Home » Eclipse Projects » Equinox » multiple versions of one bundle
multiple versions of one bundle [message #62672] Mon, 27 February 2006 12:08 Go to next message
Originally posted by: chs.tipas.at
our application has multiple ui-plugins which requires some basic plugins.
for this basic plugins multiple versions are requrired, due to the different
dependencies from ui-plugins to different versions of the base plugins.
does the equinox platform stable support multiple versions of plugins to be
installed and activated within the same jvm ?
thanks!
chris
Re: multiple versions of one bundle [message #62696 is a reply to message #62672] Mon, 27 February 2006 16:33 Go to previous messageGo to next message
Yes, it will support that. It's actually a feature required by the OSGi
spec.
You should set this up so that the ui-plugins require specific version
ranges of the packages they import and the base plugins export the
packages with versions in those ranges. Equinox will sort out which
package lives where and wire the bundles together. Make sure that the
import range has an upper limit, because the plugins are wired to the
export with the highest compatible version. If you don't specify an
upper limit, all versions higher than the version mentioned are
considered matching.
Harald
Re: multiple versions of one bundle [message #62720 is a reply to message #62696] Tue, 28 February 2006 02:56 Go to previous messageGo to next message
yes of course the ui plugins will search the dependencies with version aware
settings.
the important thing would be, can there be different concurrent bundles
activated at the same time within one jvm ?
"Harald Niesche" <harald@brokenerror.de> schrieb im Newsbeitrag
news:dtvr7r$3jb$1@utils.eclipse.org...
>> plugins.
>> different
>> be
> spec.
> Harald
Re: multiple versions of one bundle [message #62743 is a reply to message #62720] Tue, 28 February 2006 08:35 Go to previous messageGo to next message
Yes. This is detailed in the OSGi specification.
Jeremy Volkman
Re: multiple versions of one bundle [message #62765 is a reply to message #62672] Tue, 28 February 2006 19:27 Go to previous messageGo to next message
Originally posted by: alex_blewitt.yahoo.com
As several people have noted yes, this does work (even in the same VM). Each bundle gets its own classloader, so two bundles can load the same named bundle but a different version.
However, make sure that you put both a lower and upper vesion on the bundle dependency, otherwise it will take the highest one available. For example, if you were using Xerces 2.5 in one and Xerces 2.6 in another, you'd have to have:
Requires-Bundle: org.apache.xerces;bundle-version="[2.5.0,2.6.0)"
and
Requires-Bundle: org.apache.xerces;bundle-version="[2.6.0,2.7.0)"
in each of the two plugins. Without it, both would just jump to the highest version of Xerces 2.6 installed at the time. (The [ syntax means 'from' and the ) syntax means 'up to but not including' in laymans terms. In mathematical terms they are an open range and a closed range ;-)
Alex.
PS Eclipse doesn't come with an org.apache.xerces bundle but you can substitute your own example in place of xerces.
Re: multiple versions of one bundle [message #62849 is a reply to message #62765] Wed, 01 March 2006 06:01 Go to previous message
thanks for tthis information!
the example is already under test now. i will post some feedback if we find
any open limitations or bugs.
thanks.
chris
"Alex Blewitt" <alex_blewitt@yahoo.com> schrieb im Newsbeitrag
news:23800214.1141172911145.JavaMail.root@cp1.javalobby.org...
> you'd have to have:
> and
> Alex.
Previous Topic:How do I determine the contributing bundle for a given extension
Next Topic:Eclipse 3.2 M4 or M5 + Webstart -> Impossible !
Current Time: Thu Jul 17 21:42:37 EDT 2025
Powered by FUDForum. Page generated in 0.14266 seconds
