| grid widget part of SWT [message #63010] |
Wed, 15 April 2009 11:33  |
Is there a plan to put the grid widget part of SWT API? In addition,
when would this widget become modified from ALPHA to BETA and from BETA
to a full release?
Mircea
| Re: grid widget part of SWT [message #63024 is a reply to message #63022] |
Wed, 15 April 2009 15:53   |
Thank you Tom,
It's good to know that there is a custom widget library that gets mature
with time. Whether part of SWT or Nebula, it does not matter much for a
software engineer using the API. I have been looking in implementing a
grid similar to the one in nebula, however, seeing it exists in the
Alpha stage, I will certainly use it in my product once the API is stable.
Mircea
What matters more is the
Tom Schindl wrote:
> *[Disclaimer: This is my current personal view and has not been
> discussed with all Nebula committers but this will follow immediately
> after I posted the answer to this thread]*
> Hi Mircea,
> The initial indent of Nebula in the past has been to provide a
> playground to explore new ways for widget who might migrate to SWT once
> the API is stable.
> In reality we had rethink this because none of our widget will ever get
> part of the SWT release. Instead I think Nebula is going to provide a
> place for reusable UI-Widgets who can't get part of SWT or JFace because
> they only hold widgets used by the Eclipse-Platform.
> With the latest contributions we added to Nebula we already made this
> step reality (e.g. XViewer is a such a component, as well as the
> RadioGroup widget) I see nebula more as a central place where
> UI-Components get a place which are reusable outside the direct
> project-scope they are developed in. So we are one answer to the ever
> occurring "BLOAT" discussing when it comes to UI-Components.
> This new focus implies to things:
> a) instead of relying on the fact that once our widgets are mature we
> need to split nebula into 2 projects:
> - Nebula-mature
> - Nebula-incubation
> b) We make 1.0 releases of all widgets part of Nebula-mature
> But it gives us new possibilities:
> a) We have much more freedome when it comes to minor Java-Version we
> need to support => We allow Java 5 API
> b) We can define our own release train and time
> But it also implies new working areas:
> a) We need to work hard to get our widgets build => For most mature
> widgets this is already reality (See our new download page)
> b) We need to get out of people brains that our widgets are alpha/beta
> whereas the reality is that they are extremly stable
> c) We need better project management to coordinate the effort going into
> the widgets
> So what are the next things to happen is that:
> - Widgets who get part of Nebula-mature get built
> - Widgets who get part of Nebula-mature are IP clean
> => Nebula-mature will not have access to Parellel IP because it is not
> an incubation project
> - Widgets (Owners) part of Nebula-mature have to decide on releases
> dates (You can think of Nebula-mature-Release to something
> Galileo-Release for Eclipse but at our project level because all
> widgets are still quite independent though they are technically not
> Eclipse-Projects on their own)
> I hope this answers your question without answering the real question
> :-) so maybe I can summerize it:
> Yes you will see a stable release of Nebula-Grid in future (though I
> can't give you a final date) but it won't be part of SWT but part of the
> new Nebula-Mature project.
> Tom
> M. Luchian schrieb:
>> Hello,
>> to a full release?
>> Thanks,
>> Mircea
| Re: grid widget part of SWT [message #63025 is a reply to message #63024] |
Wed, 15 April 2009 17:24  |
I'd say the main API is stable and it hasn't changed since a long time.
We only added new API but didn't break any API contract since quite a
long time.
Tom
M. Luchian schrieb:
> Thank you Tom,
> Mircea
>> Hi Mircea,
>> the API is stable.
>> - Nebula-mature
>> - Nebula-incubation
>> the widgets
>> Tom
>> M. Luchian schrieb:
>>> Hello,
>>> to a full release?
>>> Thanks,
>>> Mircea
| Re: grid widget part of SWT [message #594427 is a reply to message #63010] |
Wed, 15 April 2009 14:53  |
Hi Mircea,
the API is stable.
- Nebula-mature
- Nebula-incubation
the widgets
Tom
M. Luchian schrieb:
> Hello,
> to a full release?
> Mircea
| Re: grid widget part of SWT [message #594446 is a reply to message #63022] |
Thank you Tom,
Mircea
> Hi Mircea,
> the API is stable.
> - Nebula-mature
> - Nebula-incubation
> the widgets
> Tom
> M. Luchian schrieb:
>> Hello,
>> to a full release?
>> Thanks,
>> Mircea
| Re: grid widget part of SWT [message #594453 is a reply to message #63024] |
long time.
Tom
M. Luchian schrieb:
> Thank you Tom,
> Mircea
>> Hi Mircea,
>> the API is stable.
>> - Nebula-mature
>> - Nebula-incubation
>> the widgets
>> Tom
>> M. Luchian schrieb:
>>> Hello,
>>> to a full release?
>>> Thanks,
>>> Mircea
FUDForum. Page generated in 0.04971 seconds
