Home » Newcomers » Newcomers » Newbie Help with 1st OS X Install
Newbie Help with 1st OS X Install [message #62592] Wed, 11 May 2005 07:43 Go to next message
Originally posted by: lyle.norbeck.org
Hi:
Really basic questions for an OS X install.
I downloaded what I think was the base environment, and when I launch it
displays the splash screen and starts up. But, there's obviously some
things wrong with the installation. I added the web plug in, and need
help interpreting the error log.
If there is a link to documentation on this that would help, but I'm
unable to find much and Googling didn't help. How to you debug messages
like this:
Error May 11, 2005 05:57:33.578 Problems occurred when invoking code
from plug-in: "org.eclipse.core.runtime".java.lang.NoSuchMethodError:
org.eclipse.core.runtime.IConfigurationElement.getNamespace( )Ljava/lang/S
tring;at
org.eclipse.wst.common.dependencychecker.CheckMissingFiles.g etMissingFile
s(CheckMissingFiles.java:87)at
org.eclipse.wst.common.dependencychecker.CheckMissingFiles.e arlyStartup(C
heckMissingFiles.java:45)at
org.eclipse.ui.internal.EarlyStartupRunnable.runEarlyStartup (EarlyStartup
Runnable.java:81)at
org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartu pRunnable.jav
a:61)at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.j
ava:616)at org.eclipse.core.runtime.Platform.run(Platform.java:747)at
org.eclipse.ui.internal.Workbench$15.run(Workbench.java:1283 )at
java.lang.Thread.run(Thread.java:552)
Re: Newbie Help with 1st OS X Install [message #62689 is a reply to message #62592] Wed, 11 May 2005 09:56 Go to previous message
Originally posted by: jeff.duska_removethis.noaa.gov
It looks like your missing one of the WTP prerequisites. Make sure
you've install EMF driver[1], GEF driver[2] and the Java EMF driver[3].
Here the current links.
[1] http://download.eclipse.org/webtools/downloads/drivers/emf-s do-xsd-SDK-I200504141117.zip
[2] http://download.eclipse.org/webtools/downloads/drivers/GEF-S DK-3.1M6.zip
[3] http://download.eclipse.org/webtools/downloads/drivers/JEM-S DK-I20050415.zip
If you are still having problems, try dropping by the WTP newsgroups.
HTH,
Jeff
Lyle Schofield wrote:
> Hi:
> like this:
> tring;at
> Runnable.java:81)at
> a:61)at
Previous Topic:Intro comes up blank on win32
Next Topic:Eclipse not coming up!
Current Time: Sun Nov 09 09:25:50 EST 2025
Powered by FUDForum. Page generated in 0.06110 seconds
