Home » Modeling » OCL » OCL rules processing classes on different packages
OCL rules processing classes on different packages [message #62525] Mon, 29 September 2008 08:06 Go to next message
Hi all !
I have some problem with a rule processing classes on a different package
thant the context.
I have an OCL method taking a parameter of a type defined in another emf
package (dreams.model). This parameter was unkonw at the compilation, so I
prefixed this parameter type by model:: and the compilation was ok.
But during the execution, when accessing to this parameter, I have an
OCLInvalid error (with ocl verbose). If the parameter type is in the same
package, I have no problem.
Any idea ?
Here is my OCL :
package dreams
context ResourceExtendedTest
def rankResource : rankResource(req : model::RequiredResource):Real=(
if (req.duration > 0) then
100.0
else
-0.0
endif
endpackage
Thanks in advance,
Samuel
Re: OCL rules processing classes on different packages [message #62549 is a reply to message #62525] Mon, 29 September 2008 10:17 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hi, Samuel,
The OclInvalid usually indicates some kind of RuntimeException in the
evaluation, like a ClassCastException, IllegalArgumentException, or
NullPointerException. Can you debug to find out which exception is
being thrown, where?
I don't have any ideas off-hand ... If you can provide a small
reproducible test case, you could attach it to a bug so we can
investigate the problem, in case it's a bug in the OCL interpreter.
Christian
samuel wrote:
> Hi all !
> package thant the context.
> I prefixed this parameter type by model:: and the compilation was ok.
> same package, I have no problem.
> Any idea ?
> Here is my OCL :
> package dreams
> 100.0 else -0.0
> endif
> endpackage
> Thanks in advance,
> Samuel
Re: OCL rules processing classes on different packages [message #62571 is a reply to message #62549] Wed, 01 October 2008 05:04 Go to previous messageGo to next message
Thanks you for your answer.
I debugged the ocl execution, and it was our bug. The eClass of the
parameter was not the same instance (same object, but different adress)
than the eCLass loaded in the OCL evaluator.
And somewhere, there was a containsAll on the eClass properties returning
false, launching the OCLIsInvalid error.
It's working now, thanks for your help !
Re: OCL rules processing classes on different packages [message #62595 is a reply to message #62571] Wed, 01 October 2008 09:00 Go to previous message
Great! I'm glad you were able to resolve the problem.
Perhaps a little more diagnostic information from the interpreter would
have been useful to you.
Christian
> than the eCLass loaded in the OCL evaluator. And somewhere, there was a
> containsAll on the eClass properties returning false, launching the
> OCLIsInvalid error.
Previous Topic:[Announce] MDT OCL 1.3.0M2 is available
Next Topic:Is there a tutorial on OCL?
Current Time: Sun Aug 31 10:59:31 EDT 2025
Powered by FUDForum. Page generated in 0.07669 seconds
