| Re: Is there a way to make a call to the Eclipse Tomcat directly? [message #64221 is a reply to message #63123] |
Thu, 05 June 2003 12:59  |
No. Tomcat plug-in is intended to be run under Eclipse framework as an
embedded server, not the stand-alone server. The closest you can get to
running it from command line is to start stand-alone help that will run
_embedded_ tomcat. Whey don't you just download Tomcat and start it
according to its instructions.
Konrad Kolosowski
"Probir Mukerjee" <probirkmukerjee@yahoo.com> wrote in message
news:bblmci$mlm$1@rogue.oti.com...
> Is there a way to start the tomcat server in the Eclipse framework
> directly from the command line?
> I would like to just start the tomcat server.
> Thanks for your help.
> Probir
FUDForum. Page generated in 0.03773 seconds
