Validating XML doc against its Schema [message #62682] |
Tue, 02 August 2005 04:39  |
Originally posted by: smahon.ittalks.co.uk
I want to validate an XML document against its Schema and was wondering
what was the best way to go about this. Would it be to model the document
using EMF, to convert the document into Java Objects using JAXB, simply to
use DOM or is there any other methods.
Any suggestions are appreciated.
Shane
Re: Validating XML doc against its Schema [message #62706 is a reply to message #62682] |
Tue, 02 August 2005 09:33  |
Shane,
If you simply want validation of a document against a schema, using JAXP
seems like a good way to go. Converting to Ecore and using EMF's
validation support makes sense if you will be using the generated model
code for other purposes too, but seems like a bit overkill if validation
is the only goal.
shane wrote:
> wondering what was the best way to go about this. Would it be to
> model the document using EMF, to convert the document into Java
> Objects using JAXB, simply to use DOM or is there any other methods.
> Shane
Re: Validating XML doc against its Schema [message #596181 is a reply to message #62682] |
Shane,
is the only goal.
shane wrote:
> Shane
FUDForum. Page generated in 0.05265 seconds
