Home » Archived » BIRT » [ERR]: org.eclipse.birt.chart.exception.PluginException: Unable to locate any en
[ERR]: org.eclipse.birt.chart.exception.PluginException: Unable to locate any en [message #62350] Thu, 28 July 2005 14:01 Go to next message
Originally posted by: jyl.us.ibm.com
I am a newcomer of BIRT, trying to learn Chart Programming by running the
"create a line chart programmatically" example in FAQ. I ran into the
any entries for lookup=dv.SWING; (full message attached). Will appreciate
any advice on how to resolve the problem.
Also, is there any doc describing how to start with the chart programming
with examples?
Juhnyoung
any entries for lookup=dv.SWING; element=(name:device) in any plugin.xml
file in all of the available plugins
entries for lookup=dv.SWING; element=(name:device) in any plugin.xml file
org.eclipse.birt.chart.util.PluginSettings.getPluginXmlObjec t(PluginSettings.java:636)
org.eclipse.birt.chart.util.PluginSettings.getDevice(PluginS ettings.java:324)
org.eclipse.birt.chart.examples.api.viewer.SwingLiveChartVie wer. <init>(SwingLiveChartViewer.java:116)
org.eclipse.birt.chart.examples.api.viewer.SwingLiveChartVie wer.main(SwingLiveChartViewer.java:92)
org.eclipse.birt.chart.examples.api.viewer.SwingLiveChartVie wer.main(SwingLiveChartViewer.java:105)
Exception in thread "main"
Re: [ERR]: org.eclipse.birt.chart.exception.PluginException: Unable to locate any en [message #62444 is a reply to message #62350] Thu, 28 July 2005 22:03 Go to previous message
Greeting,
For resolving the problem you encountered, please add the following lines to
Run -> Arguments -> VM arguments:
-DSTANDALONE
-DBIRT_HOME=<Your BIRT_HOME>
In addition, you could find some chart programming examples in
org.eclipse.birt.chart.examples package.
Cheers.
Nina
"Juhnyoung Lee" <jyl@us.ibm.com> wrote in message
news:08341c43d29dfc2eb6e05dd4750c554c$1@www.eclipse.org...
> with examples?
> Juhnyoung
> at
> at
> at
> at
> at
> at
> at
> at
> java.lang.NullPointerException
> at
Previous Topic:Viewer App Server
Next Topic:Multiple data sources in a report table ?
Current Time: Thu Jul 17 20:12:28 EDT 2025
Powered by FUDForum. Page generated in 0.06450 seconds
