| Hyades and Weblogic 6.1 [message #63131] |
Fri, 31 March 2006 13:07 |
Originally posted by: deepu_roy.yahoo.com
I am new to Hyades (I have to use Eclipse 3.0 so I cannot use tptp 4.0 and
above). I am trying to profile a J2EE application running on Weblogic 6.1.
I have added the -XrunpiAgent:server=enabled option to the start script of
my Weblogic server. I have been able to attach to the Weblogic process.
When I try to run a page on the server or collect any data from the
process, the Weblogic server is killed. I have run the raserver with debug
logging and I get the output below. There is no unusual output on the
Weblogic logs. Is there anything else that I should be doing. Any help
would be appreciated.
Deepu
<SERVER_MSG time="2006:3:31:10:54:18" severity="INFORMATION" text="Service
starting"/>
<SERVER_MSG time="2006:3:31:10:54:18" severity="DEBUG" text="Using plugin
directory C:\hyades\plugins"/>
<SERVER_MSG time="2006:3:31:10:54:18" severity="DEBUG" text="Parsing
plugin file:
C:\hyades\plugins\org.eclipse.hyades.datacollection\config\p luginconfig.xml "/>
<SERVER_MSG time="2006:3:31:10:54:18" severity="DEBUG" text="Started
processing Configuration
<SERVER_MSG time="2006:3:31:10:54:18" severity="DEBUG" text="Completed
text="Successfully loaded plugin: org.eclipse.hyades.datacollection"/>
plugin file:
C:\hyades\plugins\org.eclipse.hyades.logging.parsers\config\ pluginconfig.xml "/>
text="Successfully loaded plugin: org.eclipse.hyades.logging.parsers"/>
plugin file:
C:\hyades\plugins\org.eclipse.hyades.test\config\pluginconfi g.xml "/>
text="Successfully loaded plugin: org.eclipse.hyades.test"/>
<SERVER_MSG time="2006:3:31:10:54:18" severity="INFORMATION" text="Active
configuration set to: default"/>
<SERVER_MSG time="2006:3:31:10:54:18" severity="DEBUG" text="Successfully
set PATH = C:\hyades\bin;C:\PROGRAM
FILES\FILENET\IDM\;C:\SYBASE\SQLREMOTE\DLL\;C:\SYBASE\OCS-12 _0\BIN\;C:\WINDOWS\;C:\SYBASE\ASEP\;C:\SYBASE\OCS-12_0\DLL\; C:\WINDOWS\SYSTEM32\;C:\WINDOWS\SYSTEM32\WBEM;C:\WINDOWS\SYS TEM32;C:\WINDOWS;C:\WINDOWS\SYSTEM32\WBEM;C:\CA_APPSW;C:\TNG SD\BIN;C:\NOTES\DATA;C:\PROGRAM
FILES\E!PC\;C:\PROGRAM FILES\MICROSOFT SQL
SERVER\80\TOOLS\BINN\;C:\PROGRAM
FILES\RATIONAL\CLEARCASE\BIN\;C:\DMI\WIN32\BIN"/>
set CLASSPATH =
C:\sybase\ASEP\3pclass.zip;C:\sybase\ASEP\monclass.zip;;C:\h yades\lib\commons-logging.jar "/>
set CLASSPATH =
C:\sybase\ASEP\3pclass.zip;C:\sybase\ASEP\monclass.zip;;C:\h yades\lib\commons-logging.jar;C:\hyades\lib\hcframe.jar "/>
set CLASSPATH =
C:\sybase\ASEP\3pclass.zip;C:\sybase\ASEP\monclass.zip;;C:\h yades\lib\commons-logging.jar;C:\hyades\lib\hcframe.jar;C:\h yades\lib\hexcore.jar "/>
set CLASSPATH =
C:\sybase\ASEP\3pclass.zip;C:\sybase\ASEP\monclass.zip;;C:\h yades\lib\commons-logging.jar;C:\hyades\lib\hcframe.jar;C:\h yades\lib\hexcore.jar;C:\hyades\lib\hexl.jar "/>
set CLASSPATH =
C:\sybase\ASEP\3pclass.zip;C:\sybase\ASEP\monclass.zip;;C:\h yades\lib\commons-logging.jar;C:\hyades\lib\hcframe.jar;C:\h yades\lib\hexcore.jar;C:\hyades\lib\hexl.jar;C:\hyades\lib\h exr.jar "/>
set CLASSPATH =
C:\sybase\ASEP\3pclass.zip;C:\sybase\ASEP\monclass.zip;;C:\h yades\lib\commons-logging.jar;C:\hyades\lib\hcframe.jar;C:\h yades\lib\hexcore.jar;C:\hyades\lib\hexl.jar;C:\hyades\lib\h exr.jar;C:\hyades\lib\hl14.jar "/>
set CLASSPATH =
C:\sybase\ASEP\3pclass.zip;C:\sybase\ASEP\monclass.zip;;C:\h yades\lib\commons-logging.jar;C:\hyades\lib\hcframe.jar;C:\h yades\lib\hexcore.jar;C:\hyades\lib\hexl.jar;C:\hyades\lib\h exr.jar;C:\hyades\lib\hl14.jar;C:\hyades\lib\hlcommons.jar "/>
set CLASSPATH =
C:\sybase\ASEP\3pclass.zip;C:\sybase\ASEP\monclass.zip;;C:\h yades\lib\commons-logging.jar;C:\hyades\lib\hcframe.jar;C:\h yades\lib\hexcore.jar;C:\hyades\lib\hexl.jar;C:\hyades\lib\h exr.jar;C:\hyades\lib\hl14.jar;C:\hyades\lib\hlcommons.jar;C :\hyades\lib\hlcore.jar "/>
set CLASSPATH =
C:\sybase\ASEP\3pclass.zip;C:\sybase\ASEP\monclass.zip;;C:\h yades\lib\commons-logging.jar;C:\hyades\lib\hcframe.jar;C:\h yades\lib\hexcore.jar;C:\hyades\lib\hexl.jar;C:\hyades\lib\h exr.jar;C:\hyades\lib\hl14.jar;C:\hyades\lib\hlcommons.jar;C :\hyades\lib\hlcore.jar;C:\hyades\lib\hlevents.jar "/>
set CLASSPATH =
C:\sybase\ASEP\3pclass.zip;C:\sybase\ASEP\monclass.zip;;C:\h yades\lib\commons-logging.jar;C:\hyades\lib\hcframe.jar;C:\h yades\lib\hexcore.jar;C:\hyades\lib\hexl.jar;C:\hyades\lib\h exr.jar;C:\hyades\lib\hl14.jar;C:\hyades\lib\hlcommons.jar;C :\hyades\lib\hlcore.jar;C:\hyades\lib\hlevents.jar;C:\hyades \lib\hlcbe101.jar "/>
set CLASSPATH =
C:\sybase\ASEP\3pclass.zip;C:\sybase\ASEP\monclass.zip;;C:\h yades\lib\commons-logging.jar;C:\hyades\lib\hcframe.jar;C:\h yades\lib\hexcore.jar;C:\hyades\lib\hexl.jar;C:\hyades\lib\h exr.jar;C:\hyades\lib\hl14.jar;C:\hyades\lib\hlcommons.jar;C :\hyades\lib\hlcore.jar;C:\hyades\lib\hlevents.jar;C:\hyades \lib\hlcbe101.jar;C:\hyades\lib\ecore.jar "/>
set CLASSPATH =
C:\sybase\ASEP\3pclass.zip;C:\sybase\ASEP\monclass.zip;;C:\h yades\lib\commons-logging.jar;C:\hyades\lib\hcframe.jar;C:\h yades\lib\hexcore.jar;C:\hyades\lib\hexl.jar;C:\hyades\lib\h exr.jar;C:\hyades\lib\hl14.jar;C:\hyades\lib\hlcommons.jar;C :\hyades\lib\hlcore.jar;C:\hyades\lib\hlevents.jar;C:\hyades \lib\hlcbe101.jar;C:\hyades\lib\ecore.jar;C:\hyades\lib\comm on.jar "/>
set CLASSPATH =
C:\sybase\ASEP\3pclass.zip;C:\sybase\ASEP\monclass.zip;;C:\h yades\lib\commons-logging.jar;C:\hyades\lib\hcframe.jar;C:\h yades\lib\hexcore.jar;C:\hyades\lib\hexl.jar;C:\hyades\lib\h exr.jar;C:\hyades\lib\hl14.jar;C:\hyades\lib\hlcommons.jar;C :\hyades\lib\hlcore.jar;C:\hyades\lib\hlevents.jar;C:\hyades \lib\hlcbe101.jar;C:\hyades\lib\ecore.jar;C:\hyades\lib\comm on.jar;C:\hyades\plugins\org.eclipse.hyades.test\lib\junit.j ar "/>
<SERVER_MSG time="2006:3:31:10:54:18" severity="INFORMATION" text="Loaded
configuration: default"/>
started successfully"/>
<SERVER_MSG time="2006:3:31:10:54:18" severity="DEBUG" text="Loaded JVM
library C:\Program Files\Java\j2re1.4.2_09\bin\client\jvm.dll"/>
<SERVER_MSG time="2006:3:31:10:54:18" severity="DEBUG" text="Resolved
entrypoint for JNI_CreateJavaVM"/>
<SERVER_MSG time="2006:3:31:10:54:18" severity="DEBUG" text="Process
polling thread created, tid = 572"/>
<SERVER_MSG time="2006:3:31:10:54:24" severity="INFORMATION"
text="Incoming connection request on socket 1032 from 30.22.74.197"/>
text="Connection accepted on socket 1032"/>
<SERVER_MSG time="2006:3:31:10:54:24" severity="DEBUG" text="Entering
processing thread for client on socket 1032"/>
<SERVER_MSG time="2006:3:31:10:54:32" severity="DEBUG" text="Validated
message of 36 bytes"/>
<SERVER_MSG time="2006:3:31:10:54:32" severity="DEBUG" text="Processing
message of length 36 bytes."/>
command: tag=17"/>
<SERVER_MSG time="2006:3:31:10:54:37" severity="DEBUG" text="Validated
<SERVER_MSG time="2006:3:31:10:54:37" severity="DEBUG" text="Processing
command: tag=17"/>
<SERVER_MSG time="2006:3:31:10:54:52" severity="DEBUG" text="Validated
<SERVER_MSG time="2006:3:31:10:54:52" severity="DEBUG" text="Processing
command: tag=17"/>
<SERVER_MSG time="2006:3:31:10:54:53" severity="DEBUG" text="Validated
<SERVER_MSG time="2006:3:31:10:54:53" severity="DEBUG" text="Processing
command: tag=17"/>
<SERVER_MSG time="2006:3:31:10:54:54" severity="DEBUG" text="Validated
<SERVER_MSG time="2006:3:31:10:54:54" severity="DEBUG" text="Processing
command: tag=17"/>
<SERVER_MSG time="2006:3:31:10:54:55" severity="DEBUG" text="Validated
<SERVER_MSG time="2006:3:31:10:54:55" severity="DEBUG" text="Processing
command: tag=17"/>
<SERVER_MSG time="2006:3:31:10:54:56" severity="DEBUG" text="Validated
<SERVER_MSG time="2006:3:31:10:54:56" severity="DEBUG" text="Processing
command: tag=17"/>
<SERVER_MSG time="2006:3:31:10:55:2" severity="DEBUG" text="Validated
<SERVER_MSG time="2006:3:31:10:55:2" severity="DEBUG" text="Processing
command: tag=17"/>
command: tag=17"/>
<SERVER_MSG time="2006:3:31:10:55:4" severity="DEBUG" text="Validated
<SERVER_MSG time="2006:3:31:10:55:4" severity="DEBUG" text="Processing
command: tag=17"/>
<SERVER_MSG time="2006:3:31:10:55:14" severity="DEBUG" text="Validated
<SERVER_MSG time="2006:3:31:10:55:14" severity="DEBUG" text="Processing
command: tag=17"/>
<SERVER_MSG time="2006:3:31:10:55:15" severity="DEBUG" text="Validated
<SERVER_MSG time="2006:3:31:10:55:15" severity="DEBUG" text="Processing
command: tag=17"/>
<SERVER_MSG time="2006:3:31:10:55:16" severity="DEBUG" text="Validated
<SERVER_MSG time="2006:3:31:10:55:16" severity="DEBUG" text="Processing
command: tag=17"/>
command: tag=17"/>
command: tag=17"/>
command: tag=17"/>
<SERVER_MSG time="2006:3:31:10:55:17" severity="DEBUG" text="Validated
<SERVER_MSG time="2006:3:31:10:55:17" severity="DEBUG" text="Processing
command: tag=17"/>
<SERVER_MSG time="2006:3:31:10:56:28" severity="DEBUG" text="Validated
<SERVER_MSG time="2006:3:31:10:56:28" severity="DEBUG" text="Processing
command: tag=17"/>
command: tag=17"/>
<SERVER_MSG time="2006:3:31:10:56:29" severity="DEBUG" text="Validated
<SERVER_MSG time="2006:3:31:10:56:29" severity="DEBUG" text="Processing
command: tag=17"/>
<SERVER_MSG time="2006:3:31:10:57:42" severity="DEBUG" text="Validated
message of 20 bytes"/>
<SERVER_MSG time="2006:3:31:10:57:42" severity="DEBUG" text="Processing
message of length 20 bytes."/>
<SERVER_MSG time="2006:3:31:10:57:42" severity="INFORMATION"
text="Incoming connection request from agent Java Profiling Agent in
process 2260 with uuid c2e80b6a-a4ae-44cc-9884-c11ff8a8fafc"/>
text="Registering process 2260"/>
<SERVER_MSG time="2006:3:31:10:57:42" severity="WARNING" text="Registered
Agent c2e80b6a-a4ae-44cc-9884-c11ff8a8fafc."/>
<SERVER_MSG time="2006:3:31:10:57:42" severity="DEBUG" text="Wrote
configuration of length 200 to agent
<SERVER_MSG time="2006:3:31:10:57:47" severity="DEBUG" text="Validated
<SERVER_MSG time="2006:3:31:10:57:47" severity="DEBUG" text="Processing
command: tag=17"/>
message of 40 bytes"/>
message of length 40 bytes."/>
command: tag=18"/>
message of 64 bytes"/>
message of length 64 bytes."/>
command: tag=28"/>
<SERVER_MSG time="2006:3:31:10:57:57" severity="DEBUG" text="Validated
<SERVER_MSG time="2006:3:31:10:57:57" severity="DEBUG" text="Processing
command: tag=17"/>
command: tag=18"/>
command: tag=28"/>
<SERVER_MSG time="2006:3:31:10:58:27" severity="DEBUG" text="Validated
<SERVER_MSG time="2006:3:31:10:58:27" severity="DEBUG" text="Processing
command: tag=17"/>
command: tag=18"/>
command: tag=28"/>
<SERVER_MSG time="2006:3:31:10:59:4" severity="DEBUG" text="Validated
<SERVER_MSG time="2006:3:31:10:59:4" severity="DEBUG" text="Processing
command: tag=17"/>
command: tag=18"/>
command: tag=28"/>
command: tag=17"/>
command: tag=18"/>
command: tag=28"/>
<SERVER_MSG time="2006:3:31:10:59:5" severity="DEBUG" text="Validated
<SERVER_MSG time="2006:3:31:10:59:5" severity="DEBUG" text="Processing
command: tag=17"/>
command: tag=18"/>
command: tag=28"/>
<SERVER_MSG time="2006:3:31:10:59:7" severity="DEBUG" text="Validated
<SERVER_MSG time="2006:3:31:10:59:7" severity="DEBUG" text="Processing
command: tag=20"/>
<SERVER_MSG time="2006:3:31:10:59:7" severity="INFORMATION"
text="Preparing Agent active"/>
<SERVER_MSG time="2006:3:31:10:59:16" severity="DEBUG" text="Validated
message of 984 bytes"/>
<SERVER_MSG time="2006:3:31:10:59:16" severity="DEBUG" text="Processing
message of length 984 bytes."/>
command: tag=25"/>
<SERVER_MSG time="2006:3:31:10:59:16" severity="DEBUG" text="Forwarding
command to agent: tag=25 agent=Java Profiling Agent pid=2260"/>
<SERVER_MSG time="2006:3:31:10:59:16" severity="DEBUG" text="Sent 112
bytes to agent c2e80b6a-a4ae-44cc-9884-c11ff8a8fafc"/>
command: tag=25"/>
command: tag=25"/>
command: tag=25"/>
<SERVER_MSG time="2006:3:31:10:59:16" severity="DEBUG" text="Sent 108
command: tag=25"/>
command: tag=25"/>
command: tag=25"/>
<SERVER_MSG time="2006:3:31:10:59:16" severity="DEBUG" text="Sent 104
command: tag=25"/>
<SERVER_MSG time="2006:3:31:10:59:16" severity="DEBUG" text="Sent 100
command: tag=25"/>
command: tag=25"/>
<SERVER_MSG time="2006:3:31:10:59:16" severity="DEBUG" text="Sent 120
command: tag=25"/>
<SERVER_MSG time="2006:3:31:10:59:16" severity="DEBUG" text="Sent 168
message of 80 bytes"/>
message of length 80 bytes."/>
command: tag=26"/>
command to agent: tag=26 agent=Java Profiling Agent pid=2260"/>
<SERVER_MSG time="2006:3:31:10:59:16" severity="DEBUG" text="Sent 80 bytes
message of 72 bytes"/>
message of length 72 bytes."/>
command: tag=22"/>
<SERVER_MSG time="2006:3:31:10:59:16" severity="DEBUG" text="About to
create shared memory with name rabuffer0 and size=67108864"/>
<SERVER_MSG time="2006:3:31:10:59:18" severity="INFORMATION" text="Created
data channel with name rabuffer0 and CB addr 08140158 buffer addr 08182270
size in=67108864 size out=67108864"/>
<SERVER_MSG time="2006:3:31:10:59:18" severity="DEBUG" text="Connecting to
the client data channel socket on port 1630"/>
text="Connected to client data channel socket on port 1630 with descriptor
1000"/>
flusher thread and about to send message to agent"/>
<SERVER_MSG time="2006:3:31:10:59:18" severity="DEBUG" text="Sent 80 bytes
<SERVER_MSG time="2006:3:31:10:59:18" severity="DEBUG" text="Validated
message of 76 bytes"/>
<SERVER_MSG time="2006:3:31:10:59:18" severity="DEBUG" text="Processing
message of length 76 bytes."/>
command: tag=26"/>
<SERVER_MSG time="2006:3:31:10:59:18" severity="DEBUG" text="Forwarding
<SERVER_MSG time="2006:3:31:10:59:18" severity="DEBUG" text="Sent 76 bytes
<SERVER_MSG time="2006:3:31:10:59:18" severity="DEBUG" text="About to
start flushing data from agent Java Profiling Agent pid=2260 to port
1630"/>
<SERVER_MSG time="2006:3:31:10:59:46" severity="DEBUG" text="Validated
message of 156 bytes"/>
<SERVER_MSG time="2006:3:31:10:59:46" severity="DEBUG" text="Processing
message of length 156 bytes."/>
<SERVER_MSG time="2006:3:31:10:59:46" severity="INFORMATION"
text="Deregistering agent c2e80b6a-a4ae-44cc-9884-c11ff8a8fafc. "/>
text="Removing agent c2e80b6a-a4ae-44cc-9884-c11ff8a8fafc. from client"/>
<SERVER_MSG time="2006:3:31:10:59:46" severity="DEBUG" text="No more
active agents in process 2260 so scrub it"/>
<SERVER_MSG time="2006:3:31:10:59:48" severity="DEBUG" text="After
flushing has stopped from agent Java Profiling Agent pid=2260 to port
1630."/>
<SERVER_MSG time="2006:3:31:10:59:48" severity="DEBUG" text="Returning
from flushing thread after cleaning up storage"/>
<SERVER_MSG time="2006:3:31:10:59:49" severity="INFORMATION" text="Process
2260 does not exist so scrub it"/>
2260 exited"/>
FUDForum. Page generated in 0.22123 seconds
