Home » Eclipse Projects » Nebula » adding grid control to my project
adding grid control to my project [message #5675] |
Mon, 19 June 2006 16:45  |
I downloaded the grid 1.0 release from the nebula download page, but
even though I add the jar to my project, I can't use it, as even after
importing it, a constructor can't be located for "grid".
I downloaded the examples plugin, and that seems to work, but for some
reason I can't the JAR file from that download either ( same problem ).
Any ideas on what could be going on wrong ( I'm running this on MAC OS X
10.4.6 + SWT_AWT compatibility fix from Apple, fyi ).
I'm running using the 1.5.0.4 JVM from Apple.
suggestions ?
Marcelo
Re: adding grid control to my project [message #5692 is a reply to message #5675] |
Tue, 20 June 2006 09:31   |
Hi Marcelo,
The Grid is not at 1.0 release. Please be aware that the Grid is still
under active development and is not complete.
As for your problem, I can't really guess what the cause might be. I
just downloaded the zip and extracted and used the jar file just fine.
I can only imagine there is some problem on your machine or development
environment.
-Chris
> suggestions ?
> Marcelo
Re: adding grid control to my project [message #5709 is a reply to message #5692] |
Tue, 20 June 2006 21:26  |
No problemo Chris. I restarted Eclipse..and voila...I was magically able
to use it. Possible the manifest isn't being processed properly ?
Anyway, no big deal, as I can now get to using it. Things are looking
good so far.
Marcelo
Chris Gross wrote:
> Hi Marcelo,
> just downloaded the zip and extracted and used the jar file just fine. I
> environment.
> -Chris
>> X 10.4.6 + SWT_AWT compatibility fix from Apple, fyi ).
>> suggestions ?
>> Marcelo
Re: adding grid control to my project [message #562500 is a reply to message #5675] |
Hi Marcelo,
environment.
-Chris
> suggestions ?
> Marcelo
Re: adding grid control to my project [message #562524 is a reply to message #5692] |
good so far.
Marcelo
Chris Gross wrote:
> Hi Marcelo,
> environment.
> -Chris
>> suggestions ?
>> Marcelo
Current Time: Sun Jun 01 00:05:36 EDT 2025
Powered by FUDForum. Page generated in 0.02390 seconds
