Home » Eclipse Projects » GEF » dragging outside area
dragging outside area [message #62655] Thu, 06 February 2003 10:28 Go to next message
Originally posted by: g.wagenknecht.intershop.de
I have some trouble with dragging above or left from the visible area.
In the logic example only the scrollbars are updated. In my editor the whole
root figure is moved together with the scroll bars update. I don't
understand why.
Any ideas?
Thanks, Gunnar
Re: dragging outside area [message #62680 is a reply to message #62655] Thu, 06 February 2003 11:00 Go to previous messageGo to next message
Are you using the FreeformRootEditPart?
"Gunnar Wagenknecht" <g.wagenknecht@intershop.de> wrote in message
news:b1ttil$fn$1@rogue.oti.com...
whole
> understand why.
> Any ideas?
> Thanks, Gunnar
Re: dragging outside area [message #62703 is a reply to message #62680] Thu, 06 February 2003 11:29 Go to previous messageGo to next message
"Randy Hudson" <none@us.ibm.com> schrieb im Newsbeitrag
news:b1tvf3$2ac$1@rogue.oti.com...
No, ScalableFreeformRootEditPart.
Cu, Gunnar
Re: dragging outside area [message #64213 is a reply to message #62680] Tue, 11 February 2003 07:45 Go to previous message
The graphical viewer is exactly initialized like the logic example. The
first difference is the "LogicDiagramEditPart". My main EditPart uses a
figure inherited from "FreeformLayer" with my own layout to display a grid.
Cu, Gunnar
Previous Topic:Logic Example
Next Topic:Caching Edit Parts
Current Time: Fri Nov 07 11:05:06 EST 2025
Powered by FUDForum. Page generated in 0.03921 seconds
