Home » Eclipse Projects » Nebula » [Grid] setTopIndex without V_SCROLL
[Grid] setTopIndex without V_SCROLL [message #63033] Fri, 24 April 2009 08:40 Go to next message
i am using two Grid's which are located side by side and behave as one
Grid with fixed columns (inspired by
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet234.java?view=co).
No i'd like to make the VScrollBar of the left Grid invisible which
unfortunately causes the "parallel scrolling" to break. This happens due
to
if (!vScroll.getVisible())
return;
in method setTopIndex() of Grid.
Is there any chance to workaround that (using setSelection() of Grid makes
the selection change correctly but does not cause the tree to scroll)? I'd
like to achieve synchronised scrolling without having the left VScrollBar
visible.
Thanks in advance for any hints and tipps,
Thomas E.-E.
Re: [Grid] setTopIndex without V_SCROLL [message #63034 is a reply to message #63033] Fri, 24 April 2009 10:59 Go to previous messageGo to next message
Is this https://bugs.eclipse.org/bugs/show_bug.cgi?id=197008 and what
you really want is fixed columns right?
Tom
Thomas Eichstädt-Engelen schrieb:
> unfortunately causes the "parallel scrolling" to break. This happens due to
> return;
> makes the selection change correctly but does not cause the tree to
> scroll)? I'd like to achieve synchronised scrolling without having the
> left VScrollBar visible.
> Thomas E.-E.
Re: [Grid] setTopIndex without V_SCROLL [message #63035 is a reply to message #63034] Fri, 24 April 2009 11:42 Go to previous messageGo to next message
Hi Tom,
yeeees, i do really want fixed columns ;-) Did i get the bugs right that
there is still a solution in grid to achieve that?
cheers,
Thomas E.-E.
Re: [Grid] setTopIndex without V_SCROLL [message #63037 is a reply to message #63035] Fri, 24 April 2009 15:01 Go to previous message
yes at least the author in the bug says it somehow works. As you noticed
I today ranked all the bugs of grid based on whether they have a patch,
the amount of work, ... .
Sad enough the fixed column stuff is not very high up in the priority
list though really many people are interested in such a feature but we
(Chris and me) have to face the reality that we could not work on this
our own but need to depend on external contributors.
My current strategy was to rank bugs and see which bugs are backed by
interested people (e.g. providing a patch, ...) and integrate this
stuff. Adding the fixed column feature is quite a large refactoring
effort I guess and there is no one who really started working on this
feature => I put it to P5 but at the very moment somebody invests time
into it it would immediately go up in the priority.
A fixed footer-row is already possible since the header_footer branch
got integrated back to the code base (I was payed to add such a feature
and was allowed to contribute it back but fixed columns hasn't been a
requirement).
Tom
> Hi Tom,
> cheers,
> Thomas E.-E.
Re: [Grid] setTopIndex without V_SCROLL [message #594533 is a reply to message #63033] Fri, 24 April 2009 10:59 Go to previous message
Tom
> return;
> Thomas E.-E.
Re: [Grid] setTopIndex without V_SCROLL [message #594540 is a reply to message #63034] Fri, 24 April 2009 11:42 Go to previous message
Hi Tom,
cheers,
Thomas E.-E.
Re: [Grid] setTopIndex without V_SCROLL [message #594551 is a reply to message #63035] Fri, 24 April 2009 15:01 Go to previous message
requirement).
Tom
> Hi Tom,
> cheers,
> Thomas E.-E.
Previous Topic:[Grid] An editing issue in macosx
Next Topic:CDateTime release schedule?
Current Time: Thu Nov 13 11:05:07 EST 2025
Powered by FUDForum. Page generated in 0.04221 seconds
