Home » Archived » XML Schema Definition (XSD) » Redefine does give the resolved schema
Redefine does give the resolved schema [message #63260] Wed, 14 September 2005 19:09 Go to next message
Originally posted by: abanerjee.vitria.com
The main schema attached below points to the 2nd schema which redefines
the 3rd schema. The XSDComplexTypeDefintion corresponding to “ClaimType”
points to the 2rd schema. The content of the CompleType is instanceof
XSDRedefine and I can call redefine.getResolvedSchema() or
redefine.getIncorporatedSchema() to get the 3rd schema. How can I resolve
the ComplexType so that it includes the elements from schema 2 and schema
3.
-Anindita.
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<xsd:include schemaLocation="ClaimType.xsd"/>
<xsd:element name="Claim" type="ClaimType"/>
</xsd:schema>
<xsd:redefine schemaLocation="../../../bom/Claim/ClaimType.xsd">
<xsd:complexType name="ClaimType">
<xsd:complexContent>
<xsd:extension base="ClaimType">
<xsd:sequence>
<xsd:element name="EncounterFlag" type="xsd:boolean" minOccurs="0"/>
</xsd:sequence>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
</xsd:redefine>
</xsd:schema>
<xsd:sequence>
<xsd:element name="AccidentCountryCode" type="xsd:string"
minOccurs="0"/>
<xsd:element name="AccidentDateTime" type="xsd:dateTime" minOccurs="0"/>
<xsd:element name="AccidentStateCode" type="xsd:string" minOccurs="0"/>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
Re: Redefine does give the resolved schema [message #63332 is a reply to message #63260] Thu, 15 September 2005 06:08 Go to previous message
Anindita,
I guess you hit send twice. ;-)
> redefines the 3rd schema. The XSDComplexTypeDefintion corresponding to
> �ClaimType� points to the 2rd schema. The content of the CompleType is
> instanceof XSDRedefine and I can call redefine.getResolvedSchema() or
> resolve the ComplexType so that it includes the elements from schema 2
> and schema 3.
> -Anindita.
> </xsd:schema>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> </xsd:redefine>
> </xsd:schema>
> <xsd:sequence>
> <xsd:element name="AccidentCountryCode" type="xsd:string" minOccurs="0"/>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
Re: Redefine does give the resolved schema [message #596398 is a reply to message #63260] Thu, 15 September 2005 06:08 Go to previous message
Anindita,
> and schema 3.
> -Anindita.
> </xsd:schema>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> </xsd:redefine>
> </xsd:schema>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
Previous Topic:Redefine with extension does not pick up the
Next Topic:XSD serialization format
Current Time: Fri Jun 20 11:20:11 EDT 2025
Powered by FUDForum. Page generated in 0.04539 seconds
