Home » Archived » Test and Performance Tools Platform (TPTP) » Problem with runing AGR tests with Ant script without existing .metadata folder
Problem with runing AGR tests with Ant script without existing .metadata folder [message #63107] Fri, 31 March 2006 12:31 Go to next message
Originally posted by: Joan.He.freescale.com
I ran into the problem when running AGR tests with Ant script without
existing .metadata folder. It always complains about testsuite file
doesn't exist. I haven't tried with Junit tests. I wonder if anyone had
the same problem before, if .metadata folder is required for running tests
with Ant script. Any information and help is appreciated.
Joan
Re: Problem with runing AGR tests with Ant script without existing .metadata folder [message #65689 is a reply to message #63107] Tue, 11 April 2006 14:32 Go to previous message
The primary developer of the automatable service framework is not on the
project anymore but I believe he still does regularly check the mailing
list. Please try sending your message to the test mailing list:
http://www.eclipse.org/tptp/home/project_info/general/mailne ws.html
"Joan He" <Joan.He@freescale.com> wrote in message
news:0000a55a5858366438b6e60f5966e26a$1@www.eclipse.org...
> Joan
Previous Topic:Verification Hook class problem in Linux
Next Topic:Problem running AGR in standard mode
Current Time: Wed Oct 29 05:57:48 EDT 2025
Powered by FUDForum. Page generated in 0.03798 seconds
