tried importing the metamodel even, but that doesn't
work..
any suggestions..
Thanks.
Durga
Re: XPand workflow problem [message #63720 is a reply to message #63497] Mon, 06 July 2009 07:51 Go to previous messageGo to next message
Hi Durga,
you need to import the namespace of the used types in your Xpand template.
Please add the following as the first line in your Xpand file.
<<IMPORT datatypes>>
Don't you get error markers in the template?
You need to add such an import for each used EPackage. In Xpand we use
the name attribute of an EPackage to compute qualified names of the
contained types.
Hope that helps,
Sven
> «ENDDEFINE»
> «REM»
> OperationBehaviour»
> «ENDREM»
> «ENDFILE»
> «ENDDEFINE»
> workflow:
> 12 [main] INFO eclipse.emf.mwe.core.WorkflowRunner - 758 [main]
> INFO lipse.emf.mwe.utils.StandaloneSetup - Registering platform uri
> generated EPackage
> generated EPackage 'eu.qimpress.samm.behaviour.BehaviourPackage'
> generated EPackage
> generated EPackage 'eu.qimpress.samm.deployment.hardware.HardwarePackage'
> generated EPackage
> generated EPackage 'eu.qimpress.samm.datatypes.DatatypesPackage'
> generated EPackage 'eu.qimpress.samm.annotation.AnnotationPackage'
> generated EPackage 'eu.qimpress.samm.usagemodel.UsagemodelPackage'
> DirectoryCleaner: cleaning directory 'src-gen'
> Component of type org.eclipse.xpand2.Generator: EvaluationException
> work..
> any suggestions..
> Thanks.
> Durga
Re: XPand workflow problem [message #63842 is a reply to message #63354] Tue, 07 July 2009 16:32 Go to previous messageGo to next message
Hi Durga!
You are specifying
after FOR you name a type name, but Xpand expects an object of that
type. After FOR follows usually the name of the output slot in which a
reader component, here MweReader, writes. By default this is 'model'. So try
~Karsten
Re: XPand workflow problem [message #63865 is a reply to message #63497] Tue, 07 July 2009 21:54 Go to previous messageGo to next message
Hi Durga!
On 02.07.09 13:13, Durga Prasana Sahoo wrote:
Your expand value is
but the error message is
> No Definition 'Template::defn_PrimitiveDataType for datatypes::PrimitiveDataType' found!
Also the log message says
> Generator: generating 'Template::defn_PrimitiveDataType FOR model' => []
This contradicts. I think you did not post the correct workflow. From what I read from the console output the package qualifier 'template::' is
missing in your expand value.
Is just fine, and console log should print:
Generator: generating 'templates::Template::defn_PrimitiveDataType FOR model' => []
Kind regards,
~Karsten
Re: XPand workflow problem [message #64001 is a reply to message #63842] Wed, 08 July 2009 17:33 Go to previous messageGo to next message
Hi Karsten
Ya, Actually I was making the mistake of ' FOR somethingelse', which Sven
pointed out & I modified accordingly.
However, it seems really strange that the following workflow doesn't work:
____________________________________________________________ _________
<metaModel class="org.eclipse.xtend.typesystem.emf.EmfMetaModel">
<metaModelFile
</metaModel>
<expand value="templates::Template::defn_PrimitiveComponent FOR model"/>
But the following workflow works:
<metaModelPackage value="eu.qimpress.samm.datatypes.DatatypesPackage" />
</metaModel>
<metaModelPackage value="eu.qimpress.samm.behaviour.BehaviourPackage" />
</metaModel>
<metaModelPackage
</metaModel>
<metaModelPackage
value="eu.qimpress.samm.deployment.hardware.HardwarePackage " />
</metaModel>
____________________________________________________________ __________
That is instead of specifying the entire metamodel file in just one step,
we have to rather specify the Packages in the metamodel file.
So, I'm just continuing using the second approach.It's quite surprising,
Since
the first approach is actually suggested in references.
Thanks a lot, still for all your help.
Durga
Re: XPand workflow problem [message #64116 is a reply to message #64001] Thu, 09 July 2009 17:31 Go to previous message
hive used the documented feature with the metaModelFile and this worked
fine for me - what is the exception you get?
Christian
Previous Topic:Problem checking constraints on references with types from ecore meta model
Next Topic:error on context.getVariable
Current Time: Sat Aug 23 01:04:27 EDT 2025
Powered by FUDForum. Page generated in 0.04914 seconds
