| no SWT in my VE [message #62503] |
Wed, 29 September 2004 01:34  |
Originally posted by: spam.scientifik.com
I'm using ecilpse 3.0.1 and VE 1.0......and SWT doesn't appear to even be
included?
Perhaps I'm doing something completely wrong here but the SWT palette
doesn't show up and I see no references to SWT anywhere.
From what I've read, it should be there in this release, correct?
| Re: no SWT in my VE [message #63264 is a reply to message #62709] |
Wed, 29 September 2004 14:51   |
Joe Winchester wrote:
> Hi zambizzi,
> Can you try another way to add the SWT runtime to your project, this
> time opening the Java build path, switching to the Libraries page, and
> using "Add Library". Then select "Standard Widget Toolkit" from the
> list, press Next and Finish. Is there anything suspcious written to
> the .log file ?
> Best regards,
> Joe Winchester
That (sort of) worked, at least the SWT menus show up now, however, my
widgets aren't being displayed correctly. I can't create a shell or
anything that resembles an application. When I drag widgets onto the
visual area they're just icons with text beneath them.
I'm new to Eclipse and *very* new to VE so I have no clue what I'm doing
wrong here.
Is there a coherent tutorial out there? The couple that I found on
eclipse.org are far too vague and aren't helping at all.
For example:
http://www-106.ibm.com/developerworks/opensource/library/os- ecvisual/
When I click and drag a shell widget onto the visual builder area all I
see is a crappy little icon that says "sShell" underneath it.....not a
visual representation of a shell window as expected.
Any ideas?
Thanks again!
| Re: no SWT in my VE [message #63286 is a reply to message #63264] |
Wed, 29 September 2004 15:11  |
> > Hi zambizzi,
> > the .log file ?
> > Best regards,
> > Joe Winchester
> wrong here.
> For example:
> Any ideas?
> Thanks again!
Nevermind, disregard that last post - the little shell window was hiding
down in the corder of my screen. I clicked it and the shell window
appeared in the designer area and now it does everytime I create a class.
Because it was hiding in minimized state down in the corner I couldn't
find it to add widgets to it.
All is good now, I love it!
Thanks for your help!!!
| Re: no SWT in my VE [message #599977 is a reply to message #62503] |
Wed, 29 September 2004 02:20  |
> included?
-answering my own post - edit...
I Did try choosing the SWT application style when creating a new visual
class, I still have no SWT menu after doing so...what gives?
I use Gentoo Linux/GTK, eclipse 3.0.1, VE 1.0
| Re: no SWT in my VE [message #599983 is a reply to message #62503] |
Wed, 29 September 2004 02:28  |
> included?
this option isn't in the project-wizards.
create a simple java-project.
then call the visual-class wizard (new visual class...)
here you can choose to create a swt application.
| Re: no SWT in my VE [message #599989 is a reply to message #62593] |
Wed, 29 September 2004 02:32  |
Christian wrote:
> > included?
Did you read my post before yours? Just to be sure I tried this again w/
an entirely new test project, I get no SWT palette, even when I specify
SWT->Application as a style in the New Visual Class menu.
I made sure to add the necessary external jars for SWT (there are 3 for
linux/gtk)
Thanks!
| Re: no SWT in my VE [message #600025 is a reply to message #62615] |
Wed, 29 September 2004 05:41  |
Hi zambizzi,
the .log file ?
Joe Winchester
| Re: no SWT in my VE [message #600145 is a reply to message #62709] |
> Hi zambizzi,
> the .log file ?
> Best regards,
> Joe Winchester
wrong here.
For example:
Any ideas?
Thanks again!
| Re: no SWT in my VE [message #600151 is a reply to message #63264] |
> > Hi zambizzi,
> > the .log file ?
> > Best regards,
> > Joe Winchester
> wrong here.
> For example:
> Any ideas?
> Thanks again!
FUDForum. Page generated in 0.08519 seconds
