| Error trying to run a Java Project [message #62324] |
Mon, 09 May 2005 22:39  |
Originally posted by: james.dixon.canberra.edu.au
I'm a newbie to Eclipse. UI have set it up, and it seems to be running
well - until I try and execute the project I am working on. I get the
following message:
Activation.main: warning: sun.rmi.activation.execPolicy system
property unspecified and no ExecPermissions/ExecOptionPermissions
granted; subsequent activation attempts may fail due to unsuccessful
ExecPermission/ExecOptionPermission permission checks. For
documentation on how to configure rmid security, refer to:
http://java.sun.com/j2se/1.4/docs/tooldocs/solaris/rmid.html
http://java.sun.com/j2se/1.4/docs/tooldocs/win32/rmid.html
I have checked the website as instructed (I am using a Windows OS) and
everything seems to be OK. I have run a netstat, and it says that
javaw.exe is using port 1098 - I assume this is the process that calls the
RMID daemon?
Anyway, I've not had much luck getting my projects to run, so any help
would be gratefully received!
I am running Eclipse 3.0(.02) using j2re1.4.2_06. Am I missing a plug-in
or something? It's very frustrating. Grateful for any advice or pointers.
Cheers
James
| Re: Error trying to run a Java Project [message #64232 is a reply to message #62324] |
Sat, 14 May 2005 13:54  |
Originally posted by: aronbock.hotmail.com
James, I've never seen this error, but am writing just so you don't feel all
alone ;-) Have you been able to run any project at all? Even a "hello
world!" one? If so, uh, *shrug*; else, it could be an installation issue
(though there's not much "installation" involved in unzipping the
distribution!), and a reinstall may help.
--A
"James" <james.dixon@canberra.edu.au> wrote in message
news:e8095665ec95e549e4a9133be1ce5907$1@www.eclipse.org...
> Hi
> following message:
> RMID daemon?
> pointers.
FUDForum. Page generated in 0.08842 seconds
