| XML generating wizard [message #62585] |
Wed, 27 July 2005 03:47  |
Originally posted by: smahon.ittalks.co.uk
For part of an Eclipse plugin i'm developing, I want to generate an XML
file from an XSD Schema, similar to 'new -> other -> xml -> Create XML
file from an XML schema file'. This leads on to a great wizard, which I
would like to use in my app.
But I would like to make some changes to the wizard and make some
selections automatically. What plugin is this wizard contained in and is
it possible to extend it as part of my project?
Shane
| Re: XML generating wizard [message #62857 is a reply to message #62842] |
Wed, 07 September 2005 07:33  |
Nancy,
Did you try the WTP newsgroup?
nancy wrote:
> shane
> did you get to know answer to your question? I having same problem. I
> want to generate xml from a schema.
> do u know exactly which api can help me?
> thaks in advance nancy
| Re: XML generating wizard [message #596109 is a reply to message #62585] |
Wed, 27 July 2005 07:24  |
Shane,
Probably this wizard is provided by the XML tools in the WTP project.
I don't know anything about it.
shane wrote:
> XML file from an XSD Schema, similar to 'new -> other -> xml -> Create
> XML file from an XML schema file'. This leads on to a great wizard,
> which I would like to use in my app.
> is it possible to extend it as part of my project?
> Thanks
> Shane
| Re: XML generating wizard [message #596263 is a reply to message #62585] |
Fri, 02 September 2005 01:21  |
shane
did you get to know answer to your question? I having same problem. I want
thaks in advance
nancy
| Re: XML generating wizard [message #596270 is a reply to message #62842] |
Nancy,
nancy wrote:
> shane
FUDForum. Page generated in 0.05173 seconds
