Home » Language IDEs » Java Development Tools (JDT) » Q: Can JDT API be used headless?
Q: Can JDT API be used headless? [message #5600] Fri, 25 April 2003 13:37 Go to next message
I'm using the JDT API heavily in my metrics plugin, but now
would like to calculate the metrics as part of an automated
nightly build - from ant. Can the JDT API be used this way?
How does one find/access the workspace programmatically
in this scenario, if at all possible?
Frank Sauer
Re: Q: Can JDT API be used headless? [message #5629 is a reply to message #5600] Fri, 25 April 2003 15:18 Go to previous messageGo to next message
Originally posted by: jed_anderson.us.ibm.com
Frank,
I have written a tool that uses the JDT core headless, so I know that is
possible.
If you use just org.eclipse.jdt.core and org.eclipse.core.resources, you
can run headless and still access the workspace through normal means
(i.e. ResourcesPlugin.getWorkspace()).
jkca
> Frank Sauer
Re: Q: Can JDT API be used headless? [message #54384 is a reply to message #5600] Wed, 11 June 2003 07:03 Go to previous messageGo to next message
> Frank Sauer
Frank - I'm also trying to run the JDT core headless, have you had any
luck?
Thanks, Dennis
Re: Q: Can JDT API be used headless? [message #54408 is a reply to message #5629] Wed, 11 June 2003 07:13 Go to previous message
Jed:
Any chance you would be will to provide a snippet of code detailing how
you accomplished running the JDT core headless?
Thanks, Dennis
Jed Anderson wrote:
> Frank,
> possible.
> jkca
> > Regards,
> > Frank Sauer
Previous Topic:Threads and Monitors
Next Topic:NullPointerException at JavaCore.getOptions(JavaCore.java:1248)
Current Time: Mon Jul 14 21:35:09 EDT 2025
Powered by FUDForum. Page generated in 0.24524 seconds
