Home » Eclipse Projects » Nebula » CDateTime issues since 26 January?
CDateTime issues since 26 January? [message #62844] Wed, 18 February 2009 04:10 Go to next message
I've checked out the CDateTime project from the eclipse CVS and got it
working in my application on the 26 January.
I did that becouse the old CDateTime I've used would't work correctly a
Vista system (the menu bar would dissapear under a white bar after the
drop down composite would show).
The 26 January version I got from the eclipse CVS corrected this problem
but I had other issues:
- If I would open and close the drop down 4 times in a row by clicking
on the botton (aka arrow button in a normal combo) then the CDateTime
would start to preselect days (Ex it would auto-select the day 21 and if
I pressed on 15 without going with the mouse over 21 a priori then it
would still select the 21rst day of that date - it could trick the user
that he selected the 15 but actually the CDateTime selected 21 or so;
note that after the 4th drop of the combo the date that it
'auto-selected' kept changing circulary following a diagonal pattern
parallel with the secondary diagonal of the square)
- moreover if I tried to use the arrows on the keyboard to change the
selection then the whole app would freeze
I did a compare with the date 26 january to check weather there have
been changes that could correct this but I would like to check with you
if these issues are already corrected or can otherwise be workedaround.
For now I rolled back to the old CDateTime and miss the chance to run my
app on a Vista box.
Please advice.
Liviu
Re: CDateTime issues since 26 January? [message #62870 is a reply to message #62844] Thu, 19 February 2009 08:23 Go to previous messageGo to next message
Hi Liviu,
Thanks for the excellent and thorough description of this problem. The
first actually sounds like an internal focus problem - do these issues
happen on XP or is it specific to Vista?
Please file a bug for each of these and I'll try to get to them shortly
- I just haven't had time to run Vista lately.
Liviu wrote:
> Hello,
> app on a Vista box.
> Please advice.
> Liviu
Re: CDateTime issues since 26 January? [message #62876 is a reply to message #62870] Thu, 19 February 2009 13:17 Go to previous messageGo to next message
Hi Jeremy,
They happen on XP.
I only tested on Vista that it would not kill the menu bar and it didn't
but on XP I had that focus problem you identified.
I did not test on vista for those bugs. I may do so next week
(Monday-Tuesday?).
I will file the bugs in about 20 hours.
Liviu
Jeremy Dowdall wrote:
> Hi Liviu,
> Liviu wrote:
>> Hello,
>> app on a Vista box.
>> Please advice.
>> Thanks,
>> Liviu
Re: CDateTime issues since 26 January? [message #62897 is a reply to message #62876] Mon, 02 March 2009 10:54 Go to previous messageGo to next message
Hi Jeremy,
I forgot to tell you my hours tend to be quite long sometimes.
Here are the bugs:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=266694
https://bugs.eclipse.org/bugs/show_bug.cgi?id=266698
I'd offer my time to correct this but I don't really know where to
start; on the other hand my client has already moved some systems on
Vista and, you guessed it, I'm rather desperate.
Please advice.
Liviu
Liviu wrote:
> Hi Jeremy,
> They happen on XP.
> (Monday-Tuesday?).
> Thanks
> Liviu
>> Hi Liviu,
>> Liviu wrote:
>>> Hello,
>>> app on a Vista box.
>>> Please advice.
>>> Thanks,
>>> Liviu
Re: CDateTime issues since 26 January? [message #62900 is a reply to message #62897] Mon, 02 March 2009 20:08 Go to previous message
no problem, that happens :)
thanks for filing the bugs, I'll follow up there...
Re: CDateTime issues since 26 January? [message #593734 is a reply to message #62844] Thu, 19 February 2009 08:23 Go to previous message
Hi Liviu,
Liviu wrote:
> Hello,
> app on a Vista box.
> Please advice.
> Liviu
Re: CDateTime issues since 26 January? [message #593746 is a reply to message #62870] Thu, 19 February 2009 13:17 Go to previous message
Hi Jeremy,
They happen on XP.
(Monday-Tuesday?).
Liviu
> Hi Liviu,
> Liviu wrote:
>> Hello,
>> app on a Vista box.
>> Please advice.
>> Thanks,
>> Liviu
Re: CDateTime issues since 26 January? [message #593826 is a reply to message #62876] Mon, 02 March 2009 10:54 Go to previous message
Hi Jeremy,
Here are the bugs:
Please advice.
Liviu
Liviu wrote:
> Hi Jeremy,
> They happen on XP.
> (Monday-Tuesday?).
> Thanks
> Liviu
>> Hi Liviu,
>> Liviu wrote:
>>> Hello,
>>> app on a Vista box.
>>> Please advice.
>>> Thanks,
>>> Liviu
Re: CDateTime issues since 26 January? [message #593834 is a reply to message #62897] Mon, 02 March 2009 20:08 Go to previous message
Previous Topic:GridTableViewer and sorting
Next Topic:GridViewer - Getting notifed when a record gets invisible through vertical scrolling
Current Time: Sat Nov 22 01:26:52 EST 2025
Powered by FUDForum. Page generated in 1.04646 seconds
