Home » Language IDEs » C / C++ IDE (CDT) » Installation issue
Installation issue [message #62573] Tue, 18 February 2003 11:47 Go to next message
Originally posted by: acalifano.firstgenetic.net
I just installed Eclipse 2.0.2 (which seems to be the supported platform
for the CDT). After downloading the CDT zip and installing it in the
plugin directory, I received a message from Eclipse saying that the CDT
feature could not be properly configured because "the pluging
"org.eclipse.cdt.win32" version "1.0.1" referenced by this feature is
missing. included feature "org.eclipse.cdt_1.0.1" is missing"
Can anyone shed some light on this problem? Is that the right way to
install the plugin?
Thx!
Re: Installation issue [message #62620 is a reply to message #62573] Tue, 18 February 2003 15:24 Go to previous messageGo to next message
"Andrea Califano" <acalifano@firstgenetic.net> wrote in message
news:b2to3q$30b$1@rogue.oti.com...
| install the plugin?
| Thx!
This is a known issue and there is a workaround on most systems ...
Hi all,
There have been some sporadic problems reported regarding installing the CDT
in both Eclipse 2.0.x and 2.1.
The following is a guide to installing the CDT and a workaround for this
intermittent problem
If you unzip the bin.dist.zip file into the eclipse directory:
1) Be sure that all previous installations of the CDT have
been removed from your plugins and features directories
2) If the Install/Update manager will not let you install the CDT saying
something to the effect of Eclipse C/C++ Development Tools (Windows)
requires Eclipse C/C++ Development Tools 1.0.1
a) Eclipse will still install the plugins but it will disable them.
(Disabled plugins are not visible in the default view)
b) In the Install/Update Perspective, Install Configuration View
i) select the icon to show disabled features
ii) The Eclipse C/C++ Development Tools (Windows) will show as
disabled
iii) Click the "Enable" button in the Details Preview View
iv) Both plugins should now be fully enabled.
I will continue to look into why this is happening and hope to have it
solved in the near future
-Judy
Re: Installation issue [message #62671 is a reply to message #62620] Fri, 21 February 2003 00:39 Go to previous messageGo to next message
> Hi all,
> disabled
I am trying to get this installed on a XP box. Even with the above
mentioned work-around I am still not able to get CDT 1.0.1 installed on
Eclipse 2.0.2. I get an error meassage that says:
Error creating feature
"file:C:/eclipse/features/org.eclipse.cdt_1.0.1.jar/".[java.io.FilenotFoundException:
C:\eclipse\features\org.eclipse.cdt_1.0.1.jar\feature.xml (The system
cannot find the path specified)]
Am I missing something?
Dayne
Re: Installation issue [message #63082 is a reply to message #62620] Tue, 25 February 2003 19:28 Go to previous messageGo to next message
Originally posted by: davemedberry.myway.com
Thanks Judy, that worked for me.
For any other readers, the
Is in the top right hand corner of the Install Configuration pane (took me
awhile to find it....)
-dave
"Judy N. Green" <jgreen@qnx.com> wrote in message
news:b2u334$d4c$1@rogue.oti.com...
> | install the plugin?
> | Thx!
> Hi all,
CDT
> disabled
> -Judy
Re: Installation issue [message #64003 is a reply to message #62671] Wed, 05 March 2003 10:12 Go to previous message
Originally posted by: gdlxn.us.ibm.com
I'm also seeing the problem Dayne describes when trying to install CDT 1.01.
GA on IBM's WebSphere Studio Workbench 2.0.2 running on Windows 2000 SP 2.
Is there a workaround or fix?
Geoff Alexander
"Dayne Medlyn" <orbitsim@hotmail.com> wrote in message
news:b34e3e$vha$1@rogue.oti.com...
platform
> > Hi all,
CDT
> > disabled
xception:
> Dayne
Previous Topic:What is the difference between GDB and Cygwin GDB?
Next Topic:Load command progress help req
Current Time: Mon Nov 03 11:52:11 EST 2025
Powered by FUDForum. Page generated in 0.24494 seconds
