OCL rules processing classes on different packages [message #62525] |
Mon, 29 September 2008 08:06  |
Hi all !
I have some problem with a rule processing classes on a different package
thant the context.
I have an OCL method taking a parameter of a type defined in another emf
package (dreams.model). This parameter was unkonw at the compilation, so I
prefixed this parameter type by model:: and the compilation was ok.
But during the execution, when accessing to this parameter, I have an
OCLInvalid error (with ocl verbose). If the parameter type is in the same
package, I have no problem.
Any idea ?
Here is my OCL :
package dreams
context ResourceExtendedTest
def rankResource : rankResource(req : model::RequiredResource):Real=(
if (req.duration > 0) then
100.0
else
-0.0
endif
endpackage
Thanks in advance,
Samuel
Re: OCL rules processing classes on different packages [message #62549 is a reply to message #62525] |
Mon, 29 September 2008 10:17   |
Originally posted by: cdamus.zeligsoft.com
Hi, Samuel,
The OclInvalid usually indicates some kind of RuntimeException in the
evaluation, like a ClassCastException, IllegalArgumentException, or
NullPointerException. Can you debug to find out which exception is
being thrown, where?
I don't have any ideas off-hand ... If you can provide a small
reproducible test case, you could attach it to a bug so we can
investigate the problem, in case it's a bug in the OCL interpreter.
Christian
samuel wrote:
> Hi all !
> package thant the context.
> I prefixed this parameter type by model:: and the compilation was ok.
> same package, I have no problem.
> Any idea ?
> Here is my OCL :
> package dreams
> 100.0 else -0.0
> endif
> endpackage
> Thanks in advance,
> Samuel
Re: OCL rules processing classes on different packages [message #62595 is a reply to message #62571] |
Wed, 01 October 2008 09:00  |
Great! I'm glad you were able to resolve the problem.
Perhaps a little more diagnostic information from the interpreter would
have been useful to you.
Christian
samuel wrote:
> Thanks you for your answer.
> I debugged the ocl execution, and it was our bug. The eClass of the
> parameter was not the same instance (same object, but different adress)
> than the eCLass loaded in the OCL evaluator. And somewhere, there was a
> containsAll on the eClass properties returning false, launching the
> OCLIsInvalid error.
> It's working now, thanks for your help !
FUDForum. Page generated in 0.19058 seconds
