Home » Modeling » TMF (Xtext) » Xtext Editor as a standalone application?
Xtext Editor as a standalone application? [message #62450] Wed, 22 July 2009 07:42 Go to next message
Originally posted by: ilyas.keser.gmail.com
Hi @all,
is it possible to use the generated DSL editor as a standalone
application (without Eclipse)?
ILyas
Re: Xtext Editor as a standalone application? [message #62505 is a reply to message #62450] Wed, 22 July 2009 08:42 Go to previous messageGo to next message
Originally posted by: oba.informatik.uni-kiel.de
Hi Ilyas,
you could use the message with the subject "[XText] a standalone Java
application that parses text to model"
Good luck
mN
Ilyas Keser wrote:
> Hi @all,
> ILyas
Re: Xtext Editor as a standalone application? [message #62845 is a reply to message #62505] Wed, 22 July 2009 12:47 Go to previous messageGo to next message
Hi mN,
thanks for your reply.
If I understood the example correctly, one can parse with XtextResource
a resource and get the parse result. OK, but XtextResource doesn't offer
methods to run/start the editor? Any ideas?
ILyas
myName schrieb:
> Hi Ilyas,
> Good luck
> mN
> Ilyas Keser wrote:
>> Hi @all,
>> Thanks,
>> ILyas
Re: Xtext Editor as a standalone application? [message #62883 is a reply to message #62450] Wed, 22 July 2009 15:50 Go to previous messageGo to next message
Hi Ilyas,
Xtext creates Eclipse plugins. What do you mean with "editor without
Eclipse"? You may want to use the runtime part in standalone mode and
create all the ui infrastructure yourself. It is easier to provide a
minimal Eclipse distro (with Eclipse - whatever that means) that
contains the editor plugin.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 22.07.2009 13:42 Uhr, schrieb Ilyas Keser:
> Hi @all,
> ILyas
Re: Xtext Editor as a standalone application? [message #62934 is a reply to message #62883] Thu, 23 July 2009 11:17 Go to previous messageGo to next message
Sebastian,
I remember that the GMF generator somewhere has en option to generate a
standalone editor. The result is a downsized Eclipse application with
only the GMF plugin available. People using this standalone version can
only create and edit model files of this DSL and nothing else.
This is useful if your DSL is used by non programmers and you don't want
to expose all of Eclipse to them, but a sim0plified environment instead.
Jos
Sebastian Zarnekow wrote:
> Hi Ilyas,
> Sebastian
Re: Xtext Editor as a standalone application? [message #62956 is a reply to message #62934] Fri, 24 July 2009 04:46 Go to previous messageGo to next message
Hi Sebastian & Jos,
thanks for your answers. My question was about an application which only
shows the generated Xtext editor. You can then give this tool to users
of your DSL (yes, non programmers) to provide a nice editor for model
editing.
If I use a minimal Eclipse distro is it possible to show only the editor
and hide everything else? With "everything else" I mean other views and
windows of Eclipse like Project Explorer or Console...
ILyas
Jos Warmer schrieb:
> Sebastian,
> Jos
>> Hi Ilyas,
>> Regards,
>> Sebastian
Re: Xtext Editor as a standalone application? [message #62960 is a reply to message #62956] Fri, 24 July 2009 04:52 Go to previous message
Hi Ilyas,
yes thats possible. You can remove almost anything from Eclipse (with
respect to the dependencies of the Editor).
There are various tutorials about pde development and product packaging
out there - I think google will be your friend :-).
Sebastian
Am 24.07.2009 10:46 Uhr, schrieb Ilyas Keser:
> Hi Sebastian & Jos,
> editing.
> ILyas
> Jos Warmer schrieb:
>> Sebastian,
>> a standalone editor. The result is a downsized Eclipse application
>> with only the GMF plugin available. People using this standalone
>> version can only create and edit model files of this DSL and nothing
>> else.
>> want to expose all of Eclipse to them, but a sim0plified environment
>> instead.
>> Jos
>>> Hi Ilyas,
>>> Regards,
>>> Sebastian
Previous Topic:[Xtext] static initializer size problem in generated parser code
Next Topic:XtextResource to XMI
Current Time: Sat Jul 26 14:02:01 EDT 2025
Powered by FUDForum. Page generated in 0.47026 seconds
