multiple versions of one bundle [message #62672] |
Mon, 27 February 2006 12:08  |
Originally posted by: chs.tipas.at
our application has multiple ui-plugins which requires some basic plugins.
for this basic plugins multiple versions are requrired, due to the different
dependencies from ui-plugins to different versions of the base plugins.
does the equinox platform stable support multiple versions of plugins to be
installed and activated within the same jvm ?
thanks!
chris
Re: multiple versions of one bundle [message #62765 is a reply to message #62672] |
Tue, 28 February 2006 19:27   |
Originally posted by: alex_blewitt.yahoo.com
As several people have noted yes, this does work (even in the same VM). Each bundle gets its own classloader, so two bundles can load the same named bundle but a different version.
However, make sure that you put both a lower and upper vesion on the bundle dependency, otherwise it will take the highest one available. For example, if you were using Xerces 2.5 in one and Xerces 2.6 in another, you'd have to have:
Requires-Bundle: org.apache.xerces;bundle-version="[2.5.0,2.6.0)"
and
Requires-Bundle: org.apache.xerces;bundle-version="[2.6.0,2.7.0)"
in each of the two plugins. Without it, both would just jump to the highest version of Xerces 2.6 installed at the time. (The [ syntax means 'from' and the ) syntax means 'up to but not including' in laymans terms. In mathematical terms they are an open range and a closed range ;-)
Alex.
PS Eclipse doesn't come with an org.apache.xerces bundle but you can substitute your own example in place of xerces.
Re: multiple versions of one bundle [message #62849 is a reply to message #62765] |
Wed, 01 March 2006 06:01  |
thanks for tthis information!
the example is already under test now. i will post some feedback if we find
any open limitations or bugs.
thanks.
chris
"Alex Blewitt" <alex_blewitt@yahoo.com> schrieb im Newsbeitrag
news:23800214.1141172911145.JavaMail.root@cp1.javalobby.org...
> you'd have to have:
> and
> Alex.
FUDForum. Page generated in 0.04327 seconds
