| Problem exporting OCL interpreter example [message #62425] |
Tue, 23 September 2008 07:35  |
Originally posted by: sderrienREMOVE.irisa.fr
I have some problems when exporting the OCL interpreter example on my
eclipse plugin directory.
The example works perfectly well when launched as a runtime eclipse
application, however it is never loaded by my eclipse configuration when
exported in the eclipse plugin directory (not registered in the plugin
details info window).
I made the following checks :
* no messages in error/problem log
* used the -clean option when launching eclipse
* checked that the .jar was in the correct directory
* used another name fot the plugin
but couldn't solve the issue.
I am not sure wether it is an eclipse or OCL related issue, that's why
I'm asking in this group. Has anybody been facing the same problem ?
Thanks in advance,
Steven
| Re: Problem exporting OCL interpreter example [message #62449 is a reply to message #62425] |
Tue, 23 September 2008 09:06   |
Originally posted by: cdamus.zeligsoft.com
Hi, Steven,
I haven't had this problem with this particular plug-in. You should get
more diagnostic information if you run with the -debug command-line
argument. AFAIK, Equinox doesn't report configuration problems to the
Error Log without -debug, but the messages you will get generally are
quite informative.
Another consideration is whether you are using a p2-based Eclipse
Platform (i.e., Ganymede or later). In that case, you need to export
into ${ECLIPSE_HOME}/dropins/eclipse in order to spontaneously add a
plug-in to your config.
HTH,
Christian
news.eclipse.org wrote:
> Hello,
> Thanks in advance,
> Steven
| Re: Problem exporting OCL interpreter example [message #62478 is a reply to message #62449] |
Wed, 24 September 2008 02:57  |
Thanks Christian,
The problem was actually coming from another plugin which was not
correctly uninstalled. The -debug option helped me finfing the problem.
Steven
Christian W. Damus a écrit :
> Hi, Steven,
> quite informative.
> HTH,
> Christian
>> Hello,
>> when exported in the eclipse plugin directory (not registered in the
>> plugin details info window).
>> Thanks in advance,
>> Steven
FUDForum. Page generated in 0.04353 seconds
