Accessing included/imported XSD in App Server environment [message #62866] |
Fri, 09 September 2005 19:35  |
Originally posted by: vitrpp.netscape.net
I am planning to use XSD infoset model at runtime in app server environment.
I expect the schema files to deployed as part of the ear file. I am
wondering if I need to do anything specific when parsing schema so that any
included/imported schema can be located properly.
Can some one give more information or direct me to documentation?
thanks,
Prasad
Re: Accessing included/imported XSD in App Server environment [message #63102 is a reply to message #62866] |
Sun, 11 September 2005 19:25  |
--------------030305030801070807010400
Content-Type: multipart/alternative;
boundary="------------060200000903080302070704"
--------------060200000903080302070704
Prasad,
It's important to use an absolute URI for loading the resources if there
are any relative schema locations. If you have the attached jar at
c:/tmp, then the following would load the schema in that jar (and
resolves the relative schemaLocations correctly):
xsd-example.bat -validate
archive:file://c:/tmp/simple.jar!/folder/lib/library1.xsd
--> archive:file://c:/tmp/simple.jar!/folder/lib/library1.xsd
--> archive:file://c:/tmp/simple.jar!/folder/lib/library2.xsd
--> archive:file://c:/tmp/simple.jar!/folder/per/person.xsd
EMF's archive scheme (84327
<http://bugs.eclipse.org/bugs/show_bug.cgi?id=84327>) can even access
jars within jars.
archive:file://c:/tmp/simple.jar!/xsd.jar!/lib/library1.xsd
--> archive:file://c:/tmp/simple.jar!/xsd.jar!/lib/library1.xsd
--> archive:file://c:/tmp/simple.jar!/xsd.jar!/lib/library2.xsd
--> archive:file://c:/tmp/simple.jar!/xsd.jar!/per/person.xsd
Other URI schemes, such as jar or zip supported by the class loader,
work the same way. If your runtime uses a scheme other that zip, jar,
or archive, you need to make sure the EMF runtime knows about it: 67720
<http://bugs.eclipse.org/bugs/show_bug.cgi?id=67720>
>thanks,
>Prasad
<html>
<head>
<title></title>
</head>
Prasad,<br>
<br>
there are any relative schema locations. If you have the attached jar
at c:/tmp, then the following would load the schema in that jar (and
resolves the relative schemaLocations correctly): <br>
<blockquote>xsd-example.bat -validate
archive:<a class="moz-txt-link-freetext" href="file://c:/tmp/simple.jar!/folder/lib/library1.xsd">file://c:/tmp/simple.jar!/folder/lib/library1.xsd</a><br>
--> archive:<a class="moz-txt-link-freetext" href="file://c:/tmp/simple.jar!/folder/lib/library1.xsd">file://c:/tmp/simple.jar!/folder/lib/library1.xsd</a><br>
--> archive:<a class="moz-txt-link-freetext" href="file://c:/tmp/simple.jar!/folder/lib/library2.xsd">file://c:/tmp/simple.jar!/folder/lib/library2.xsd</a><br>
--> archive:<a class="moz-txt-link-freetext" href="file://c:/tmp/simple.jar!/folder/per/person.xsd">file://c:/tmp/simple.jar!/folder/per/person.xsd</a><br>
</blockquote>
EMF's archive scheme (<a target="_bugz"
href="http://bugs.eclipse.org/bugs/show_bug.cgi?id=84327">84327</a>)
can even access jars within jars.<br>
archive:<a class="moz-txt-link-freetext" href="file://c:/tmp/simple.jar!/xsd.jar!/lib/library1.xsd">file://c:/tmp/simple.jar!/xsd.jar!/lib/library1.xsd</a><br>
--> archive:<a class="moz-txt-link-freetext" href="file://c:/tmp/simple.jar!/xsd.jar!/lib/library1.xsd">file://c:/tmp/simple.jar!/xsd.jar!/lib/library1.xsd</a><br>
--> archive:<a class="moz-txt-link-freetext" href="file://c:/tmp/simple.jar!/xsd.jar!/lib/library2.xsd">file://c:/tmp/simple.jar!/xsd.jar!/lib/library2.xsd</a><br>
--> archive:<a class="moz-txt-link-freetext" href="file://c:/tmp/simple.jar!/xsd.jar!/per/person.xsd">file://c:/tmp/simple.jar!/xsd.jar!/per/person.xsd</a><br>
</blockquote>
or archive, you need to make sure the EMF runtime knows about it: <a
target="_bugz"
href="http://bugs.eclipse.org/bugs/show_bug.cgi?id=67720">67720</a><br>
<br>
<br>
<blockquote cite="middft67u$qab$1@news.eclipse.org" type="cite">
<pre wrap="">I am planning to use XSD infoset model at runtime in app server environment.
thanks,
Prasad
</pre>
</blockquote>
<br>
</body>
</html>
--------------060200000903080302070704--
Content-Type: application/octet-stream;
name="simple.jar"
Content-Disposition: attachment;
filename="simple.jar"
UEsDBBQACAAIADxPKzMAAAAAAAAAAAAAAAAJAAQATUVUQS1JTkYv/soAAAMA UEsHCAAAAAAC
AAAAAAAAAFBLAwQUAAgACAA8TyszAAAAAAAAAAAAAAAAFAAAAE1FVEEtSU5G L01BTklGRVNU
Lk1G803My0xLLS7RDUstKs7Mz7NSMNQz4OVyLkpNLElN0XWqBAmY6BkqaHg6 +So45xcV5Bcl
lgAVavJy8XIBAFBLBwg37y60PQAAAD4AAABQSwMECgAAAAAAOE4rMwAAAAAA AAAAAAAAAAcA
AABmb2xkZXIvUEsDBAoAAAAAADBNKzMAAAAAAAAAAAAAAAALAAAAZm9sZGVy L2xpYi9QSwME
FAAIAAgAFE4rMwAAAAAAAAAAAAAAABcAAABmb2xkZXIvbGliL2xpYnJhcnkx LnhzZK2RzU7D
MBCE75X6DpbvxGm5oKhpJSQ4lR+JIrg6ztJaxHawHZK+PRsnKWkp4sIlUlbf eGZnF6tGFeQT
rJNGp3QWxZSAFiaXepvS583txRVdLaeTRePyxIkdKE6mE0I8t1vw91yBK7mA lO68LxPG6rqO
oOGqLCASRrG1zCy3e9pq0Em7BISxJ7woZOkgMnbLQL2xeRzP2U2LjWQl2F9N HjG+0ZR804XM
/ow0wnG5I7y+DGEwyIy93q2fwt4Ua2gloQqpRVHlQLpK1kZwHwosusfnEUKU jRVQgALticbO
Dhwlfl92v8mQ60iFgTF3s0GqVw7YsmV6ysFHhVeDfnbWsf0OdkHjLd44uJ3R KN48CFFZl9JK
Z6bSOeSUKKmHaUwHHekNMmPe3Xihaxz84/u1lR4PPXZ4CaODx4L9KKMbjVoM 5fZguB0OvgBQ
SwcIezwtE0gBAAAFAwAAUEsDBBQACAAIAPJNKzMAAAAAAAAAAAAAAAAXAAAA Zm9sZGVyL2xp
Yi9saWJyYXJ5Mi54c2SNlE1v2zAMhu8F+h8E3Wen3WUw4hZosAIF0m5YW2xX WWEdodbHJLlx
/v0o24lV200XwBeaL/nyIZ3ldSMr8gbWCa1yepEsKAHF9UaoMqfPT7dfvtHr q/OzZeM2meNb
kIycnxHimS3BPzAJzjAOOd16b7I03e12CTRMmgoSrmW6FoVldk+DBjsplwHX dpTPK2EcJNqW
KciX9HKxuEy/h7RIZsB+2OQn2teKkiG7EsWnlqJ0HO5d+u5rawaNXKR/7teP 7dwUMQRJi0JI
o60n6lMAB28du7XmzLekkyTFkcKDrxMsSdO4PkqxQvO0N9A2yemN1q/BAiF9 ioO/Na4K+lgf
hQokKN+LvPAVUOKxTE5bkbe42bbXhyLDSnCxSCh/WoFDQakD006E+LPgd3WI n1Sz2m+1jRsy
tX/+dddtqPu1V5NZeAEbZkaTYLPfVnhAYfdSG6MdBnJaYGt37LlMJ7S6UMQ4 Ru9ECI/IHyeJ
N2Ah4ORhoaRgrjf/sAqfBR1NrGoJtt09eWNVjbn3e4fup2ymmY9cBOu3Xav/ ENwIXVpmtvsR
hMhwxGEY+PQF9rhjAn3SSiuP+xz5ajDmBjZhY/3XcDUsdv6UJ5ciWfOD89q6 nNaq0LXawIYS
KdQhuqCxlvSWu0uYuazJPR1ONqI7ezpD+DjfO8QzROavra/d/i1g4B9QSwcI HSdK5QECAACJ
BQAAUEsDBAoAAAAAADNNKzMAAAAAAAAAAAAAAAALAAAAZm9sZGVyL3Blci9Q SwMEFAAIAAgA
hE0rMwAAAAAAAAAAAAAAABUAAABmb2xkZXIvcGVyL3BlcnNvbi54c2SFkL1O AzEQhPtIeQdr
e24voUGnOKmgAoREkGgtZ3M56fyDbbjj7VkbIwIUNC5GM59ndrObzSjeKMTB WQmrpgVBVrvD
YHsJT/ubiyvYbZeLzRwPXdQnMkosF0IkFXpK98pQ9EqThFNKvkOcpqmhWRk/ UqOdwQcmOws5
wh/Z2JF24Zddj4OP1LjQI5kjrtt2jdfZdhbzFP77Q3y7uewP93RZ6Exe4fPd 7WPZATwrR8o0
5jBu3r97EpZXSajUbbZUU6SXVz4OVa2qNJIhm2osvyAScySUTAp8SsAvDv4B fUpnBUqvaixN
WfgAUEsHCI5lawboAAAAqAEAAFBLAwQUAAgACAA4TyszAAAAAAAAAAAAAAAA BwAAAHhzZC5q
YXIL8GZmEWHgAEILf21jBiTAycDC4Osa4qjr6eem/+8UAwMzQ4A3OwdIigmq JACnZhEghmv2
dfTzdHMNDtHzdfvse+a0j7eu3kVeb12tc2fObw4yuGL84GmRnpevjqfvxdJV LJwzXkhqZVRY
/dSyeC4u+kRcdRqDaNanoo9FjGDrzd/rbbEFGm4HtZ4LbJ2BL6r1LECck5mk j3CgiB+qCgGo
CiAuSiyqNNSrKE5ZO/Gs32EDgZb3U3/xTXt/JHPnghWZqioWU+U7lXZYnbsU daRsg+ykfbbS
6pqZmo8OqQaF3a9ISxdf7Sb6RHjNZLflJWJHpzSIqU2vmn3p+dm3R0VjdZdP dn386UinrIbf
MmEnm+3RH77HNGrvbJjybo++8LFXu/oWPFyloyDktnHrGZ3t1beyLnjuZmnZ qL5HI+WlglHZ
aYe9Gytlzt/07e5NUb0R7ytnuO/ilJrLrWf+9ZgcKtypvGcfT6LBiZ6999bO P3RPJDtDdSHX
StfApw67vK65Fchz6ew6/lzQaUqvaEAD09vOY+f4ZFTr4sv2n5zw2qO10bB8 s+OqcL4bm1Kr
Th10bw1vriu7tvEvX5njY917FjvmXtS4Z8MRGDn9klf6skuWT6ZorGzP9GGX fclrlHzvbsXC
bJk/j39vnSrHb1tWwbm4+XjTX43F0r1RPE+/JeyQ5dsHjqdqG11hD0YGBlZm 5GTyyRdvLBiB
YqF3im/+bQOetvesv+RZ7qYvv5tq8EgsYwMT66W8iOic8MhE2YXXjqvsLPz3 V+N2Z+htX/ED
4rP0f35SnPu0VFn7E9s1zrVFVRN1NBiPfnVbYbT8vP/2+H0XX6/+vDn1sdnM x9ETeubMF3w0
U/egvQHnOQM+y7tV+ZtM7r4t4zTxmcUltC51l1hrapl/M5u15nTG62VTzmsn yqjcmqZ5YvqX
oo07fPa3b/FIO1B344n6retdkxR3Cx1dPm1Ricy72F/vsrPZemOW1L+73v/2 joghi2e3k8fi
teqvghnY82V3b312ZvuSySpHJx5qXi+s43l5h53XRqfPW8wvmJ182Xtt/UEm xdqu5v2m67h+
Rci3cqlo3O/e80E04NFGH7/oidt33Nx2vV3psFfBRg+N+qhGZ8eVzJf9Wn5s flBe2jE/ZPOt
/K290kZb6/+VXs9d8Xtr+OTICkbpNLfJCZvvh1U4JH4Pkl4sy1YUlZBd/man j/qWXQFHLNze
u3D0n5BX7zRPUHzwJHHhkoR15v83cM1nlfVdk8W57a5tZXJo787v1e3vlucs m9kfw/J6e+zq
/wJ3OGKj0rb9Fmw5UXAkUeLHF9ZvO5KZai95aff/lvmZZfCMzSwx+e/1AlOd sn9T1KcrRX5u
/nxr15xrqy5svXWgTUjziuKuBRunfZm223vGzjUnbWX9zBZZV1s5/7C4b33E 2OXZ+rXr7/7T
TXggD0o+supeTxmBxUwnK3I2N8aSzQtSi5CyeQuaCj6oCiAuzs8DJa/WCXv9 mA0FWn57VLJn
V+fpL3RcbrFyAVOLy4QM3fRiy5d/mnN3PH4bKa3MJGKi52Y8P71s8+yzGvc0 jhyM5Fy9jNUx
bPfhhGpO/9+zu7Vv5E7vPivDH3tF3chLR9xJRbTK6/upgC9ek1uCvfY5z1m2 cmGkpH3Q4rkH
2dWsuS0Pyd+8MbHs4fTY/ub+KzsuKM9UXne7rPf6zTKxzyL/fjvX7N75hv97 SeQLn7iHn+++
Tb7JaKPtfsrkmUHevf3VQtPCPVdcyd0WErxkergdX+jaVSaTFGdn6exXECpW meLDVeN1QJ/v
H2OtVzqr1/osHd/IH+BM2JeazfYCGAIrGEGhyMgkwoBaWsPKcU5wSCIDlIIf XStyGSyCos0W
R7EPMoGLAXdZjQB74CU3wk5Q2Y1cngig6LiHpSRH1g0qc5CTE6ruFCbMEgjZ tdiSHAIsZoEl
QIR9oCSIHPB8KDqOsqAnyABvVjaQDDsQzgSqf8kK4gEAUEsHCMsIvB3RBQAA mAcAAFBLAQIU
ABQACAAIADxPKzMAAAAAAgAAAAAAAAAJAAQAAAAAAAAAAAAAAAAAAABNRVRB LUlORi/+ygAA
UEsBAhQAFAAIAAgAPE8rMzfvLrQ9AAAAPgAAABQAAAAAAAAAAAAAAAAAPQAA AE1FVEEtSU5G
L01BTklGRVNULk1GUEsBAgoACgAAAAAAOE4rMwAAAAAAAAAAAAAAAAcAAAAA AAAAAAAAAAAA
vAAAAGZvbGRlci9QSwECCgAKAAAAAAAwTSszAAAAAAAAAAAAAAAACwAAAAAA AAAAAAAAAADh
AAAAZm9sZGVyL2xpYi9QSwECFAAUAAgACAAUTiszezwtE0gBAAAFAwAAFwAA AAAAAAAAAAAA
AAAKAQAAZm9sZGVyL2xpYi9saWJyYXJ5MS54c2RQSwECFAAUAAgACADyTSsz HSdK5QECAACJ
BQAAFwAAAAAAAAAAAAAAAACXAgAAZm9sZGVyL2xpYi9saWJyYXJ5Mi54c2RQ SwECCgAKAAAA
AAAzTSszAAAAAAAAAAAAAAAACwAAAAAAAAAAAAAAAADdBAAAZm9sZGVyL3Bl ci9QSwECFAAU
AAgACACETSszjmVrBugAAACoAQAAFQAAAAAAAAAAAAAAAAAGBQAAZm9sZGVy L3Blci9wZXJz
b24ueHNkUEsBAhQAFAAIAAgAOE8rM8sIvB3RBQAAmAcAAAcAAAAAAAAAAAAA AAAAMQYAAHhz
ZC5qYXJQSwUGAAAAAAkACQAmAgAANwwAAAAA
--------------030305030801070807010400--
Re: Accessing included/imported XSD in App Server environment [message #596290 is a reply to message #62866] |
Prasad,
jars within jars.
>thanks,
>Prasad
<html>
<head>
<title></title>
</head>
Prasad,<br>
<br>
</blockquote>
</blockquote>
target="_bugz"
<br>
<br>
thanks,
Prasad
</pre>
</blockquote>
<br>
</body>
</html>
name="simple.jar"
FUDForum. Page generated in 0.06860 seconds
