Home » Archived » M2M (model-to-model transformation) » [ATL] ClassCastException with java code and ant tasks
[ATL] ClassCastException with java code and ant tasks [message #63326] Mon, 01 October 2007 12:49
Originally posted by: heggly.gmx.net
Hi again,
Running my ATL project from the launch configuration works fine but
both using Ant tasks and java code gives me the same(!) exception (see
on the bottom).
This is really strange because I am sure I use the same models...so I
guess it must be a certain option...
I use the "-- @atlcompiler atl2006" flag and the latest version from
the CVS. Do I have to specify that I want to use the 2006 compiler in
java/ant as well? What about inter-model references for java (I found
the attribute for ant)?
Thanks for your help!
Felix.
SCHWERWIEGEND: ****** BEGIN Stack Trace
SCHWERWIEGEND: exception:
SCHWERWIEGEND: java.lang.ClassCastException@12e67fa
java.lang.IllegalArgumentException:
at sun.reflect.GeneratedMethodAccessor16.invoke(Unknown Source)
org.eclipse.m2m.atl.engine.vm.ClassNativeOperation.exec(Clas sNativeOperation.java:59)
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:133)
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:91)
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:230)
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:325)
org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:161)
org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:289)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:161)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:105)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:81)
at atlinvocation.main.ATL2.run(ATL2.java:327)
at atlinvocation.main.ATL2.start(ATL2.java:95)
at atlinvocation.actions.SampleAction.testATL2(SampleAction.jav a:97)
at atlinvocation.actions.SampleAction.run(SampleAction.java:70)
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:256)
org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPl uginAction.java:229)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:545)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:443)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
at org.eclipse.equinox.launcher.Main.main(Main.java:1144)
SCHWERWIEGEND: A.main() : ??#48 null
SCHWERWIEGEND: local variables = {self=test : ASMModule}
SCHWERWIEGEND: local stack = []
SCHWERWIEGEND: A.__matcher__() : ??#1 null
SCHWERWIEGEND: A.__matchAbstraction() : ??#24 202:3-209:4
SCHWERWIEGEND: local variables = {a=OPERATOR!<unnamed>, self=test :
ASMModule}
SCHWERWIEGEND: local stack = [TransientLinkSet {}]
SCHWERWIEGEND: NativeOperation public static void
org.eclipse.m2m.atl.engine.vm.nativelib.ASMTransientLink.add TargetElement(org.eclipse.m2m.atl.engine.vm.StackFrame,org.e clipse.m2m.atl.engine.vm.nativelib.ASMTransientLink,org.ecli pse.m2m.atl.engine.vm.nativelib.ASMString,org.eclipse.m2m.at l.engine.vm.nativelib.ASMOclAny)
SCHWERWIEGEND: args = [TransientLink {rule = 'Abstraction',
sourceElements = {a = OPERATOR!<unnamed>}, targetElements = {},
variables = {}}, TransientLink {rule = 'Abstraction', sourceElements =
{a = OPERATOR!<unnamed>}, targetElements = {}, variables = {}},
'package']
SCHWERWIEGEND: ****** END Stack Trace
INFO: Execution terminated due to error (see launch configuration to
allow continuation after errors).
SCHWERWIEGEND: null
java.lang.RuntimeException
org.eclipse.m2m.atl.engine.vm.SimpleDebugger.error(SimpleDeb ugger.java:185)
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:85)
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:77)
org.eclipse.m2m.atl.engine.vm.ClassNativeOperation.exec(Clas sNativeOperation.java:64)
Caused by: java.lang.IllegalArgumentException:
.... 51 more
Previous Topic:strings library
Next Topic:[ATL] graphical plugin to plan and executing ATL transformations
Current Time: Sun Jul 27 06:10:46 EDT 2025
Powered by FUDForum. Page generated in 0.03572 seconds
