Home » Language IDEs » Java Development Tools (JDT) » [CORE] ClassInstanceCreation grammar question
[CORE] ClassInstanceCreation grammar question [message #62854] Fri, 20 June 2003 11:19 Go to next message
Given:
ClassInstanceCreation:
[ Expression . ] new TypeName
( [ Expression { , Expression } ] )
[ AnonymousClassDeclaration ]
as the grammar for a ClassInstanceCreation per the JavaDoc in
ClassInstanceCreation,
I'm confused about what valid Java code would parse using the initial
[ Expression . ]
part of the grammar. Or even where I would go to find out.
I'd be most appreciative if someone could just post an example of valid
Java code that would parse using that optional Expression dot at the
beginning of that grammar.
Thanks much in advance,
Dave
Dave Orme
Advanced Systems Concepts
http://www.swtworkbench.com
Re: [CORE] ClassInstanceCreation grammar question [message #63224 is a reply to message #62854] Fri, 20 June 2003 11:56 Go to previous messageGo to next message
Is this kind of example you're looking for?
public class A {
public class B {
public class C {
void foo() {
public static void main(String args[]) {
new A().new B().new C().foo();
"David J. Orme" <daveo@asc-iseries.com> wrote in message
news:bcv8lg$ug0$1@rogue.oti.com...
> Given:
> [ Expression . ]
> Dave
> Dave Orme
Re: [CORE] ClassInstanceCreation grammar question [message #64099 is a reply to message #63224] Sat, 21 June 2003 17:04 Go to previous message
> public class A {
> public class B {
> public class C {
> void foo() {
Yes, perfect! Thanks.
Dave
Previous Topic:Verifier Related HotSwap Bug
Next Topic:Run configuration display in favorites menu?
Current Time: Tue Nov 11 01:38:05 EST 2025
Powered by FUDForum. Page generated in 0.03939 seconds
