xs:redefine [message #63283] |
Wed, 14 September 2005 19:28  |
Originally posted by: abanerjee.vitria.com
How can I resolve a redefined ComplexType so that it includes the elements
from redefined and original schema? The main schema attached below points
to the 2nd schema which redefines the 3rd schema. The
XSDComplexTypeDefintion corresponding to ClaimType points to the 2rd
schema. The content of the CompleType is instanceof XSDRedefine and I can
call redefine.getResolvedSchema() or redefine.getIncorporatedSchema() to
get the 3rd schema. What api can I use to get the contents of ClaimType
so that it includes the elements from schema 2 and schema 3.
Thanks in advance,
-Anindita.
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<xsd:include schemaLocation="ClaimType.xsd"/>
<xsd:element name="Claim" type="ClaimType"/>
</xsd:schema>
<xsd:redefine schemaLocation="../../../bom/Claim/ClaimType.xsd">
<xsd:complexType name="ClaimType">
<xsd:complexContent>
<xsd:extension base="ClaimType">
<xsd:sequence>
<xsd:element name="EncounterFlag" type="xsd:boolean" minOccurs="0"/>
</xsd:sequence>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
</xsd:redefine>
</xsd:schema>
<xsd:sequence>
<xsd:element name="AccidentCountryCode" type="xsd:string"
minOccurs="0"/>
<xsd:element name="AccidentDateTime" type="xsd:dateTime" minOccurs="0"/>
<xsd:element name="AccidentStateCode" type="xsd:string" minOccurs="0"/>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
Re: xs:redefine [message #63629 is a reply to message #63556] |
Thu, 22 September 2005 14:06   |
Ed,
Thanks for offering to take a look at my use case. You can use the schemas
that I have attached at the beginning of the email thread.
modelGroup.getParticles() return an empty list.
Thanks a lot,
-Anindita.
import org.eclipse.emf.ecore.resource.*;
import org.eclipse.xsd.util.*;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.common.util.URI;
import org.eclipse.xsd.*;
import java.util.*;
import java.io.File;
public class TestRedefine {
private XSDSchema schema_;
public TestRedefine() {
void checkComplexTypeForElement(XSDComplexTypeDefinition complexType,
String elementName) {
if (complexType.getContentType() instanceof XSDParticle ) {
XSDModelGroup modelGrp =
((XSDParticle)complexType.getContentType()).getTerm().
resolveModelGroupDefinition(complexType.getName()).getModelG roup();
checkModelGroupForElement(modelGrp, elementName);
} else
System.out.println("complexType.getContentType(): " +
complexType.getContentType().getClass().getName());
XSDElementDeclaration checkModelGroupForElement(XSDModelGroup modelGroup,
List particles = modelGroup.getParticles();
System.out.println("Size of particles is " + particles.size());
XSDElementDeclaration xsElement = null;
for (Iterator iter = particles.iterator(); iter.hasNext();) {
XSDTerm term = ((XSDParticle)iter.next()).getTerm();
if ((term instanceof XSDElementDeclaration) &&
((XSDElementDeclaration)term).getName().equals(elementName)) {
System.out.println("FOUND ELEMENT: " + elementName);
} else if (term instanceof XSDModelGroup) {
xsElement = checkModelGroupForElement((XSDModelGroup)term,
elementName);
} else
System.out.println("wildcard group:" + term);
return xsElement;
XSDComplexTypeDefinition getComplexType(String memberName) {
List allTypes = schema_.getTypeDefinitions();
for (Iterator iter = allTypes.iterator(); iter.hasNext();) {
XSDTypeDefinition typedef = (XSDTypeDefinition)iter.next();
if ((typedef instanceof XSDComplexTypeDefinition) &&
typedef.getName().equals(memberName))
return (XSDComplexTypeDefinition)typedef;
return null;
XSDSchema loadSchema(String fname) throws Exception {
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "xsd",
new XSDResourceFactoryImpl());
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getLoadOptions().put(XSDResourceImpl.XSD_TRACK_L OCATION,
Boolean.TRUE);
URI uri = URI.createURI(fname);
XSDResourceImpl xsdSchemaResouce = (XSDResourceImpl)
resourceSet.getResource(uri, true);
for (Iterator resources = resourceSet.getResources().iterator();
resources.hasNext(); ) {
Resource resource = (Resource)resources.next();
if (resource instanceof XSDResourceImpl) {
XSDResourceImpl xsdResource = (XSDResourceImpl)resource;
schema_ = xsdResource.getSchema();
return schema_;
return null;
try {
String fname = args[0];
File file = new File(fname);
TestRedefine sch = new TestRedefine();
sch.loadSchema(file.toURL().toString());
XSDComplexTypeDefinition claim = sch.getComplexType("ClaimType");
sch.checkComplexTypeForElement(claim, "AccidentDateTime");
} catch (Exception e) {
e.printStackTrace();
Re: xs:redefine [message #63651 is a reply to message #63629] |
Thu, 22 September 2005 16:52   |
--------------010900060703020100020900
Anindita,
I changed this and things appear to be much better.
*(XSDModelGroup)*((XSDParticle)complexType.getContentType()) .getTerm();*//.
resolveModelGroupDefinition(complexType.getName()).getModelG roup();*
I'm not quite sure that that code was trying to do, but there are no
named model groups in this schema so the above could only result in a
"placeholder" model group definition being returned, i.e., one whose
getContainer() is null because it's not really in any schema.
Anindita Banerjee wrote:
> Ed,
> schemas that I have attached at the beginning of the email thread.
> Thanks a lot,
> -Anindita.
> import java.util.*;
> } else
> modelGroup, String elementName) {
> elementName);
> } else
> return xsElement;
> return null;
> Boolean.TRUE);
> return schema_;
> return null;
> public static void main(String[] args) {
> try {
<html>
<head>
http-equiv="Content-Type">
</head>
Anindita,<br>
<br>
I changed this and things appear to be much better.<br>
<br>
Re: xs:redefine [message #63673 is a reply to message #63651] |
Thu, 22 September 2005 18:57  |
Ed,
It worked!! I was trying to resolve the ModelGroup and that was resulting
in an empty particle list.
Thanks once again for all your help,
-Anindita.
Re: xs:redefine [message #596405 is a reply to message #63283] |
Thu, 15 September 2005 06:13  |
Anindita,
This question is slightly different.
XSDComplexTypeDefinition.getContentType returns either the particle or
the simple type representing the content type. In the case of a
particle, you can walk the XSDParticle.getTerm to get at the root
XSDModelGroup and then you can walk the XSDModelGroup.getParticles to
recursively visit the children. The term of a particle can be either an
XSDElementDeclaration, an XSDModelGroup, or an XSDWildcard. This content
type particle tree includes the all content inherited from based types.
> elements from redefined and original schema? The main schema attached
> below points to the 2nd schema which redefines the 3rd schema. The
> XSDComplexTypeDefintion corresponding to �ClaimType� points to the 2rd
> can call redefine.getResolvedSchema() or
> redefine.getIncorporatedSchema() to get the 3rd schema. What api can I
> use to get the contents of �ClaimType
> � so that it includes the elements from schema 2 and schema 3.
> Thanks in advance,
> -Anindita.
> </xsd:schema>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> </xsd:redefine>
> </xsd:schema>
> <xsd:sequence>
> <xsd:element name="AccidentCountryCode" type="xsd:string" minOccurs="0"/>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
Re: xs:redefine [message #596430 is a reply to message #63283] |
Thu, 15 September 2005 19:36  |
Hi Ed,
I tried out the following code as per your suggestion but it doesn't work.
Am I missing something?
-Anindita.
/* complexType is "ClaimType" which has been redefined */
XSDComplexTypeContent compContentType = complexType.getContentType();
XSDModelGroupDefinition modelGrp =
((XSDParticle)complexType.getContentType()).getTerm().resolv eModelGroupDefinition(complexType.getName());
List particles = modelGrp.getModelGroup().getParticles();
for (Iterator modelIter = particles.iterator();
modelIter.hasNext();) {
XSDParticleContent partContent =
((XSDParticle)modelIter.next()).getContent();
if (partContent instanceof XSDElementDeclaration) {
(XSDElementDeclaration)partContent;
System.out.println("===> " + xsElement.getName());
Re: xs:redefine [message #596435 is a reply to message #63423] |
Fri, 16 September 2005 06:01  |
Anindita,
I noticed you did ((XSDParticle)modelIter.next()).getContent() not
getTerm() for the second level particle. You are also not walking the
content model recursively and in this example you will definitely hit
another model group at the second level of particles.
> Hi Ed,
> work. Am I missing something?
> -Anindita.
Re: xs:redefine [message #596461 is a reply to message #63445] |
Wed, 21 September 2005 19:14  |
Hi Ed,
I changed the code to recursively traverse the model group, but I am still
not able to get to the resolved complexType. In my particular case
modelGroup.getParticles() returns an empty list.
-Anindita.
XSDElementDeclaration xsElement = checkModelGroupForElement(modelGrp);
XSDElementDeclaration checkModelGroupForElement(XSDModelGroup modelGroup) {
if (term instanceof XSDElementDeclaration) {
return (XSDElementDeclaration)term;
xsElement = checkModelGroupForElement((XSDModelGroup)term);
} else {
return xsElement;
Re: xs:redefine [message #596467 is a reply to message #63535] |
Wed, 21 September 2005 19:59  |
Anindita,
If you can demonstrate the problem with a reproducible test case, I can
most efficiently help. I've loaded the schemas and they all appear to
work, but I don't know the context in which you are trying to do your
processing. An all too common mistake is to load the schema with a
relative URI causing relative schemaLocation URIs to fail to resolve.
Modifying org.eclipse.xsd.example to turn it into a test case is pretty
easy and often people find that problem goes away when they do that
(especially when you look at how the URIs are created).
> Hi Ed,
> still not able to get to the resolved complexType. In my particular
> case modelGroup.getParticles() returns an empty list.
> -Anindita.
> modelGroup) {
> } else {
> return xsElement;
Re: xs:redefine [message #596494 is a reply to message #63556] |
Ed,
Thanks a lot,
-Anindita.
import java.util.*;
} else
elementName);
} else
return xsElement;
return null;
Boolean.TRUE);
return schema_;
return null;
try {
Re: xs:redefine [message #596502 is a reply to message #63629] |
Anindita,
> Ed,
> Thanks a lot,
> -Anindita.
> import java.util.*;
> } else
> elementName);
> } else
> return xsElement;
> return null;
> Boolean.TRUE);
> return schema_;
> return null;
> try {
<html>
<head>
</head>
Anindita,<br>
<br>
<br>
Re: xs:redefine [message #596508 is a reply to message #63651] |
Ed,
-Anindita.
FUDForum. Page generated in 0.07241 seconds
