Home » Eclipse Projects » Equinox » How to embedded the OSGi framework into the standalone application?
How to embedded the OSGi framework into the standalone application? [message #62647] Mon, 27 February 2006 04:48
hi,
we are prepare to use the OSGi framwork as the extension framework in
our appliction. The architecture of the application looks like:
Plugins implement the extenion point
OSGi framwork (used to load the extensions)
Main application (load the OSGi framework, get the extensions from the
framework)
The problem is how should we get the plugins loaded by the OSGi framwork.
It seems that the BundleContext can only be accessed in the bundle itself.
The outside codes like our Main Application can't get the loaded
extensions.
In a more common case, The main application can define a service
interface, the interface is implemented by the plugins in the OSGi
framework. The main application can't get the service registed by the
plugin from ourside the framework.
In Eclipse 3.2 M2, we can use the private field "context" defined in the
EclipseStarter to install/access/uninstall the bundle. Is there a public
API to support this feaure or do we have a plan to support such a feature?
Previous Topic:JSP compiler / Jasper bundle
Next Topic:How do I determine the contributing bundle for a given extension
Current Time: Sat Jul 12 06:10:35 EDT 2025
Powered by FUDForum. Page generated in 0.03397 seconds
