Home » Language IDEs » Java Development Tools (JDT) » How to validate a NumberLiteral semantically?
How to validate a NumberLiteral semantically? [message #62651] Fri, 20 June 2003 04:01 Go to next message
Originally posted by: taciano.tres.first.fraunhofer.de
Hi All!
I'm parsing a piece of code using AST.parseCompilationUnit(...), and
getting the result, everything OK.
My problem is that when I parse a code like:
String aNumber = "1" + Double.MAX_VALUE; // generates the String
//11.7976931348623157E308, that is not a valid double value (JLS 3.10.2)
String classString =
"public class SampleClass {"
+ " public double atributte = " + aNumber + ";"
CompilationUnit cu = AST.parseCompilationUnit(classString.toCharArray());
As AST means (Abstract SYNTAX Tree), that code works without problems,
and I get a CompilationUnit without messages or problems.
But I need to "validate" the value of aNumber "semanticaly", i. e., I
have to know if the NumberLiteral in the AST contains a valid number in
the Java language.
There's a simple way to do this?
Thaks for any help!
Taciano Tres
taciano.tres@first.fraunhofer.de
Re: How to validate a NumberLiteral semantically? WORKAROUD! [message #66776 is a reply to message #62651] Wed, 25 June 2003 03:57 Go to previous message
If someone has the same problem, here goes my workaround:
Use the source code inside the methods "computeConstant()" in the
classes IntLiteral, LongLiteral, FloatLiteral and DoubleLiteral, all on
package "org.eclipse.jdt.internal.compiler.ast". Its a internal package,
so copy the method body inside the class you are writing. Cause this
solves a problem unrelated with Eclipse, the code don't need to be
replaced each time a new release is available.
Inside this package is also possible to find anothers "checks" for the
AST nodes.
If someone has a better idea, I'm glad to listen.
Taciano Tres
Previous Topic:Modifying format of Template Variables
Next Topic:About start up plugin! Thx
Current Time: Fri Oct 24 09:41:49 EDT 2025
Powered by FUDForum. Page generated in 0.03742 seconds
