Home » Eclipse Projects » Mylyn » Displaying data from database with WikiText
Displaying data from database with WikiText [message #63315] Wed, 10 December 2008 03:03 Go to next message
Hi David,
for displaying data from a database table using its key with a tag, say,
<data key="">, what's the best way to extend WikiText?
Thanks!
Yau.
Re: Displaying data from database with WikiText [message #63361 is a reply to message #63315] Wed, 10 December 2008 15:10 Go to previous messageGo to next message
Yau wrote:
> Hi David,
> Thanks!
> Yau.
Yau, if you're using the Textile markup language then all XML tags are
passed through to the HTML output. You could therefore do a two-pass
rendering of the markup. The first pass would transform the markup to
XHTML with embedded XML tags. The second pass would use the XML tags to
process the database content.
Alternatively you could extend a markup language such as Textile to
include your own proprietary tags.
Another option would be to use some other technology such as Facelets
and JSF to render a page with logic and data, and have a custom Facelet
tag handler or JSF tag process regions of text with the WikiText markup
parser.
The best approach really depends on what you're trying to do.
Re: Displaying data from database with WikiText [message #65807 is a reply to message #63361] Mon, 23 February 2009 09:39 Go to previous messageGo to next message
Originally posted by: tbone13.gmx.de
David Green schrieb:
> Yau wrote:
>> Hi David,
>> Thanks!
>> Yau.
> parser.
Hello David,
thank you for this hint, but this doesn't seem to be my problem. Inside
my IDE I created a Project and a file "test.textile". I can edit this
file and the SourceViewer is great, but the preview tab doesn't work.
Now I decided to test inside a clean new installtion. I downloaded
eclipse-SDK-3.4.1-win32 (the classic version) and added the 3 Mylyn
UpdateSites
..../e3.4
..../extras
..../incubators
to the available sites and installed the WikiText plugin.
And ... it's working fine (SourceViewer && Preview Tab)
I'll trie a --clean with my IDE tomorrow.
Best regards
Tobi
Re: Displaying data from database with WikiText [message #65851 is a reply to message #65807] Mon, 23 February 2009 12:33 Go to previous message
> ... snip ...
Sounds like you resolved the issue. If the problem occurs again please
file a bug.
Re: Displaying data from database with WikiText [message #595414 is a reply to message #63315] Wed, 10 December 2008 15:10 Go to previous message
Yau wrote:
> Hi David,
> Thanks!
> Yau.
parser.
Re: Displaying data from database with WikiText [message #596415 is a reply to message #63361] Mon, 23 February 2009 09:39 Go to previous message
> Yau wrote:
>> Hi David,
>> Thanks!
>> Yau.
> parser.
Hello David,
UpdateSites
..../e3.4
..../extras
..../incubators
Best regards
Tobi
Re: Displaying data from database with WikiText [message #596429 is a reply to message #65807] Mon, 23 February 2009 12:33 Go to previous message
> ... snip ...
file a bug.
Previous Topic:Displaying Images in an SWT StyledText
Next Topic:WikiText Textile-generated HTML Misrenders in Eclipse Help System
Current Time: Thu Oct 23 21:30:52 EDT 2025
Powered by FUDForum. Page generated in 0.50935 seconds
