Home » Archived » Test and Performance Tools Platform (TPTP) » Can't profile using the "Getting Started" tutoria;
Can't profile using the "Getting Started" tutoria; [message #63064] Thu, 30 March 2006 17:13
Hi--
When I try to follow the "Getting Started" profiling tutorial, the Eclipse
instance that is doing the monitoring/collecting freezes after the first
attempt to collect. I'm trying to attach to a local java process, and am
trying with and without using the Hyades plug-ins--neither works--which,
by the way, I seem to be missing the Hyades plug-ins.
Using on the command line: eclipse -vmargs -XrunpiAgent:server=enabled
eclipse -date profile
This on an XP machine with 2 instances of Eclipse running.
Not sure what I'm doing wrong so any suggestions to fix this would be
helpful.
Thanks in advance!
Lisa
Previous Topic:AGR standard execution stalls
Next Topic:Hyades and Weblogic 6.1
Current Time: Wed Nov 12 13:10:24 EST 2025
Powered by FUDForum. Page generated in 0.03380 seconds
