Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Transaction] Command is not executed
[Transaction] Command is not executed [message #62858] Mon, 27 November 2006 10:47 Go to next message
Originally posted by: wah.zurich.ibm.com
I would like to add a constraint to a UML class. However, I have not
found a tutorial on the transaction API, so I've done some
trial-and-error. Sadly, I stopped with an error.
Here's my code. The problem is that the execute() method is never invoked.
Any help appreciated!
Michael
TransactionalEditingDomain editDomain =
TransactionUtil.getEditingDomain(targetClass);
editDomain.getCommandStack().execute(new
org.eclipse.emf.common.command.AbstractCommand() {
public void execute() {
targetClass.getOwnedRules().add(constraint);
public void redo() {
// TODO
editDomain.getCommandStack().flush();
Re: [Transaction] Command is not executed - solved [message #62869 is a reply to message #62858] Mon, 27 November 2006 10:53 Go to previous messageGo to next message
I just replaced AbstractCommand with RecordingCommand, and now it's working!
One more question: Is is necessary at all to invoke flush() on the
command stack?
Michael Wahler wrote:
> Michael
Re: [Transaction] Command is not executed - solved [message #62875 is a reply to message #62869] Tue, 28 November 2006 10:02 Go to previous message
Hello, Michael,
You didn't actually need to use the RecordingCommand. What you forgot to do
in your AbstractCommand was to override the default implementation of
prepare() to return something other than false (i.e., true). Unless you do
that, the command will not be executable, and the command stack will refuse
to execute it. The RecordingCommand overrides prepare() to return true by
default, because it assumes that subclasses won't have anything to prepare.
You shouldn't need to flush the command stack unless you actually don't want
any of its history to be undoable.
Christian
> working!
> command stack?
>> invoked.
>> Michael
Re: [Transaction] Command is not executed - solved [message #596242 is a reply to message #62858] Mon, 27 November 2006 10:53 Go to previous message
command stack?
> Michael
Re: [Transaction] Command is not executed - solved [message #596251 is a reply to message #62869] Tue, 28 November 2006 10:02 Go to previous message
Hello, Michael,
Christian
> working!
> command stack?
>> invoked.
>> Michael
Previous Topic:[Transaction] Command is not executed
Next Topic:Can Validation handle inter-model constraints?
Current Time: Sat Jul 12 19:30:43 EDT 2025
Powered by FUDForum. Page generated in 0.04674 seconds
