Home » Modeling » M2T (model-to-text transformation) » [JET] Problem with Jet editor in 3.5 RC4
[JET] Problem with Jet editor in 3.5 RC4 [message #62729] Wed, 24 June 2009 07:48 Go to next message
Originally posted by: sderrienREMOVE.irisa.fr
I recently upgraded to Eclipse 3.5RC1 to be able to play with the Xtext
software, and noticed that the Jet editor provided with the m2t project
does not wor anymore (Exception when trying to open a .jet file).
Is anybody experienced or if aware of this issue (it seems that the jet
editor source have not been modified for quite some time) ?
Thanks in advance,
Steven
Re: [JET] Problem with Jet editor in 3.5 RC4 [message #62794 is a reply to message #62729] Wed, 24 June 2009 09:32 Go to previous messageGo to next message
Steven:
Can you submit a bugzilla. Attaching any stack traces you can find would
be useful:
https://bugs.eclipse.org/bugs/enter_bug.cgi?assigned_to=m2t. jeteditor-inbox%40eclipse.org&bug_file_loc=http%3A%2F%2F &bug_severity=normal&bug_status=NEW&comment=& ;component=Jet
Editor&contenttypemethod=autodetect&contenttypeselec tion=text%2Fplain&flag_type-1=X&flag_type-2=X&fl ag_type-4=X&flag_type-6=X&flag_type-7=X&flag_typ e-8=X&flag_type-9=X&form_name=enter_bug&maketemp late=Remember
values as bookmarkable template&priority=P3&product=M2T&version=1.0.0
Paul Elder
Steven Derrien wrote:
> Hello,
> Thanks in advance,
> Steven
Re: [JET] Problem with Jet editor in 3.5 RC4 [message #62811 is a reply to message #62794] Fri, 26 June 2009 08:19 Go to previous messageGo to next message
Bug submitted. Thanks for the advice.
Steven
Paul Elder a écrit :
> Steven:
> be useful:
> Paul Elder
>> Hello,
>> Xtext software, and noticed that the Jet editor provided with the m2t
>> project does not wor anymore (Exception when trying to open a .jet file).
>> jet editor source have not been modified for quite some time) ?
>> Thanks in advance,
>> Steven
Re: [JET] Problem with Jet editor in 3.5 RC4 [message #481066 is a reply to message #62729] Wed, 19 August 2009 09:44 Go to previous message
Originally posted by: diego.frei.icimsi.REMOVE.ch
we are experiencing the same problem after switching from Ganymede
to Galileo and installing the JET Editor + JET SDK from the
"install new software" menu. The stacktrace we get matches the one
Steven has already reported on bugzilla at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=281619
Installing the All-In-One package with the JET Capabilities doesn't fix
the problem either. With this setup if we try to open a jet template it
will keep opening it with the text editor and if we force to open it
with the JET Editor (by selecting open with->others->JET Editor) the
editor will fail to load with the same NullPointerException reported
previously. Moreover the All-In-One package hides the "JET
Transformation" panel and the Capabilities from the Preference window.
We have already tried to replace the new JET Editor (version 1.0.0) with
the last one working for us (version 0.9.1.v200901261702) but the
plugin just won't get loaded.
Is there any workaround or quickfix to get the old JET Editor
up and running in order to avoid editing the jet templates with the text
editor?
Thanks in advance,
Diego Frei
> Hello,
> Thanks in advance,
> Steven
Previous Topic:[XPAND] analyzing Xpand/Xtend projects
Next Topic:jet xpath expression to reference properties on an object valued model attribute
Current Time: Sun Jul 27 01:24:11 EDT 2025
Powered by FUDForum. Page generated in 0.03995 seconds
