Home » Eclipse Projects » Nebula » grid widget part of SWT
grid widget part of SWT [message #63010] Wed, 15 April 2009 11:33 Go to next message
Is there a plan to put the grid widget part of SWT API? In addition,
when would this widget become modified from ALPHA to BETA and from BETA
to a full release?
Mircea
Re: grid widget part of SWT [message #63022 is a reply to message #63010] Wed, 15 April 2009 14:53 Go to previous messageGo to next message
*[Disclaimer: This is my current personal view and has not been
discussed with all Nebula committers but this will follow immediately
after I posted the answer to this thread]*
Hi Mircea,
The initial indent of Nebula in the past has been to provide a
playground to explore new ways for widget who might migrate to SWT once
the API is stable.
In reality we had rethink this because none of our widget will ever get
part of the SWT release. Instead I think Nebula is going to provide a
place for reusable UI-Widgets who can't get part of SWT or JFace because
they only hold widgets used by the Eclipse-Platform.
With the latest contributions we added to Nebula we already made this
step reality (e.g. XViewer is a such a component, as well as the
RadioGroup widget) I see nebula more as a central place where
UI-Components get a place which are reusable outside the direct
project-scope they are developed in. So we are one answer to the ever
occurring "BLOAT" discussing when it comes to UI-Components.
This new focus implies to things:
a) instead of relying on the fact that once our widgets are mature we
need to split nebula into 2 projects:
- Nebula-mature
- Nebula-incubation
b) We make 1.0 releases of all widgets part of Nebula-mature
But it gives us new possibilities:
a) We have much more freedome when it comes to minor Java-Version we
need to support => We allow Java 5 API
b) We can define our own release train and time
But it also implies new working areas:
a) We need to work hard to get our widgets build => For most mature
widgets this is already reality (See our new download page)
b) We need to get out of people brains that our widgets are alpha/beta
whereas the reality is that they are extremly stable
c) We need better project management to coordinate the effort going into
the widgets
So what are the next things to happen is that:
- Widgets who get part of Nebula-mature get built
- Widgets who get part of Nebula-mature are IP clean
=> Nebula-mature will not have access to Parellel IP because it is not
an incubation project
- Widgets (Owners) part of Nebula-mature have to decide on releases
dates (You can think of Nebula-mature-Release to something
Galileo-Release for Eclipse but at our project level because all
widgets are still quite independent though they are technically not
Eclipse-Projects on their own)
I hope this answers your question without answering the real question
:-) so maybe I can summerize it:
Yes you will see a stable release of Nebula-Grid in future (though I
can't give you a final date) but it won't be part of SWT but part of the
new Nebula-Mature project.
Tom
M. Luchian schrieb:
> Hello,
> to a full release?
> Mircea
Re: grid widget part of SWT [message #63024 is a reply to message #63022] Wed, 15 April 2009 15:53 Go to previous messageGo to next message
Thank you Tom,
It's good to know that there is a custom widget library that gets mature
with time. Whether part of SWT or Nebula, it does not matter much for a
software engineer using the API. I have been looking in implementing a
grid similar to the one in nebula, however, seeing it exists in the
Alpha stage, I will certainly use it in my product once the API is stable.
Mircea
What matters more is the
> Hi Mircea,
> the API is stable.
> - Nebula-mature
> - Nebula-incubation
> the widgets
> Tom
> M. Luchian schrieb:
>> Hello,
>> to a full release?
>> Thanks,
>> Mircea
Re: grid widget part of SWT [message #63025 is a reply to message #63024] Wed, 15 April 2009 17:24 Go to previous message
I'd say the main API is stable and it hasn't changed since a long time.
We only added new API but didn't break any API contract since quite a
long time.
Tom
M. Luchian schrieb:
> Thank you Tom,
> Mircea
>> Hi Mircea,
>> the API is stable.
>> - Nebula-mature
>> - Nebula-incubation
>> the widgets
>> Tom
>> M. Luchian schrieb:
>>> Hello,
>>> to a full release?
>>> Thanks,
>>> Mircea
Re: grid widget part of SWT [message #594427 is a reply to message #63010] Wed, 15 April 2009 14:53 Go to previous message
Hi Mircea,
the API is stable.
- Nebula-mature
- Nebula-incubation
the widgets
Tom
M. Luchian schrieb:
> Hello,
> to a full release?
> Mircea
Re: grid widget part of SWT [message #594446 is a reply to message #63022] Wed, 15 April 2009 15:53 Go to previous message
Thank you Tom,
Mircea
> Hi Mircea,
> the API is stable.
> - Nebula-mature
> - Nebula-incubation
> the widgets
> Tom
> M. Luchian schrieb:
>> Hello,
>> to a full release?
>> Thanks,
>> Mircea
Re: grid widget part of SWT [message #594453 is a reply to message #63024] Wed, 15 April 2009 17:24 Go to previous message
long time.
Tom
M. Luchian schrieb:
> Thank you Tom,
> Mircea
>> Hi Mircea,
>> the API is stable.
>> - Nebula-mature
>> - Nebula-incubation
>> the widgets
>> Tom
>> M. Luchian schrieb:
>>> Hello,
>>> to a full release?
>>> Thanks,
>>> Mircea
Previous Topic:[Grid, GridViewer][PATCH] rowspan support
Next Topic:CDateTime used as cellEditor
Current Time: Tue Nov 25 21:50:54 EST 2025
Powered by FUDForum. Page generated in 0.08329 seconds
