Home » Modeling » GMF (Graphical Modeling Framework) » "load resource" from editor canvas fails
"load resource" from editor canvas fails [message #62335] Fri, 13 October 2006 14:14 Go to next message
i try to load a resource from a diagram canvas using right-click -> load
resource. the resource is however not loaded into the ecore file. i have
to edit the ecore with the emf table-based editor to load the resource.
only then i can make references to resource elements inside the gmf
editor´s property view.
is this a known bug?
thanks, felix
Re: "load resource" from editor canvas fails [message #62430 is a reply to message #62335] Sat, 14 October 2006 10:39 Go to previous message
Felix Dorner schrieb:
It is just that the Properties view is not updated correctly. I have to
close and reopen it for the resource model elements to appear.
Felix
Previous Topic:Resource for Adding Connections
Next Topic:How do I implement complex model changes via EOperations?
Current Time: Fri Nov 07 12:21:15 EST 2025
Powered by FUDForum. Page generated in 0.04806 seconds
