| Problems with launching Eclipse 3.1M6 on x86_64 Linux Box [message #62396] | Tue, 10 May 2005 10:12  |  |
| Eclipse User  |  |  |  |  | Originally posted by: jens.gruentjes.ebira.de
 i get an error message when I try to start Eclipse 3.1M6. The splash  =
 screen appears and after that I get a box that says 'An error has  =
 occurred. See the log file  =
 "/home/jens/eclipse/configuration/1115733377008.log"'.
 I have spent some time on reading articles, bug reports and so on but no=
 ne  =
 of the solutions worked for me. The error still remained the same. I hav=
 e  =
 included the output of the error message an of the ldd-command on the  =
 library that is mentioned in the log.
 I am using SuSE Linux 9.2, JDK 1.4.2_06-b03. I do have the JDK  =
 1.5.0_02-b09 installed as well but is this a problem? I hope you can hel=
 p  =
 me here.
 Looking in that message mentioned above gives the following output:
 !SESSION 2005-05-10 15:56:18.355  =
 eclipse.buildId=3DI20050401-1645
 java.version=3D1.4.2_06
 java.vendor=3DSun Microsystems Inc.
 BootLoader constants: OS=3Dlinux, ARCH=3Dx86_64, WS=3Dgtk, NL=3Dde_DE
 Command-line arguments:  -os linux -ws gtk -arch x86_64
 !ENTRY org.eclipse.osgi 2005-05-10 15:56:18.357
 !MESSAGE Application error
 !STACK 1
 java.lang.UnsatisfiedLinkError:  =
 /home/jens/eclipse/configuration/org.eclipse.osg
 i/bundles/67/1/.cp/os/linux/x86_64/libswt-pi-gtk-3128.so:  =
 figuration/org.eclipse.osgi/bundles/67/1/.cp/os/linux/x86_64 /libswt-pi-g=
 tk-3128.
 so: cannot open shared object file: No such file or directory
 at java.lang.ClassLoader$NativeLibrary.load(Native Method)
 at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1586)
 at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1495)
 at java.lang.Runtime.loadLibrary0(Runtime.java:788)
 at java.lang.System.loadLibrary(System.java:834)
 at  org.eclipse.swt.internal.Library.loadLibrary(Library.java:12 =
 3)
 at org.eclipse.swt.internal.gtk.OS.<clinit>(OS.java:19)
 at  org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: =
 63)
 54)
 at org.eclipse.swt.widgets.Display.<clinit>(Display.java:122)
 at  =
 org.eclipse.ui.internal.Workbench.createDisplay(Workbench.ja va:320)
 at  org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:155) =
 at  =
 org.eclipse.ui.internal.ide.IDEApplication.createDisplay(IDE Application.=
 java:128)
 at  =
 org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:79)
 at  =
 org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActiva=
 tor.java:228)
 at  =
 org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:=
 344)
 at  =
 156)
 at  =
 sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.jav=
 a:39)
 at  =
 sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessor=
 Impl.java:25)
 at  org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 =
 at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
 at org.eclipse.core.launcher.Main.run(Main.java:942)
 at org.eclipse.core.launcher.Main.main(Main.java:926)
 An 'ldd  =
 /home/jens/eclipse/configuration/org.eclipse.osgi/bundles/67 /1/.cp/os/li=
 nux/x86_64/libswt-pi-gtk-3128.so'  =
 gives:
 libgtk-x11-2.0.so.0 =3D> /opt/gnome/lib64/libgtk-x11-2.0.so.0  =
 (0x0000002a956d0000)
 libgthread-2.0.so.0 =3D> /opt/gnome/lib64/libgthread-2.0.so.0  =
 (0x0000002a95ac1000)
 libXtst.so.6 =3D> /usr/X11R6/lib64/libXtst.so.6 (0x0000002a95bc=
 6000)
 libc.so.6 =3D> /lib64/tls/libc.so.6 (0x0000002a95ccc000)
 libgdk_pixbuf-2.0.so.0 =3D> /opt/gnome/lib64/libgdk_pixbuf-2.0.=
 so.0  =
 (0x0000002a95eee000)
 libgdk-x11-2.0.so.0 =3D> /opt/gnome/lib64/libgdk-x11-2.0.so.0  =
 (0x0000002a96005000)
 libX11.so.6 =3D> /usr/X11R6/lib64/libX11.so.6 (0x0000002a961820=
 00)
 libpangoxft-1.0.so.0 =3D> /opt/gnome/lib64/libpangoxft-1.0.so.0=
 (0x0000002a96391000)
 libpangox-1.0.so.0 =3D> /opt/gnome/lib64/libpangox-1.0.so.0  =
 (0x0000002a96497000)
 libpango-1.0.so.0 =3D> /opt/gnome/lib64/libpango-1.0.so.0  =
 (0x0000002a965a3000)
 libatk-1.0.so.0 =3D> /opt/gnome/lib64/libatk-1.0.so.0  =
 (0x0000002a966e0000)
 libgobject-2.0.so.0 =3D> /opt/gnome/lib64/libgobject-2.0.so.0  =
 (0x0000002a96800000)
 libgmodule-2.0.so.0 =3D> /opt/gnome/lib64/libgmodule-2.0.so.0  =
 (0x0000002a9693f000)
 libdl.so.2 =3D> /lib64/libdl.so.2 (0x0000002a96a42000)
 libglib-2.0.so.0 =3D> /opt/gnome/lib64/libglib-2.0.so.0  =
 (0x0000002a96b46000)
 libm.so.6 =3D> /lib64/tls/libm.so.6 (0x0000002a96ccc000)
 libpthread.so.0 =3D> /lib64/tls/libpthread.so.0 (0x0000002a96e2=
 3000)
 libXext.so.6 =3D> /usr/X11R6/lib64/libXext.so.6 (0x0000002a96f3=
 8000)
 /lib64/ld-linux-x86-64.so.2 =3D> /lib64/ld-linux-x86-64.so.2  =
 (0x000000552aaaa000)
 libXrandr.so.2 =3D> /usr/X11R6/lib64/libXrandr.so.2  =
 (0x0000002a97049000)
 libXi.so.6 =3D> /usr/X11R6/lib64/libXi.so.6 (0x0000002a9714c000=
 libXft.so.2 =3D> /usr/X11R6/lib64/libXft.so.2 (0x0000002a972550=
 00)
 libfreetype.so.6 =3D> /usr/lib64/libfreetype.so.6  =
 (0x0000002a97369000)
 libfontconfig.so.1 =3D> /usr/lib64/libfontconfig.so.1  =
 (0x0000002a974f8000)
 libXcursor.so.1 =3D> /usr/X11R6/lib64/libXcursor.so.1  =
 (0x0000002a97632000)
 libXrender.so.1 =3D> /usr/X11R6/lib64/libXrender.so.1  =
 (0x0000002a9773c000)
 libpangoft2-1.0.so.0 =3D> /opt/gnome/lib64/libpangoft2-1.0.so.0=
 (0x0000002a97845000)
 libexpat.so.0 =3D> /usr/lib64/libexpat.so.0 (0x0000002a9796e000=
| Re: Problems with launching Eclipse 3.1M6 on x86_64 Linux Box [message #62641 is a reply to message #62396] | Wed, 11 May 2005 08:48   |  |
| Eclipse User  |  |  |  |  | Originally posted by: myersj.gmail.com
 Jens,
 You're running with a 32 bit 1.4.2 JRE.  Try launching with the -vm
 /path/to/1.5/jre argument to use the 1.5 JRE if it is the 64 bit
 version.  Otherwise, download and install the 64 bit 1.5 JRE from Sun's
 site.
 Hope this helps,
 - Jeff
 Jens Gruentjes wrote:
 > Hello,
 > none  of the solutions worked for me. The error still remained the same.
 > I have  included the output of the error message an of the ldd-command
 > on the  library that is mentioned in the log.
 > help  me here.
 > eclipse.buildId=I20050401-1645
 > java.version=1.4.2_06
 > java.vendor=Sun Microsystems Inc.
 > BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=de_DE
| Re: Problems with launching Eclipse 3.1M6 on x86_64 Linux Box [message #63054 is a reply to message #63041] | Wed, 11 May 2005 12:27   |  |
 Jens,
 In that case my guess would be that SuSE is packaging the 32 bit version
 of Eclipse on it's 64 bit distribution.
 - Jeff
 > Hello Jeff,
 > thanks for your answer, it solved the problem for me.
 > There is one strange thing left to me. I use a 64Bit-version of SuSE and
 > I  worked with Eclipse 3.0.1 "rpm"ed by SuSE. Their version runs with
 > the JRE  1.4.2 but my downloaded version did not until I used the -vm
 > argument.
 > But anyway, thanks for the hint
 > Jens
 > On Wed, 11 May 2005 14:48:15 +0200, Jeff Myers <myersj@gmail.com> wrote:
 >> Jens,
 >> Sun's  site.
 >> Hope this helps,
 >>   - Jeff
| Re: Problems with launching Eclipse 3.1M6 on x86_64 Linux Box [message #63300 is a reply to message #63054] | Thu, 12 May 2005 02:57  |  |
 Hi Jeff and others again,
 Eclipse works now unless I start it directly from KDE (via a link on the=
 desktop). When I do it that way, Eclipse crashes with the following  =
 message:
 JVM terminated. Exit code=3D1
 /usr/java/jdk1.5.0/bin/java
 -Xms40m
 -Xmx256m
 -jar /opt/eclipse/startup.jar
 -os linux
 -ws gtk
 -arch x86_64
 -launcher /opt/eclipse/eclipse
 -name Eclipse
 -showsplash 600
 -exitdata 1d0002
 -vm /usr/java/jdk1.5.0/bin/java
 -vmargs
 -Xms40m
 -Xmx256m
 Starting Eclipse from a console does not seem to have this error at leas=
 t  =
 so far as I can tell.
 Maybe somebody of you has an explanation for this strange behaviour.
 Jens
 On Wed, 11 May 2005 18:27:28 +0200, Jeff Myers <myersj@gmail.com> wrote:=
 > Jens,
 > In that case my guess would be that SuSE is packaging the 32 bit versi=
 on  =
 >   - Jeff
FUDForum. Page generated in 0.29120 seconds
